Old Sep 01, 2009, 12:13 AM
trevjonez is offline
Find More Posts by trevjonez
United States, UT, St George
Joined Jun 2009
paint jobs!
how much weight do you guys normally put on when you paint your foamies?
i just sprayed wbpu with some baby powder mixed in onto my f-18 and it added 1.9 oz to the weight (from 11 up to 12.9 that is without motor prop and battery)
it was a hefty coat of wbpu and it will only need the one as it is nice and smooth after a bit of sponge sanding. so im hoping to shed a bit of weight that way.
but what do you guys normally average on a paint job?
if you can break it down that would be a plus too.
like wieght in wbpu
then the weight of the paint
and if you do it the weight of the top coat.
would be much apreciated so i can get an idea of what i should be at. thanks aton
trevjonez is offline Find More Posts by trevjonez
Old Sep 01, 2009, 06:06 AM
windbender is offline
Find More Posts by windbender
Quebec, Canada
Joined Aug 2006
Hi trev,
i've found that it is the wbpu that adds the weight. paint added with an airbrush can be as little as .1 oz, but then again that depends on the coverage.because of this my paint scheme has gone from extravagant to functional- wing tips and vstab for visibility. If you must go the direction of scale, then you may need to plan for this by having the appropriate power system(watts / lb). I think your number is typical so far, though i've been able to add more than 4 oz to a plane with paint- needless to say it did not fly very well. Sorry that i do not have empirical data, since the paint weight of the paint would have to be given as a function of the surface area of the plane, and usually only the wing area is taken.So,the only useful advice i can give would be to use the paint sparingly, a plane that's too heavy for its power system is not fun.
Wb
windbender is offline Find More Posts by windbender
Old Sep 01, 2009, 06:12 AM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
Paper coat ( partially doubled ) 30 ..35 gram including color which is about 6 to 7 % from AUW)
Harpye is offline Find More Posts by Harpye
Old Sep 01, 2009, 09:20 AM
DRITCH is offline
Find More Posts by DRITCH
DRITCH's Avatar
ST.LOUIS
Joined Aug 2006
I watch closely how many times I fill a 10ml cup. Large planes might get 1/2 oz. Small one's get 1/10 to 1/3 oz.
DRITCH is offline Find More Posts by DRITCH
Old Sep 01, 2009, 10:16 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
We always try to add as little weight as possible with paint ... Shaker can spit bombs turned out to apply TOO MUCH paint ... brushing thin looked like ... airbrush was the way to go adding <1/2 oz. on 36" sized plane ... Sharpie is still lighter , just not as pretty ...
WBPU ... why ???
gpw is offline Find More Posts by gpw
Old Sep 01, 2009, 10:34 AM
62pilot is offline
Find More Posts by 62pilot
Don't look at me like that....
62pilot's Avatar
United States, AR, Piggott
Joined Aug 2005
I like the H2o brand of latex bombs. If you spray two to three very lite coats and let them dry in between. Comes out very even , smooth and very lite wt.
62pilot is offline Find More Posts by 62pilot
Old Sep 01, 2009, 12:06 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
I use Sharpie markers.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Sep 04, 2009, 10:15 AM
KFC is offline
KFC
Find More Posts by KFC
KFC
Blue Foam Master!!!
KFC's Avatar
United States, KY, Hanson
Joined May 2007
I have been using acrylic for a while now, and I think it is probably the best option for foam. I would estimate that it adds less than 1/2 oz. to an average plane. I use an airbrush to apply it.
KFC is offline Find More Posts by KFC
Old Sep 04, 2009, 11:10 AM
Joined Jun 2009
anybody use water based poly urethane (WBPU)? wehn i sprayed it on my f-18 it added almost 2 ounces to the over all weight of the plane. and it seems like alot of weight for as poor of coverage as it gets.
Old Sep 04, 2009, 11:31 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
WBPU is for Furniture !!!! Not planes !!!
Old Sep 04, 2009, 07:30 PM
Dreamcatcher is offline
Find More Posts by Dreamcatcher
Warbirds Lover
Dreamcatcher's Avatar
South of France
I use acrylic paints on all my foamies.
Generaly i dilute the paint with 50% water.
For a big area i use a small Roll painter and for details or small area i use a spraygun or paintbrush.
On my Alphajet, Cap 232 and F-14, the weight increased of about 10 to 15 g.
Dreamcatcher is offline Find More Posts by Dreamcatcher
Old Sep 05, 2009, 01:40 AM
Joined Jun 2009
yea well i ended up heavyer than i would have liked on my f-18 rtf is 20.4oz that is with a turnigy 1600mah battery. so paint, glass and decals ended up at about 2.4 oz not too bad for how much area there was i guess but still with it was 18 or under.... trying a new glue on the 2nd jetset f-22 im building going to glass and paint it but not put on the thrust vectoring as i did on this one and felt i didn't really care for it. (im still new to this stuff).
i will try a roller as dreamcatcher mentioned that sounds like a really good idea
Old Sep 05, 2009, 08:58 AM
electriceye is offline
Find More Posts by electriceye
Kiss the Sky
electriceye's Avatar
Dorking, Surrey, UK
Joined Jul 2006
But if you are going for a scale look, it is good stuff, just need to make sure you cut it back as much as possible to find the right balance between smoothness/foam protection so you can use just about any type of paint but without adding too much weight. I guess its 'horses for courses' ? No point WBP'ing a 3D or profile type model (although I did WBPU a printed profile warbird to seal the printed covering-it flew fine), but definately a must if you are building a scale warbird and you want a scale finish, imho?
electriceye is offline Find More Posts by electriceye
Old Sep 05, 2009, 09:03 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Eeye, Scale .... well spotted !!! But I would assume (?) that there are weight concessions made for the "appearance"... Our "sport" aircraft need all the Lightness possible for the silly things we expect the plane to do ....hahahahaha
Wild paint jobs on composites Hoot Thermal 12 Jun 19, 2003 09:32 PM
Cool paint jobs and/or modifications Zephyr Foamies (Kits) 53 Sep 26, 2002 08:37 AM
show your terry colors (terry paint jobs) terrible1 Foamies (Kits) 3 Sep 14, 2002 12:06 AM
Multiplex Cargo Paint Jobs and Coverings Wingnut 3 Foamies (Kits) 10 Mar 26, 2002 04:20 PM
show me your cool paint jobs shadetreeflyer Foamies (Kits) 8 Jan 21, 2002 01:39 AM
