Old Nov 17, 2012, 05:23 PM
Adam Stallcup
Forsyth Mo
Help!
dx7 flaps set up
I am putting together a senior telemaster plus and I am setting up the flaps. I Want to use 60% epa up and down both, I am mixing it on program 5 so that if I trim the flap, the other servo gets trimmed as well. I am mixing the gear channel to aux 1. Aux 1 works just fine for flaps with the 60%EPA, but the gear channel is still moving 100% each way. I went in and turned the EPA on the Gear channel to 0% up and 0% down to kill the gear, but cant figure this out.
So I guess the question is, how do you mix two channels together such that the slave channel keeps the Master channels EPA settings?
If you can offer some help, that would be great!!
adam
chyorn is offline Find More Posts by chyorn
Old Nov 17, 2012, 11:03 PM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Short answer - don't use pmixes to do this
Turn on "Flaperon" mode in the wing type menu and use the Flap System menu to make adjustments.
edit - I see - you want separate flaps, not flaperons
Ignore that advice
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Nov 18, 2012, 12:52 AM
St. Louis
Foambird's Avatar
USA, MO, Ballwin
Joined Mar 2010
The Flap to Elevator mix is already there on the Flap channel and does not require an external mix.
Foambird is offline Find More Posts by Foambird
Discussion Flaps! how to set them up on my DX6i madon37s Radios 16 Aug 05, 2012 04:32 PM
Discussion What is the best eay to set up landing flaps? micronracer Hitec/Multiplex USA 4 Apr 30, 2012 09:05 PM
Discussion What is the best way to set up landing flaps? micronracer Hitec/Multiplex USA 3 Apr 28, 2012 04:32 PM
Discussion how to set up flaps on 9CAF? Canada Goose Radios 0 Mar 30, 2012 10:27 AM
Help! GY401 SET-UP - DX7 - tail set up... help :( d1cky_kds Electric Heli Talk 16 Jun 27, 2011 07:10 PM
