Old Feb 28, 2012, 11:31 AM
jb_bak is offline
Find More Posts by jb_bak
Joined Oct 2011
Is this antenna setup wrong?
I'm getting real bad video reception with my best offer buy fox 700mw video system. Only about 100 feet before I lose everything. I have a turnigy 2.4ghz with frsky. Maybe my antenna setup is bad? Maybe I'm running the wrong channel? I did the testing in an urban area.
I am running a 1.2GHz High Gain Yagi Antenna, +12dBi on the Rx end.
http://www.dpcav.com/xcart/product.p...cat=272&page=1
and a 1.2GHz Antenna, "Big Stick" 7dBi on the Tx.
and a Low Pass Antenna Filter for 1.2GHz - 1.3GHz TX
jb_bak is offline Find More Posts by jb_bak
Old Feb 28, 2012, 11:59 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yes, those are the wrong antennas. That high gain omni has only a 26 degree vertical beamwidth so you'll fly out of its beam as soon as the plane climbs or banks. Use a 2-3dB omni on the tx side. The yagi is high enough gain you'd need to keep it pointed at the plane at all times. It's good if you want to fly miles away but not useful for sport flying.
8dB patch is about the highest you want to go for sport flying and a good set of omnis at both ends will get you a couple miles with that vid tx.
ian
Daemon is online now Find More Posts by Daemon
Old Feb 28, 2012, 02:22 PM
Blueshy is offline
Find More Posts by Blueshy
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
Originally Posted by jb_bak View Post
I'm getting real bad video reception with my best offer buy fox 700mw video system. Maybe my antenna setup is bad?
Your setup shows a fundamental misunderstanding of antenna gain and radiation patterns.
Try watching this:
Antennas 101 - Polarization, Diversity & Gain Patterns (27 min 56 sec)
Blues
Blueshy is offline Find More Posts by Blueshy
Old Feb 29, 2012, 01:00 PM
jb_bak is offline
Joined Oct 2011
Ok got it! Thanks. Can anyone suggest a good set of omnis? Im still a bit confused why my big stick omni is bad for the tx side. My eagle ground station has tracking, so maybe i can find a good use for the yagi down the road.
Old Feb 29, 2012, 02:28 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Then apparently you didn't really get it.
"gain" means you take away some of the radiation in one or more directions and increase it
in one or more other directions. A high gain patch antenna decreases radiation from sides
and behind and focuses it in a narrow beam out front. A high gain omni (your Tx antenna)
decreases radiation from above and below, and focuses it in a narrow beam to all sides.
A 7dB omni has a 26 degree beam height which means if the plane flies level but up high,
then its beam is not pointed at your Rx. If the plane is far to the side when it banks, then the narrow beam
is not pointed at your Rx. The Tx antenna should be as low a gain as possible.. typically 2dB
so that the radiation goes in *almost* all directions equally. There will always be nulls
off the ends of the antenna (holes in the donut), but the fatter the donut shape of the radiation
pattern, the better.
ian
Discussion why my antenna have wrong length modelerchina FPV Talk 5 Feb 26, 2012 10:44 AM
Question Will this antenna repair cause interference?!?!?!? RC_Bob Radios 3 Feb 23, 2012 06:58 AM
Discussion redid Tail setup. Setup wrong . flies great. is this correct ? sajeev Mini Helis 11 Dec 24, 2007 08:44 AM
Discussion Twin brushless - Whats wrong with this setup? spirit100 Power Systems 11 Mar 25, 2007 03:04 PM
Help! Jeti45 overheating, Whats wrong with this setup? kawika1kalina Power Systems 11 Feb 03, 2007 12:27 PM
