Old Jan 19, 2013, 03:18 PM
Brawley, CA. USA
Joined May 2000
Binding question
I am going to bind my DX8 with an AR600 using a four cell Rx battery instead of hooking up the ESC. I only have the evelator and ailerons connected for now. It would be a PITA to try and connect everything up now. Is there any reason to connect everything up now.
Can you bind without anything but the battery being hooked up?
Thanks in advance,
Bill
Wild Bill is offline Find More Posts by Wild Bill
Old Jan 19, 2013, 03:31 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Yes, you'll be fine.
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Jan 19, 2013, 04:20 PM
Joined Feb 2008
There's a picture of binding in the DX8 manual with nothing but a battery and a bind plug hooked up so, yes, that works fine. I have done this for years.
Make sure the RX pack is well-charged. Binding takes a bit of current to write to the nonvolatile memory.
Dave H. is offline Find More Posts by Dave H.
Old Jan 19, 2013, 07:27 PM
Brawley, CA. USA
Joined May 2000
Thank you both. It worked!!!!!
Bill
Old Jan 20, 2013, 06:23 AM
Buschbarber's Avatar
United States, NY, Rochester
Joined Apr 2004
When you Bind, you set the Failsafe Conditions. If you change any Servo Directions or enable Mixing, etc., you need to Bind again, so be sure to Bind again after the aircraft is set up.
Buschbarber is offline Find More Posts by Buschbarber
Old Jan 20, 2013, 12:06 PM
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
True for most radios, so don't forget to have the throttle in your chosen position for failsafe. I don't think you'd want to set the failsafe to half throttle or higher.
Wintr is online now Find More Posts by Wintr
Discussion Mcpx v2 binded with dx6i mitch_man_22 Electric Heli Talk 4 Mar 18, 2013 02:27 AM
Discussion 3gx binding with spectrum ar6115e wont bind siandhell Electric Heli Talk 13 Jan 22, 2013 10:28 AM
Discussion Esky Big Lama will not bind to radio shahram72 Coaxial Helicopters 4 Jan 18, 2013 04:45 PM
Discussion To Bind or not to Bind...thats the question! Dr. Evil Electric Heli Talk 2 Feb 07, 2011 05:21 PM
