Old Oct 13, 2012, 09:58 PM
some what irregular
dostacos's Avatar
Diamond Bar, California
Joined Feb 2004
Help!
need stuff for steam engines
I found an oiler that needs a T fitting in 1/4 40 thread. THIS I have found and ordered, but I want to hook it up with silicone tubing so I need a nipple that is 1/4 40 thread on one end and the hose fitting on the other end any one have a source?
dostacos is offline Find More Posts by dostacos
Old Oct 15, 2012, 08:10 PM
Joined Feb 2006
I got mine at City of Industry Home Depot.
Old Time flyer is offline Find More Posts by Old Time flyer
Old Oct 15, 2012, 08:37 PM
some what irregular
dostacos's Avatar
Joined Feb 2004
WOW did not know they had stuff that small, thanks, will check it out tomorrow
Dan
Old Oct 16, 2012, 02:28 AM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
1/4-40 at Home Depot is probably not what Two Enchilada's is looking for.
Model Engineering threaded fittings, although the same numbers, are not the same physical size.
It is also referred to as "MTP", as in 1/4-40 MTP.
http://www.pmresearchinc.com/store/h...table=Y&cat=38
http://www.americanmodeleng.com/id33.html
Kmot is offline Find More Posts by Kmot
Old Oct 16, 2012, 07:27 PM
some what irregular
dostacos's Avatar
Joined Feb 2004
Tom how did you hook up your oiler? mine needs a TEE and 2 of the 1/4 40 hose barbs, neither of the sites you listed has that part. if you used them where did you get them, or what did you do instead to solve da problema
Old Oct 16, 2012, 08:32 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Show me a pic of the oiler you have. Mine has plain brass tube. I may have soldered barbs on but I do not remember right now.
Old Oct 17, 2012, 01:16 AM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Alright, I did eventually solder barbs onto the tubes.
The barbs are made by Dubro and you can get them at your LHS.
Old Oct 17, 2012, 11:24 PM
some what irregular
dostacos's Avatar
Joined Feb 2004
here is mine, looks like I need a TEE for in and out BUT I am not sure how well that would pick up the oil and just go in and out. Oh fearless leader, KMOT, where did you get yours?
Old Oct 18, 2012, 01:12 AM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Yeah, okay. You got one of those nice, expensive, fancy oilers.
Figure out a way to support your oiler, build a mount if you have to. Use silicone fuel tubing and it will slip over the threaded pipe ends and you are in business. You don't use a TEE, the oiler goes in line with the steam line.
My oiler was hand made by a steam guru.
Old Oct 18, 2012, 04:28 AM
ooyah's Avatar
GLASGOW
Joined Feb 2011
[QUOTE=Kmot;23032350]Yeah, okay. You got one of those nice, expensive, fancy oilers.
My oiler was hand made by a steam guru. [/QUOTE
Hi Tom
I must contradict you here but with Dostacos's type of lubricator( oiler) with the needle adjusting screw and only 1- steam entry he must have a 'T' piece.
The 'T' piece needs a female thread to screw the lubricator into and on the straight part of the 'T' it will need screwed fittings at both ends to take the copper steam pipe, or as he has already asked he will need 2- connectors to push fuel tubing on to them and then some sort of support for the lubricator..
With your lubricator which is a straight thro' as shown on your pic you can fit fuel tubing on to each end and as you say " your in business "
Hope this helps.
George.
ooyah is offline Find More Posts by ooyah
Old Oct 18, 2012, 01:03 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
You are absolutely correct George and I thank you for correcting me!
It was late and I was under the influence of med's and not seeing clearly that his lubricator had a needle valve, not a cap, and it was not a straight through affair.
Dan, you can get metal TEE's from the LHS, designed for gas model airplanes. There are also nylon TEE's but I would not trust them under the heat of steam pressure.
Old Oct 18, 2012, 04:22 PM
some what irregular
dostacos's Avatar
Joined Feb 2004
Tom, I have the Tee"s, what I need is a 10 40 TPI female thread with barb. I found the part on the end of a pneumatic conversion, but I only need the barb and not sure they will sell that they closed at 2pm central time so I will call again early tomorrow.
Old Oct 18, 2012, 07:23 PM
ooyah's Avatar
GLASGOW
Joined Feb 2011
'TEE' Connectors
Dan,
You have me confused with all of these thread alternatives,
do you mean that you want connectors as per the enclosed sketch to fit into your TEE piece.
If so send me an e-mail with your address and if you cross my palm with silver I will make 2- and post them to you.
George
Old Oct 18, 2012, 07:43 PM
some what irregular
dostacos's Avatar
Joined Feb 2004
Originally Posted by ooyah View Post
Dan,
George
yes that is exactly what I want. I already have the tees so the connector is all I need. please PM me with a price please { need 4, have 2 lubricators}
thanks, Dan
PAY PAL or send a check?
Old Oct 19, 2012, 09:37 AM
ooyah's Avatar
GLASGOW
Joined Feb 2011
thanks, Dan
Hi Dan,
e-mail sent.
George.
For Sale Cheddar gemini steam engine for sale zorrow Boats (FS/W) 4 Mar 02, 2014 09:22 AM
Cool Steam Stuff zorrow Steam Boats 0 May 28, 2012 01:03 PM
New Product Brass covers kit for Graham TVR1A steam engine -kno3- Steam Boats 5 Mar 31, 2012 02:23 AM
Discussion V8 steam engine for live steam crackerbox prallplatte Steam Boats 6 Sep 06, 2011 01:47 PM
Wanted Looking for and Steam Launch kit and Steam Engine *** Joe Pierson Boats (FS/W) 7 Aug 18, 2011 03:01 PM
