Old Nov 15, 2003, 07:38 PM
mxclouti is offline
Find More Posts by mxclouti
Joined May 2003
PCB - LIPO Pack building
Should I use PCB to build my LIPO packs? Pros and cons?
mxclouti is offline Find More Posts by mxclouti
Old Nov 15, 2003, 07:56 PM
uglystick is offline
Find More Posts by uglystick
Arnold , Maryland, United States
Joined Nov 2002
Yes. Then, the pc bd. needs to be secured to the lipo packaging.
uglystick is offline Find More Posts by uglystick
Old Nov 16, 2003, 01:16 AM
gtstubbs is offline
Find More Posts by gtstubbs
gtstubbs's Avatar
Perth Westen Australia
Joined Jun 2003
Maxclouti:
If you have not done this before take care, read all the info re making packs and LiPo’s generally, consider, the electrical, mechanical and failure issues before you proceed.
I failed to consider the mechanical and failure issues and when an individual cell failed paid the price of the whole pack instead of just 1 cell, as a result.
Have a look at this thread http://www.rcgroups.com/forums/showt...0&pagenumber=1
Do not use the PCBs that you can buy with ETec cells unless you
a. are prepared to solder then solidly fix them in place either inside the heatshrink or with glue etc since if the PCB can move the LiPo tabs will fracture in due course and you will:
b probably loose all the cells because once they are soldered in place it is hard to unsolder them without loosing tabs and hence cells
The PCB epoxied to the cell later in the thread seems to be a better bet. If a cell goes you will probably be able to salvage the others and maybe add a new cell to the pack to reconstitute it. You should not have too many problems with tab fractures and should be able to provide strain relief without to many problems.
See the FMA Direct website and the LiPo Manuals
https://www.fmadirect.com/support_docs/item_1080.pdf
https://www.fmadirect.com/support_docs/item_1115.pdf
for some useful info.
gtstubbs is offline Find More Posts by gtstubbs
Idea Building the perfect LiPo pack. <- Post ideas here! KreAture Batteries and Chargers 76 Nov 23, 2004 02:58 PM
Lipo Pack Building? Any "How To's?" Tram Batteries and Chargers 12 Sep 27, 2004 03:06 PM
Any LiPo pack building advice? Bomberguy Batteries and Chargers 2 Jan 12, 2004 10:17 PM
How are you building a 4sXp LiPo pack? Ben74 Batteries and Chargers 1 Oct 25, 2003 05:20 PM
Battery pack building questions... Sal C Power Systems 9 Dec 24, 2001 07:43 AM
