Old Mar 21, 2012, 11:36 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
What are you using to measure current?
And how many rpm is it pulling.
jackosmeister is online now Find More Posts by jackosmeister
Old Mar 21, 2012, 11:37 PM
stanordave is offline
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
Just tried the Ammo on a tired (3.4V under load) 3 cell and got about 30A w/a 4.1 so it should do fine tomorrow...ticked about the ARC. Just got it back from lightflight and it was unused till today..
(used a Wattmeter)
stanordave is offline Find More Posts by stanordave
Old Mar 21, 2012, 11:41 PM
Auckland NZ
Joined Aug 2007
What sort of wattmeter.......
Are you sure its a -2 (3750) and not a 2.5 (2800kV). Do a Kv check.
Current is irrelevant.
RPM determines how fast you go......
Old Mar 22, 2012, 02:31 AM
batballs is offline
Find More Posts by batballs
Blue Sky Mining
batballs's Avatar
Australia, VIC, Ballarat
Joined Feb 2009
... current determines for how long ...
batballs is offline Find More Posts by batballs
Old Mar 22, 2012, 10:03 AM
stanordave's Avatar
Joined Jan 2006
Its labeled a -2 but does act likes it the other wind. One of the 1st things I did was look at the other motor specs to see if it was an obvious mislabel. Maybe someday I'll figure out how to set the drill press up to measure the Kv but for now I'll let lightflight handle the Kv check....I'm just trying to figure out how to cram a large ESC in to get it up to 800W and still have a decent sized battery..
Old Mar 22, 2012, 10:28 AM
Jwmflying14 is offline
Find More Posts by Jwmflying14
United States, CA, Lompoc
Joined Nov 2010
That's where this dual aileron set up has multiple advantsges. Look at the space saved!
Jwmflying14 is offline Find More Posts by Jwmflying14
Old Mar 22, 2012, 04:05 PM
KRProton is online now
Find More Posts by KRProton
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Not sure what other wind you are referring to, but the ARC 28-37-2.5 is good on a 4.75 x 4.75 - another ideal choice for the Rifle - flown it with that motor many times. Does 21,000rpm, 28A, 290W static (19.4A in flight), but that's on a 1500mAh 25C battey (3S of course!) (before I started flying our ElectriFly 1800mAh battery).
Not sure how to use a drill press to check the kV. All you need to do is somehow get the unloaded rpm (and know the Voltage with a Watt meter). You can simply cut a round flywheel from white plastic or cardboard or something, then mark two black lines on it, spin it up, then get a reading with our tach.
Tim
KRProton is online now Find More Posts by KRProton
Old Mar 22, 2012, 05:11 PM
stanordave's Avatar
Joined Jan 2006
Well it flew fine w/the Ammo today. Launching it has gotten waaaay easier. Either my arm has gotten stronger or I have a better setup than earlier! Maybe its just better technique. Hardly loses any altitude on the throw. The dual aileron setup may come in handy when I start using 4 cells to keep the CG close (if a decent size 4s fits!)
for now, I'll go fly while ya'll go work
cheers,
Old Mar 22, 2012, 10:08 PM
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Nice Mike.
What Ammo are you running - the 28-35-3900?
I've found that my launches are better than ever this year too. I have to remember to look at it when I throw it. This helps me keep the wings level.
Tim
Old Mar 23, 2012, 12:14 AM
Joined Nov 2010
Not sure yet but i might be selling mine. Need to earn money for a much larger TRUE F5D
Old Mar 23, 2012, 12:44 AM
stanordave's Avatar
Joined Jan 2006
Tim, the Ammo 24-45-3790
Old Mar 24, 2012, 05:12 AM
amagad is offline
Find More Posts by amagad
Joined Mar 2012
New rifle owner
I purchased the rifle today and I'm excited for the build.  This is what I have thus far, please advise if I'm on the right track to a good/fast flyer.
Motor: ARC 28-37-2
Prop: 4.5x4.1
ESC: Dynam Detrum 40A ESC(3A BEC) from hobby partz
Battery: HYPERION G3 VX 1800 MAH 3S 11.1V 35C/65C
Spinner: MP Jet Precision Spinner 30/3.2mm
Servos: tbd
Receiver: tbd but probably spektrum 6210
amagad is offline Find More Posts by amagad
Old Mar 24, 2012, 07:19 PM
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Congratulations and thanks amagad.
I've flown the Rifle dozens of times on the ARC 28-37-2 with 4.5 x 4.1. The only thing I am compelled to remind you of it's over the 300W limit specified in the manual. However, as I said, I have dozens of flights on a stock airframe Rifle with this setup and am also flying two other Rifles with the 28-35-3900 Ammo at around the same watts as your ARC and going fine. You may want to start out on low rates.
Visit my blog for ways to make a few simple improvements.
Keep us informed of how it is going and post some images.
Tim
Old Mar 25, 2012, 12:33 AM
rimripper is offline
Find More Posts by rimripper
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
cheers,
I run a 4s 1000 50c in my rifle,and I have not removed the inside wood support rib.
rimripper is offline Find More Posts by rimripper
Old Mar 25, 2012, 04:08 AM
Arkx400 is offline
Find More Posts by Arkx400
Sydney Australia
Joined Aug 2009
3 more flights today. I really love this little plane. I tried using the landing method that a number of guys mentioned on this thread by flaring gentle until they run out of up elevator but the approach i use now is to slow it as much as possible but then fly it onto the ground as smoothly as possible keeping the wings level. I have installed the landing skids on each wing tip to help stop catching a wing tip.
Arkx400 is offline Find More Posts by Arkx400
Sold Lr-1 Pylon Racer New in the box thunderfrog Aircraft - Electric - Airplanes (FS/W) 6 Feb 22, 2010 09:53 PM
Discussion LR-1 Pylon racer New in the box thunderfrog Other Websites 0 Feb 09, 2010 08:26 PM
Sold CSD Twister Pylon racer kit - new in box SPasierb Aircraft - Electric - Airplanes (FS/W) 2 Nov 16, 2009 12:11 AM
FS: Flea sport / pylon racer - RTF kyril Aircraft - Electric - Airplanes (FS/W) 4 Mar 01, 2004 03:29 PM
