Old Mar 23, 2012, 04:54 PM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Setting for cc45 and Scorpion 2221 - 12
Hi,
Can anyone please suggest settings for a Scorpion HKII-2221-12 for a CC45
Specifications
Stator Diameter 22.0 mm (0.87 in)
Stator Thickness 21.0 mm (0.83 in)
No. of Stator Arms 9
Magnet Poles 6
Motor Wind 12 Turn Delta
Motor Wire 12-Strand 0.21mm
Motor Kv 2580 RPM / Volt
No-Load Current (Io) 1.50 Amps @ 10 volts
Motor Resistance (Rm) 0.038 Ohms
Max Continuous Current 38 Amps
Max Continuous Power 530 Watts
Weight 81 Grams (2.86oz)
Outside Diameter 27.9 mm (1.098 in)
Shaft Diameter 3.17 mm (0.125 in)
Body Length 38.3 mm (1.508 in)
Overall Shaft Length 58.7 mm (2.311 in)
Max Lipo Cell 4s
Motor Timing 5deg
Drive Frequency 8kHz
MikeHRC is offline Find More Posts by MikeHRC
Old Mar 24, 2012, 07:20 AM
RS Rogers's Avatar
Clyde N.C.
Joined Oct 2003
Hi Mike
8k on the PWM & timing range set at Low is normally what we use on Scorpion motors.
RS Rogers is offline Find More Posts by RS Rogers
Old Mar 28, 2012, 03:32 PM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Now using ICE Lite 50
I decided (possibly correctly) that the 45 was a bit marginal for this - so I picked up a s/h ICE lite 50. I have just logged a couple of typical flights (lots of loops, flips, rolls etc.) plus in this case quite a few full power climbs.
Average amps 11amp, max 53,1
Max temp 168F
The max amps was for less than 1 second - is this OK ?
Old Mar 28, 2012, 04:31 PM
RS Rogers's Avatar
Clyde N.C.
Joined Oct 2003
With Helis it is common to see very quick peaks and sometimes over the current rating of the controller.
We always recomend setting the current limiting to Insensitive and at that the esc will still protect itself - but keep from shutting down prematurely on very quick peaks.
What you are seeing is not a problem at all.
Steve
Old Mar 28, 2012, 04:44 PM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Thanks Steve - appreciated
For Sale Scorpion HK-2221-12 Brushless Motor / 45 amp ztw esc HeliStyle Aircraft - Electric - Helis (FS/W) 0 Jul 25, 2010 09:27 PM
Discussion Max voltage question Scorpion 2221-12 Hoverup Electric Motor Design and Construction 2 Jul 25, 2010 03:34 PM
Discussion Best Prop, 48" combat Wing w/Scorpion 2221-12 KingJoe Flying Wings 2 Jun 06, 2010 07:51 AM
Sold Used: Scorpion 2221-12 Motor 4S with 3x 4s extreme TP packx livinma1 Aircraft - Electric - Power Systems (FS/W) 5 Aug 30, 2009 12:57 AM
For Sale Scorpion 2221-12 livinma1 Aircraft - Electric - Power Systems (FS/W) 2 Jul 20, 2009 07:39 AM
