Old May 04, 2003, 11:01 AM
flipnidaho is offline
Find More Posts by flipnidaho
Boise
Joined Sep 2002
Unequal lead lengths from S400 motor to ESC... is this a problem...
because of CG issues (long story), I've had to cut the motor (long can 400) to ESC leads in different lengths. Basically the Negative Motor to ESC Lead is about 1 inch and the Positive is around 2 inches. Is this a problem? I'm mostly concerned if this robs any power to the motor or damage my ESC (GWS ICS400).
The motor seems to run fine although I get an occassional glitch but I think that's more from the servo extensions than the motor to esc leads.
flipnidaho is offline Find More Posts by flipnidaho
Old May 04, 2003, 11:28 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
That will not cause any problems. If anything leads that short will help both power and preventing interference. The difference in lengths has no effect.
Steve
steve lewin is offline Find More Posts by steve lewin
Old May 04, 2003, 11:30 AM
Boise
Joined Sep 2002
Excellent...
Thank you very much!!!
Question Cut plug from brushless motor to ESC? yaremchl Power Systems 11 Aug 04, 2006 11:08 AM
Help with rf/video interference from electric motor/esc dmoran Aerial Photography 0 Jun 21, 2003 06:07 PM
Have got this motor/esc combo, what should I build for it? Erik Johansson Electric Plane Talk 2 Dec 09, 2002 10:43 AM
FS: $75 for 2 sets of Motor-ESC combos from Voyager Helis TMP00283 Aircraft - Electric - Airplanes (FS/W) 0 Nov 15, 2002 02:26 PM
JETI ESC questions; motor cut-off problem jbrundt Electric Plane Talk 12 Apr 25, 2001 01:29 AM
