Old Aug 01, 2012, 09:38 PM
Nightstone is offline
Find More Posts by Nightstone
20 years on the Internet
Nightstone's Avatar
Joined May 2012
Trim Question
In alot of the build threads you have folks telling you to add different amounts of trim to an aircraft prior to first flight. Say 1/8 R Rudder. 1/4 Up Elevator etc. How do these fractions correspond to the controller or airplane? Do you set the trim on the controller bar up 1/4 of the way or do you adjust the flight surface on the plane up by that much in inches.
Nightstone
Nightstone is offline Find More Posts by Nightstone
Old Aug 02, 2012, 06:05 AM
RWData is offline
Find More Posts by RWData
PowerTower
RWData's Avatar
United Kingdom, England, Bristol
Joined Aug 2009
That's a good question Nightstone, I would take it as a measurement on a given surface extreme. So 1/4 UP elevator sounds like 1/4" or 6mm. Mind you that sounds like a huge amount ! My Funbat is flat elevator trimmed, it only moves 8mm total up or down and is manic ! Someone needs to clarify I think, maybe it's 4 clicks up-trim
RWData is offline Find More Posts by RWData
Old Aug 02, 2012, 07:13 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
For the maiden flight, all the surfaces should be set to zero trim . You never know how much trim in either direction you may need. Even two identical planes may need different trim clicks. CG, slight warps make all the difference.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Aug 02, 2012, 08:18 AM
kalnaren is offline
Find More Posts by kalnaren
Wasaga Beach, Ontario
Joined Aug 2007
Like Gord said, all control surfaces should not be trimmed for the first flight. Ideally you want the plane to fly straight and level at 65%-75% throttle, so adjust the in-flight trims likewise. Land and adjust the clevises (or similar depending on what you're plane is equipped with) to these new points.
You'll always need a bit of TX trim adjustment in every flight, and every flight will be a little bit different. If you find you consistently have a trim somewhere (like aileron trim constantly at 20% for example) then adjust the clevis or servo neutral point if you have a computer radio.
kalnaren is offline Find More Posts by kalnaren
Old Aug 02, 2012, 08:55 AM
dedStik is offline
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
I think op is confusing surface deflection with trim. Trim is measured in clicks, or sub trim on a transmitter. Deflection is usually measured with a protractor or a surface deflection measuring tool.
http://www.rcgroups.com/forums/showthread.php?t=346379
http://www.rcuniverse.com/forum/m_63.../tm.htm#631506
dedStik is offline Find More Posts by dedStik
Old Aug 02, 2012, 10:12 AM
RWData is offline
PowerTower
RWData's Avatar
Joined Aug 2009
dedStik, so what's 1/8 or 1/4 ? Now you have me wondering too !
I can say most of my models fly with little or no incidence even on elevator, so 1/4 inch would be massive ! One of my models, max deflection is only 5/16" and that's flying like a nutter
Old Aug 02, 2012, 10:17 AM
dedStik is offline
dedStik's Avatar
Joined Feb 2012
That's what I'm trying to figure out. I don't know anyone that flies that would fly a plane that you had to have an 1/8th or 1/4 inch surface to control it. Imagine the lack of control in the other direction.
Old Aug 02, 2012, 10:27 AM
Nightstone's Avatar
Joined May 2012
So when I see a design where the Designer has added in 1/8 up elevator. That is 1/8 of the distance the elevator will travel ( Deflection ). Deflection is measured in degrees.
This all came up when I built a snowball. Its a nutball with an elevated motor mount and skids. I had a really bad time getting it to fly. It would take off, flip and crash. Thinking it was the CG I adjusted it. Same results. After 3 crashes I decided to launch it straight up. I managed to get it high enough to where I quickly realized what the issue was. I frantically trimmed it and now it fly's great.
That got me thinking about those fractions I see in the build threads. 1/4, 1/8 etc.
Nightstone
Old Aug 02, 2012, 10:34 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
That 1/8 or 1/4 in. is measured from the furthest distance of the trailing edge of the surface to the hinge line.
Gord.
Old Aug 02, 2012, 10:58 AM
Nightstone's Avatar
Joined May 2012
Gord.
Thanks Gord
So that measurement would be 1/8 or 1/4 up in inches. Not a fractional value of the deflection. Right? This would make alot more sense than 1/4 of the travel.
Nightstone
Old Aug 02, 2012, 11:01 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
That's right.
Gord.
Old Aug 02, 2012, 11:03 AM
RWData is offline
PowerTower
RWData's Avatar
Joined Aug 2009
By jove I think I have it (the Eureka moment !!!).
These measurements must be the amount of throws at trailing surface edge, so 1/4 will be 1/4" deflection from centre or flat. It's the suggested deflection amount (up or down) for elevator or aileron, well or rudder for that matter when you move full stick in given direction. With control surfaces being different widths, the normal 'measurement' is not in degrees of movement because if the surface width is 2" at 30deg's, that would be a huge amount more than same angle with a 1" surface. So it's the recommended setup deflections, not how much incidence to build-in before you start (this is almost sounding like 'Call-My- Bluff' now).
Old Aug 02, 2012, 11:17 AM
Nightstone's Avatar
Joined May 2012
Whoo Hoo... This will make some of these first flights on scratch builds alot easier. Thanks Alot.
Nightstone
Old Aug 02, 2012, 03:51 PM
helifreak1 is offline
Find More Posts by helifreak1
Joined Jan 2012
re;trim
To start out on a new plane trim setting this is what i do(to be safe).On the TX (if programmable) set all trims to the middle except for the throttle.Set the throttle to little under half way. Set the D/R or the throws to 50%.That will give you just enough to get use to the new feel.As you feel more comfortable with the flying increase the D/R
Almost forgot set the expo to about +40
helifreak1 is offline Find More Posts by helifreak1
Old Aug 02, 2012, 04:13 PM
RWData is offline
PowerTower
RWData's Avatar
Joined Aug 2009
Heli... Similar for me, except I dial in 50% expo and no D/R (in case my model needs every bit of help not to nose-in). Most of the time I then have a ground adjust D/R after first flight, since it almost always has more than enough throws. More important I find for elevator. My first elevon model would not have had a second flight if I hadn't had full elevator available.
Discussion JR 9503 throttle trim question RC Erik Radios 12 Jul 28, 2012 02:39 PM
Question Trimming question R0yalty Beginner Training Area (Aircraft-Electric) 82 Jun 27, 2012 07:53 PM
Question Cannot Trim Stable Mode (Also GPS question) brettwal Multirotor Talk 2 Jun 18, 2012 08:36 PM
Help! Trimming question Bad Dog Electric Plane Talk 8 Jun 15, 2012 05:17 PM
Discussion Trimming question dbergmann Electric Plane Talk 7 Apr 29, 2012 12:00 AM
