Old Nov 08, 2012, 11:05 PM
jofro is offline
Find More Posts by jofro
Joined Jan 2010
Mini-Review
"STUMAX90" powered delta foamy-now under new controls.
The wind has gone, kangaroos are out, great time to fly deltas. Enjoy the great video footage and what a sound, J.
jofro is offline Find More Posts by jofro
Old Nov 08, 2012, 11:23 PM
av8ersteve is offline
Find More Posts by av8ersteve
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
looks great! where's the vid? I wana hear!
av8ersteve is offline Find More Posts by av8ersteve
Old Nov 08, 2012, 11:44 PM
jofro is offline
Joined Jan 2010
Here we go, very gloomy today, flying in the light drizzle, J.
P1050204 (2 min 51 sec)
Old Nov 09, 2012, 11:30 AM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Your fan is vibrating. You may need to loosen all four grub screws on the rotor and re tighten in the order Stu suggests. A Stu fan should not sound like that.
falcon5 is offline Find More Posts by falcon5
Old Nov 11, 2012, 05:58 PM
jofro is offline
Joined Jan 2010
I'm glad you enjoyed watching my video, J.
Old Nov 14, 2012, 07:54 AM
MRGTX is offline
Find More Posts by MRGTX
MRGTX's Avatar
United States, CT
Joined Aug 2005
Whoa, great looking plane. The paint job is super sharp.
Nice work. I will definitely check out the video when I'm not at work.
I think he was trying to be helpful...the RC hobby doesn't necessarily demand tact.
MRGTX is offline Find More Posts by MRGTX
Old Nov 14, 2012, 04:23 PM
jofro is offline
Joined Jan 2010
Thanks for your Compl. When you design and build model that performs as seen in the vid. you don't fiddle, screw or mess around with, just enjoy flying it. Last thing I need is some SA commentary, J.
Old Nov 14, 2012, 08:02 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Actually itís an easy fix, mine was doing the same thing and sounded exactly like yours in the video. I just loosened the four grub screws and re tightened them as explained in the Stumax manual and man it made such a big difference in the smoothness and sound of the fan. Well worth the very little effort IMHO. But hey if your happy with it, no worries.
Old Nov 15, 2012, 07:19 AM
MRGTX is offline
MRGTX's Avatar
United States, CT
Joined Aug 2005
At least you're modest!
But yeah...it's a one of a kind, made by your own hands and it seems to fly extremely well. You should be proud of that.
I have to ask- how did you determine where to place the CG on a scratch-built design like that? It appears to be balanced perfectly.
Old Nov 15, 2012, 05:08 PM
jofro is offline
Joined Jan 2010
Hi, yes it is very rewarding when model performs like that after all the work. With these designes I go back many years starting on tiny 55-64-70mm+units, learning from each. With CoG it's always challenge, you never know till you actually fly it as every model is different. This particular model was only my prototype before I built 25% larger "Wren44G" turbine powered one last year. Unfortunatelly slightly underpowered especially taking off the grass so extreme care must be taken during rotation, Regards Joe. (never mind modesty, I'm more into honesty)
Old Nov 19, 2012, 06:12 PM
jofro is offline
Joined Jan 2010
I'm slightly puzzled why my turbine powered foamy (left) have a tendency to rock its wing tips during flight and identical 25% smaller EDF proto is solid as a rock. I wonder if the 190000+RPM motor torque has anything to do with it. I'm going to cut few inches off the w/tips and fit little winglets to see if it makes any difference before I try to instal stab. gyro, J.
Old Nov 22, 2012, 03:09 AM
jofro is offline
Joined Jan 2010
Oh boy, this SM90 is smooth, bit of aero routine today, John doing great video job, almost no sound of the power unit, see the great footage next.
"WREN44G" powered foamy, after redesigning my Elevons with new more streamline TE, I re-maiden it today and it's a different model, no gyro needed now! J.
dnes (3 min 41 sec)
Old Nov 23, 2012, 09:39 PM
jofro is offline
Joined Jan 2010
Curently on drawing board is my latest design foamy, that will be powered by "PST600R" turbine and this Stumax powered prototype is coming very handy as my new test bed. Cuttig out my wing tips and installing winglets will give me great picture about performance of this new project, J.
Old Nov 25, 2012, 02:17 AM
jofro is offline
Joined Jan 2010
Very interesting, after removal 2/1/2 inches from my wing tips and replacing them with small winglets I have found quite a difference. Quite a dramatic balloning effect, almost needed full down trim to level it out the first flight. Also more responsive controls as the air stream between the fuse and the winglets becomes more direct over the Elevon surface. This was probably also the reason why I had such horrendous maiden with my "Triptych" on which I have installed winglets for the first time. Another good lesson in the pocket, J.
Old Dec 17, 2012, 05:55 PM
jofro is offline
Joined Jan 2010
My latest experiment with this "Stumax" powered prototype is fitting fixed kennards to see how it will affect CofG so it will give me some guide to install kennards on my latest "Touch of magenta" project with rather very long and sleek nose then some of my other designs. They have managed to slow down landings by 70km/h with aded kennards on "TU-144" so it will be interesting to see my results after few test flights, Joe.
Discussion My Depron design with STUMAX90 jofro Foamy EDFs 3 Jan 27, 2016 06:35 PM
Sold Eflite power 15 and Delta V--Stock HABU fnlrun Aircraft - Electric - Jets (FS/W) 4 Aug 26, 2012 10:44 PM
Sold Delta 10" Compound Power Miter Saw Model 36-075 FieldofDreamsFlyer Non R/C Items (FS/W) 0 Jul 15, 2012 02:49 PM
Discussion How to Hand Launch RC Foamie Plane Mustang GWS Me109 Skyfun Delta Beaver TheLeabres Parkflyers 0 Jun 10, 2012 06:03 AM
Ryobi Powered Foamie Delta CrazyHerb Giant Scale Airplanes 3 Feb 11, 2005 10:50 AM
