Old Jul 20, 2009, 10:47 PM
airman1958 is offline
Find More Posts by airman1958
United States, OK, Ardmore
Joined Sep 2007
Making a plane larger or smaller
If I wanter to make a airplane 25%,50% and 75% larger how would I do it.
Same thing for making one smaller.
I want to do the spadet LC-40 75% or even 50% smaller out of blue core FFF.
Thanks in advance.
Kevin
airman1958 is offline Find More Posts by airman1958
Old Jul 20, 2009, 11:36 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
First step is scaling the plans...
Take each meaurement and multiply by the scale factor.
(50% the scale factor is .5)
Second is determing the diffeences in structural needs due to the scale change.
EG if you were reducing the Spadet by to 75%, you would change the wing skins to 2 mm coro and would only reduce the spar height but not thickness. The fuselage plan would have to be in front of me for me to evaluate what other changes to make... the tailplanes would still be 4 mm coro.
This would be a .25 to .32 glow power (or equivilent electric power) model when done.
The changes being made would also need to take into consideration what power system you are putting in.
If you know the desired power system then you could choose the scale factor to fit it.... designing the airplane around the engine/motor.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Jul 21, 2009, 11:13 AM
Vienna3109 is offline
Find More Posts by Vienna3109
Fly Inverted Hold Steady
Vienna3109's Avatar
Joined Jul 2009
I'm a beginner and would like to built a few planes, is there any plans here I could download, to get me started, Jeff
Vienna3109 is offline Find More Posts by Vienna3109
Old Jul 22, 2009, 04:24 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
GOOGLE "model airplane plans"
There are a ton of sources there.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
.12 or smaller plane Dorkhedeos Fuel Plane Talk 14 May 13, 2005 07:16 PM
Props... larger or smaller? naX Beginner Training Area (Aircraft-Electric) 14 Jul 20, 2004 04:30 AM
Large dog comes within inches of making new plane a chew toy tic Electric Plane Talk 18 Jan 31, 2002 12:03 AM
making foamboard plane TeddyTyler Foamies (Kits) 6 Oct 01, 2001 11:50 AM
