Old May 12, 2013, 05:16 AM
New Zealand, Canterbury, Christchurch
Joined Apr 2012
Burnham aerotow
Hi guys,
The aerotow event at the CRFC field on 18-19 May (next week) is gaining a bit of interest. Here are the attendees as of yesterday:
Burnham 18-19 May
Peter Hewson Pilatus Porter tug, Discuss 2 4.5m
Alex Hewson DG 300, 3.5m F3J model for Velcro-towing and on-line aerobatics
Alec Taylor pawnee, wilga , kirby kite , standard jantar.
Neale Blackie 5m ASG 29
Dave Griffin Cub and ASK 21.
Corrie Hoult Converted Radian
John Holmes ¼ scale Olympia, smaller gliders (Velcro system)
Gary Palmer ASG 29
Graeme Phipps Super Cub for up to 3m gliders
Kerry Oakley Cularis 2.6m
Paul Hartley Twotter Tug
John Shaw twitchy fingers
Jack Coker 4.8m Sperber, 4.8m Reiher vintage gliders
Reg Williams Discuss 2.6
Peter Deacon 4m ASW, Pawnee, Kiwicon thermal duration glider
Robin Sallabanks Ventus 2.6
Jonathon Gardener Mini moa
Greg Clarkson electric glider, Pawnee tug (small gliders)
Come and join us!
scaleflier is offline Find More Posts by scaleflier
Old Jun 23, 2013, 06:39 AM
Blenheim, NZ
Joined Dec 2007
What progress Minty??????
Flying my T31 at the weekend reminded me of your build.
Any Progress Minty?
Nice day here and flat calm. The T31 actually handled nicely for a change.
Allan
AllanK1 is offline Find More Posts by AllanK1
Old Jun 23, 2013, 06:49 PM
Joined Jul 2012
Slingsby T-35 Australian:
http://www.trapletshop.com/gb/p/1349...y-t-35-austral
JKinTX is offline Find More Posts by JKinTX
Old Jun 23, 2013, 08:23 PM
Blenheim, NZ
Joined Dec 2007
Originally Posted by JKinTX View Post
I note it has the taller rudder I retro fitted to my Cadet. It does help.
Allan
Old Jun 25, 2013, 05:04 AM
mintie's Avatar
Kaiapoi , New Zealand
Joined Jun 2007
Any Progress Minty?
Allan
HI Allan.....Progress been very slow....been busy working on float planes ,but must get back onto the T31.
The wings have causes some head aches,but think I now have it sorted.
What did you do to make yours handle nicely.
cheers Mintie.
mintie is offline Find More Posts by mintie
Old Jun 25, 2013, 05:38 PM
Blenheim, NZ
Joined Dec 2007
cheers Mintie.
I can only conclude that the extra weight of the pilot up front has helped by moving the CG. That and getting the aileron differential and rudder mix right. The calm day probably meant it was not upset by turbulance either but I really feel this was proably not the reason. It just tracked better and was less inclined to drop a wing tip and turn by itself.
I was really surprised at how well it went so will try it on the hill this summer. T31s have a heap of character and it does look pretty cool in the air. I'm finally starting to warm to it.
I look forward to seeing your bigger one flying.
Allan
Old Jun 25, 2013, 08:23 PM
mintie's Avatar
Joined Jun 2007
well that is all pretty positve stuff.
Hope mine behavies the same.
where do you now have the CG on yours?
How much differential have you on the ailerons?
My rudder is not mixed with the ailerons I just put in what I need by hand.
Yes vintage gliders do have their own character which makes them very appealing..... hence my build.
Your driver looks the part.
Report back after your slope flight....
cheers Graeme
Old Jul 13, 2013, 03:26 AM
mintie's Avatar
Joined Jun 2007
Back onto the T31
Been working on the servo mounts as I need all up the front for CG and as it is an open cockpit trying to hide as much as possible.
Tow release fits under the seat,while the elevator is at the side and is near hidden with the left leg of the pilot.
This connects to the black carbon rod which is the elevator push rod.
So far all working out as planned.
Old Jul 13, 2013, 07:59 AM
WGTN NZ
WELLINGTON NEW ZEALAND
Joined Jun 2008
Hi Mintie,looking great.but must say I would put a bigger servo on the tow release.(this comes from bad experiences with servo s not releasing if to small)
Cheers Woo
WOO NZ is offline Find More Posts by WOO NZ
Old Jul 13, 2013, 08:25 PM
PB of 733kph
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
Yes please put a bigger servo there. You Will need nose weight so a big servo won't be a problem
ALEX HEWSON is offline Find More Posts by ALEX HEWSON
Old Jul 13, 2013, 09:33 PM
mintie's Avatar
Joined Jun 2007
OK guys I hear what you are saying....will now have to do some serious realinement as a fullsize servo will not fit under the seat.
I have room for a full size servo ,but it will have to be more rearward, closer to the CG now. thanks for the imput ....a bit easier to change now than later.
Old Jul 14, 2013, 05:27 PM
Blenheim, NZ
Joined Dec 2007
I suggest you check the release will let go at twice model weight Mintie. Use full servo tavel but trhe shortest arm you need to get the hook movement. Max mech advantage in other words. Big servo is the way to go.
For what it's worth......
Allan
Old Jul 15, 2013, 12:23 AM
KISS_KeepItSimpleStupid
philkiteflyer's Avatar
Invercargill, New Zealand
Joined Nov 2006
+1 on the servo size. My 1/5th scale T31 got hung up behind the tow plane and I was using a standard servo. Only the line breaking saved the glider. The tug was big so it was always safe.
I am now looking at modifying my release. The one "I" favour seems to be "unfavorable by a lot of others . . . . . I'll attach a drawing - when I can find where I hid it. .
If you need more weight up front of CoG, put in a 'Well endowed' pilot like my one
Cheers
Phillip C
philkiteflyer is offline Find More Posts by philkiteflyer
Old Jul 15, 2013, 03:42 AM
mintie's Avatar
Joined Jun 2007
I have now fitted a heavier standard size servo in for the release.This is the tow release I have in the T31
http://www.hobbyking.com/hobbyking/s...1_7x42mm_.html
well Phil with all that lead ballast you told me about in your T31 to get the CG right is it in those pair of jugs in the seat.
Old Jul 15, 2013, 07:24 PM
Joined Nov 2006
Ha ha . . .if only the lead required was that small.
Yep, I got one of releases too . . going to put it in a 'Celeste'. Now we'll see how old you really are if you know that glider. Hint; english mag review (no longer available) scalelish looking.
Keep it coming, want to see more . . .
Phillip C
Sold Airworld 3.5 meter Kirby Kite NIB SteveR Aircraft - Sailplanes (FS/W) 9 Jun 25, 2012 01:56 PM
Discussion "The Lockheed Plant" presented by Joe Kirby BeechMusketeer Atlanta Area RC 0 May 28, 2012 09:08 PM
For Sale 2x HK-SS30A-HW ESC flashed with Simon Kirby's fw lazze Aircraft - Electric - Power Systems (FS/W) 0 May 25, 2012 08:55 AM
For Sale Vintage Super Call-Air Cadet Decals redball8 Aircraft - General - Miscellaneous (FS/W) 0 Mar 10, 2012 01:00 PM
