Old Nov 28, 2012, 11:00 PM
Nick
Nicksbbq's Avatar
United States, AL, Hoover
Joined May 2012
Question
Where To Buy Bulk Throttle Cable
My roll of throttle cable I bought from Hobby Lobby many years ago is all used up.
I cant find a supplier for bulk rolls. Anybody know of one?
Nick
Nicksbbq is offline Find More Posts by Nicksbbq
Old Nov 29, 2012, 09:43 AM
United States, KY, Taylorsville
Joined Mar 2010
Small Parts, Inc. might have something to use. Bicycle gear control (not brake cable) is ~1mm wide. Campagnolo brand is the best (but overkill for this app)!
ARUP is offline Find More Posts by ARUP
Old Nov 29, 2012, 12:05 PM
The Prez....... again
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Nick
What were/are you using for an outer sheath for the cable?
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Nov 29, 2012, 01:18 PM
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
I get a lot of bulk R/C goodies from (shhhh don't tell anyone) McMasterCarr. You have to look around as the stuff isn't labeled for our use For example for the pushrod in a sleeve I think I got braided cable & food grade ridged tubing to make my own "kit". This was YEARS ago. I've used a ton of it, and still have a bunch left. I think 25' of the cable was something like $5. I also have smaller stuff I use for pull. Also got smaller food grade tubing (food grade seems slippery than the non-food grade stuff we get at work although it is larger so I can't say if that's it) to use as a sheath for the pull-pull cables.
You usually have to buy in bulk, bulk, but it is still WAY cheaper than elsewhere. For example I needed some wire loom a while back. I got a 25' spool for about the same price as a few foot at Lowes/Home depot. I used what I needed, sold some to guys at the field for cheap (and made enough to cover the cost of the spool) and still have a bunch left over.
We have a physical catalog at work and it is LOT easier to look for stuff in there than online IMO as you can browse to stumble across stuff you never would have thought of. Looking through it you will think of 1001 R/C uses for the stuff in there.
EDIT:
I did a really quick search and found this:
sheathing... TONS to choose from... this should get you started: http://www.mcmaster.com/#standard-pl...tubing/=kdkwo2
Cable...Just a quick sample..... http://www.mcmaster.com/#standard-wire-rope/=kdkxwv
rcav8r2 is offline Find More Posts by rcav8r2
Old Nov 29, 2012, 01:27 PM
rcav8r2's Avatar
Joined Sep 2001
Ken
I believe the OP had a kit that Hobby Lobby used to sell. The kit I had contained about 10 foot each of:
Braided cable
Sheathing for the cable
tubing like outer Nyrod, but flexible enough to roll in a coil.
I went through the braided cable and sheathing, but still have the roll of tubing. Never really found a use for it.
Old Nov 29, 2012, 04:18 PM
kenh3497's Avatar
Joined Jul 2011
EDIT:
Thanks for the links. I always forget about McCarr I/v found just what I need.
Ken
Old Nov 29, 2012, 11:10 PM
Nick
Nicksbbq's Avatar
Joined May 2012
Thanks They have what I need also.
Nck
Help! Where can I buy a Syma s107g charging cable? Ifly3Dallday Coaxial Helicopters 5 Jul 12, 2012 06:15 PM
Question Where to buy ImmecrsionRC vTX cables ? sharonx FPV Talk 2 Mar 27, 2012 02:04 PM
Discussion Where to buy Balance Cables? TheTick Batteries and Chargers 0 Mar 08, 2012 11:15 PM
Where to buy Music wire in bulk? Mike Hall Electric Plane Talk 12 Sep 23, 2003 10:18 PM
Where can i buy Gunther props in bulk? JStory Electric Plane Talk 3 Jun 17, 2002 07:26 AM
