Old Dec 13, 2012, 11:24 AM
skylane42 is offline
Find More Posts by skylane42
USA, MI, Portage
Joined Sep 2003
Switching HXT bullet connectors
I need to switch the positive and negitive poles on a HXT 4mm connector. Is there a way to release the current configuration and just switch the bullets? I would rather not cut the connector apart and re-do.
skylane42 is offline Find More Posts by skylane42
Old Dec 13, 2012, 11:52 AM
JimHSoars is online now
Find More Posts by JimHSoars
United States, OK, Tulsa
Joined Jun 2003
skylane42:
With the EC# connectors I use I have used various items such as a philips screw driver, a hex driver, etc to push out the bullet. I used a sharp rap with a small hammer with to knock them out. Because the red housing is probably polarized to prevent attaching them backwards you will probably have to use a soldering iron to remove the wires and solder them into the opposite bullet.
Anyone doing this should probably add a large marker such as a big piece of masking tape to the adapter saying its polarity is reversed. Attaching it to something like an ESC could kill it.
Where are the red covered bullet connectors and the adapter in your photo avaliable.
- Jim
JimHSoars is online now Find More Posts by JimHSoars
Old Dec 13, 2012, 01:08 PM
USA, MI, Portage
Joined Sep 2003
got tit off ebay.
Old Dec 13, 2012, 09:42 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
These push in opposite of the EC# connectors. You push the wire through, solder on the connector and then pull the bullets back in. So you would have to push them out from the wire side, so no I don't see there being any reasonable way to swap them. Even if you got them released you would have to unsolder them.
grimbeaver is offline Find More Posts by grimbeaver
Old Dec 13, 2012, 10:13 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
For the cost of the connector, I just toss the mistakes.
OR
Cut the wires 1/2 way down, solder back together and shrinktube. That's if the the connectors line up OK that way. Use Red shrink tube on the + wire and black shrinktube on the neg lead.
hoppy is offline Find More Posts by hoppy
Old Dec 14, 2012, 09:37 AM
USA, MI, Portage
Joined Sep 2003
Thanks guys. Looks like I will just build a new one.
Old Dec 14, 2012, 10:51 AM
United States, MN
Joined Feb 2011
Good choice. I tried to push out the bullets last night on a connector I had cut off a battery when I stopped using these horrible connectors and I could not get it out with any reasonable amount of force.
Discussion HXT 4mm connectors - parallel chargers - do they exist? totality Batteries and Chargers 4 Aug 23, 2012 07:03 AM
Wanted IN EDMONTON? HXT 4mm bullets for hobbyking battery Xnaron Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jul 19, 2012 12:45 AM
Discussion HXT 4mm Connectors = for heavy lifters? glmccready Multirotor Talk 5 May 26, 2012 09:22 PM
Question Soldering vs Bullet Connectors AusTelemetry Multirotor Talk 39 Mar 13, 2012 03:45 PM
Discussion HXT 4mm bullet connectors with red plastic housing? Little-Acorn Batteries and Chargers 3 Mar 06, 2011 10:55 PM
