Old Feb 22, 2012, 10:13 PM
RC_Bob is offline
Find More Posts by RC_Bob
United States, CA, Mountain View
Joined Jun 2010
Question
Will this antenna repair cause interference?!?!?!?
So my dx6i antenna joint finally gave way (gently, so no hard twists in the antenna wire itself). The little plastic buds that pop in the holes and act as joints finally broke so it's basically a hinge w/out something to hold it together. So I got a thick insulated wire that only had like 4-5 wire strands inside and it fit well and did the trick! even angled the antenna a few times an it holds up.
ONLY concern though is that wouldthe new wire cause any sort of interference since it's right next to the antenna? IIF NOT, u think it would be safe to use a small paperclip wire instead?
RC_Bob is offline Find More Posts by RC_Bob
Old Feb 22, 2012, 11:21 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
Should be fine, the part that radiates is much farther up the plastic.
village_idiot is offline Find More Posts by village_idiot
Old Feb 22, 2012, 11:28 PM
RC_Bob is offline
Joined Jun 2010
Oh I see, k thx!!!
Old Feb 23, 2012, 05:58 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
I seen others use small tooth pick. Using the tooth pick still allow for breakage if it should happen again where as using a hard or solid (wire) would or may if hit or damaged again to break somewhere else.
But like mentioned above the actual antenna part is much higher in the rubber ducky.
freechip is offline Find More Posts by freechip
Discussion Will this receiver placement cause interference? RC_Bob Radios 5 May 11, 2011 05:18 PM
Discussion Will rare earth magnets cause Rx interference?? flyonline Slope 5 Mar 23, 2009 12:42 AM
If I make a brass plate for my on/off switch will it cause interference? steve crewdog Radios 1 Jun 06, 2005 10:00 PM
