Old Feb 16, 2012, 09:35 AM
F5Daholic
capediablo83's Avatar
Ancona, Italy, Europe
Joined May 2009
Help!
Strange pins in FUTABA FF7 40mhz module
Does anybody knows the meaning, the function of these three pins that yesterday i found in the TX circuit... In the picture u can see them in white just above the capacitor, above the connector underlined by the sheet.
Sorry for the quality of the picture... it's not mine!
capediablo83 is offline Find More Posts by capediablo83
Old Feb 16, 2012, 10:06 AM
thechannelmast's Avatar
martinsville indiana
Joined Dec 2007
hi
v+,v-,signal but not in that order check with ohm meter for the + and -
thechannelmast is offline Find More Posts by thechannelmast
Old Feb 16, 2012, 10:43 AM
F5Daholic
Joined May 2009
wait wait wait.... i'm not talkin' about the one with the cables cutted... do u understand? Look above...
Or... I didn't understand? If we are talking about the same thing why futaba placed there another 3 pin connector with the same function as the other?
Old Feb 16, 2012, 01:11 PM
Joined Dec 2007
sorry
sorry I didn't understand but that is a good ???
Old Feb 17, 2012, 03:09 PM
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
They are used to generate fixed high or low modulation (by plugging a jumper into one side or the other) while adjusting the trim pots (P101, P102) which set the FM frequency deviation.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Feb 18, 2012, 01:11 PM
F5Daholic
Joined May 2009
Wow!
So... for us MODELLERS there's no utility!?
Old Feb 20, 2012, 03:55 AM
Joined Jan 2001
The 'utility' is that you can use it to check and/or fine-tune the frequency of your transmitter.
Other than that, not much. What were you hoping for?
Old Feb 20, 2012, 01:50 PM
F5Daholic
Joined May 2009
Nothing exactly... just fantasize something!
Discussion HELP Futaba Module TM-7 on FF7 capediablo83 DIY Electronics 2 Feb 16, 2012 09:27 AM
Wanted Futaba 40mhz module, FC-28 chrislarkins Aircraft - General - Radio Equipment (FS/W) 1 Jun 26, 2011 04:47 PM
Help! Need Futaba 40MHz Crystals or R/F Module Dean.roberts Radios 3 Sep 18, 2003 11:50 PM
Help! Need Futaba 40MHz Crystals or R/F Module Dean.roberts Fuel Plane Talk 1 Sep 17, 2003 08:52 AM
Need Futaba 40MHz Crystals or R/F Module Dean.roberts Electric Plane Talk 0 Sep 17, 2003 12:31 AM
