Old Dec 31, 2009, 02:18 PM
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
Question
Can this be right?? Multiplex Merlin (stock power set) folding prop looks wrong.
Guys... this is my first folding prop this angle looks very wrong to me though! I expect that the spinning blades should form a flat disk (like a standard prop) rather than a cone.
Other than the obvious (that the mount isn't glued on yet!!) is the angle of these blades right? I just don't see what I can to to adjust that.
Thanks for taking a look and happy new year!!
Smokescreen38 is offline Find More Posts by Smokescreen38
Old Dec 31, 2009, 02:36 PM
My dremel tool has no fear
Mark's Avatar
Reston, VA
Joined Dec 1999
the centrifugal force keeps the blades straight at rpm , the blades should not be too tight so they can move
Mark is offline Find More Posts by Mark
Old Dec 31, 2009, 02:45 PM
Joined Jun 2005
Cool... thanks, Mark.
I'm going to spool it up and see what happens!
Old Dec 31, 2009, 02:57 PM
Joined Jun 2005
I works!!
I had visions of the hub ripping itself apart and ruining a hard to find power set... so I wanted to ask first.
Thanks!!
Old Dec 31, 2009, 03:47 PM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
I usually fit a tiny wedge in each side to stop the blades going so far forward... if they are that far forward at rest you might experience problems at start up.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Dec 31, 2009, 05:50 PM
Ireland
Joined Apr 2001
as long the blades rotate smooth and can be folded back to the fuse then there is nothing wrong.
in flight the wind will push the blades back anyway so how you show it on the picture will never happen in flight.
If you are worried spool up slowely the first time and you will see its fine.
cmulder is offline Find More Posts by cmulder
Old Dec 31, 2009, 08:09 PM
E-Gliders
outngo's Avatar
South Carolina
Joined May 2009
hold your merlin upsidedown blades should fall forward. normal.
outngo is offline Find More Posts by outngo
Discussion Proper Folding Prop Set Up Tarro Power Systems 12 Sep 12, 2009 07:20 AM
ElectroStreak power set: 550 motor, ESC, 8x5 folding prop w/ 38mm spinner kyril Aircraft - Electric - Airplanes (FS/W) 1 Aug 27, 2003 03:18 AM
LiPo's arrived - This can't be right John Webb Batteries and Chargers 14 Jun 28, 2003 10:19 AM
Bandit packaging ?, this can't be right, is it ? William A Vendor Talk 16 Dec 07, 2002 11:35 PM
Can a folding prop be used in pusher config? MtnGoat Power Systems 2 Jul 26, 2001 10:44 PM
