Old Mar 09, 2013, 10:18 PM
lasakro is offline
Find More Posts by lasakro
Seeking Control
lasakro's Avatar
United States, NY, Amsterdam
Joined Dec 2012
Originally Posted by keithy4129 View Post
not to hijack this thread but what happened to your 130x board? mine just kicked the bucket(rudder goes crazy) They made you send it in? I have a email into horizon, it would suck to send it in.
130X was 1 week old when all servos stopped working, failed AMS1117 5 volt regulator. They had me break it in half, send them the photo with packing slip and sent me a new one. The new one had a cold solder and they had me return the board. USPS went today to drop it off and they were closed as per the tracking info. I may just pick up another one to keep the heli in the air. You see why I'm so interested in the double regulator mod on this heli.
My tail servo pot was oxidized new causing the rudder to move all over. Are you sure it's the 3in1 and not the servo?
lasakro is offline Find More Posts by lasakro
Old Mar 09, 2013, 10:38 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
Yeah, after a few seconds in the air it goes full right rudder and stays there, i can counter with a lot of left and it will hold it straight. The servo itself works great, knock on wood.
keithy4129 is offline Find More Posts by keithy4129
Old Mar 10, 2013, 06:21 AM
gs550t1981 is offline
Find More Posts by gs550t1981
Beginner Pilot
United States, NY, Coram
Joined Jul 2012
It's good that you now see a difference in the gain. Maybe some slight FW changes but not enough.
High gain = Twitch. What I have is a bounce. What do you have? I got mine yesterday. Do you know about ch 5?
I am getting a tail wag.... I will take a video later on and post it up so you can see. Like I said, right out of the box it started doing it. What do you mean by ch. 5 ?
gs550t1981 is offline Find More Posts by gs550t1981
Old Mar 10, 2013, 02:55 PM
lasakro is offline
Seeking Control
lasakro's Avatar
Joined Dec 2012
Gain signal is sent using channel 5 of your tx. Check your manual on how to do it. Either send a fix value or assign it to one of your pots. range is -100 to 100. Default is 0 and I find on mine 100 is the best is it still bounces. I'm using a Devo 10 and Deviation which many Blade owners don't use.
Old Mar 11, 2013, 04:59 AM
meherenow7 is offline
Find More Posts by meherenow7
Joined Sep 2004
Just my 2 cents worth on the issue of tail bounce on the MCPX BL. I think it has been established that your not going to get rid of the bounce while hovering and doing small movement flying. I have some tail bounce on mine and I don't think it is an issue for flying at all. I can say that adjusting the gain on channel made a huge difference to the tail holding ability of the heli for fast backward flight. At stock setting of 0 gain, i was getting blowouts just flying a backwards straight line. When set at +50% out of a possible 125% (JR Radio), I could fly fast backwards with no blowout. I haven't tested much more than this.
Conclusion is, stop whingeing about the tail wag, unless it is so extreme to be uncontrollable and just fly this awesome little heli the way its meant to.
meherenow7 is offline Find More Posts by meherenow7
Old Mar 11, 2013, 05:35 AM
Beginner Pilot
Joined Jul 2012
Understood....... now when adjusting the gain on this bad boy do I activate the gyro on my transmitter? I never messed with the gain settings on a micro before. Always left it under "inhibit". Using the Dx8.... Thanks
Old Mar 11, 2013, 08:09 AM
chulian1819 is offline
Find More Posts by chulian1819
chulian1819's Avatar
Medellín, Colombia
Joined Apr 2010
The heli is brand new, out of the box, this was suposed to be the first flight video but heli has a major problem
mcpx bl tail motor not working (0 min 33 sec)
the tail motor wont spin and get really hot, any ideas?
Thank you in advance
chulian1819 is offline Find More Posts by chulian1819
Old Mar 11, 2013, 08:17 AM
lasakro is offline
Seeking Control
lasakro's Avatar
Joined Dec 2012
http://www.youtube.com/watch?v=sbWau...ature=youtu.be
Assuming it freely rotates probably the motor is missing a phase. New out of the box, return it.
Old Mar 11, 2013, 01:01 PM
Beginner Pilot
Joined Jul 2012
Is it just me or are these brushless babies having lots of issues? They couldn't even get it to hover without a tall wag.... bad motors, hopefully the control boards will last on these... my nano lasted 93 flights and my original mcpx only lasted 70. Have to say though HH does have excellent customer service....
Old Mar 11, 2013, 02:15 PM
dasBlade300X is offline
Find More Posts by dasBlade300X
Joined Feb 2012
First thing I'd do is check the tail motor connection to the 3-in-1 board.....and the motor connection to the tail boom mount....
Those micro-pins have been known to cause problems on occasion...
Failing THAT, however....I agree...DON'T DELAY in shipping it back as defective!!
If you start messing with it, HH MAY not honor the warranty!!!
Good luck!
dasBlade300X is offline Find More Posts by dasBlade300X
Old Mar 11, 2013, 04:05 PM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
QQ - Flying the MCPX BL and having a ball -Question, though, I notice that my tail isn't holding completely. It seems to drift ever so slowly as I fly it (counter clockwise). I could use trim to correct it, but know that's a no-no w/ AS3X - any thoughts?
whichwaysup is offline Find More Posts by whichwaysup
Old Mar 11, 2013, 04:28 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Bind it again to see if it fixes that, but if it doesn't, using some trim is fine
jasmine2501 is offline Find More Posts by jasmine2501
Old Mar 11, 2013, 06:10 PM
Joined Sep 2004
I'm using and old JR Radio, so I had to assign my Governor function to my channel 5, and then I adjust it through the Gov setting which gives me + and - 125%.
You need to work out what function can be assigned to your channel 5 (Normally Gear channel) on your particular TX and then assign it appropriately. Then you can adjust that function accordingly. It basically doesn't matter if its gyro, gov or just plain travel adjustments on channel 5, they all do the same thing.
Mat.
Old Mar 12, 2013, 08:51 AM
Joined Apr 2012
I'll try re-binding. Question, though - on the MSRx, if you give it 3 or more clicks of rudder trim before spooling up, it turns off the AS3X. I do not think I want to imagine this bird without the gyro . . . can I use more than 3 clicks of rudder without turning off the AS3X on this bird?
Old Mar 12, 2013, 08:55 AM
Martyn McKinney is offline
Find More Posts by Martyn McKinney
Toronto Canada
Joined Dec 2002
Oops - double post!
Martyn McKinney is offline Find More Posts by Martyn McKinney
Sold Blade MCPx KIDGLOVES00 Aircraft - Electric - Helis (FS/W) 2 Jan 09, 2013 06:17 PM
Sold Reduced -- Blade MCPX Version 2 - 90.00 shipped Roly72 Aircraft - Electric - Helis (FS/W) 3 Jan 05, 2013 10:22 AM
Wanted Blade mcpx batteries and parts xdbrix Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 04, 2013 11:47 AM
Sold blade mcpx v2 with extras forsale or trade. Wildcat29 Aircraft - Electric - Helis (FS/W) 0 Jan 04, 2013 01:52 AM
For Sale Upgraded Blade MCPx - Upgraded Blade MCPx - $160 Shipped Sl0flyer Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Mar 06, 2012 09:21 AM
