Old Feb 21, 2012, 07:16 PM
Joined Jun 2007
How water enters in the cooling system?
I am brand new in electric RC boat. I bought a twin hull boat like this.
http://www.hobbyking.com/hobbyking/s...dProduct=19637
Ques is how the water is sucked inside & run through the motor jacket & ESC?
Thanks. There is no water pump as I see
congcon97 is offline Find More Posts by congcon97
Old Feb 21, 2012, 08:04 PM
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
The pressure of the water at speed forces it thru.
scorpion1 is offline Find More Posts by scorpion1
Old Feb 22, 2012, 12:34 PM
Joined Jun 2007
If the boat is run very very slowly then at that time the water will still circulate in the system?
Old Feb 22, 2012, 12:42 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Too slow and it wont
Old Feb 22, 2012, 01:04 PM
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Congcon,
If you run the boat very very slowly (which will be hard with the type of motor and ESC at hand, as they tend to burst into life at one third throttle...), the motor will need no cooling at all, as it doesn't have to work very, very hard.
I can't find any pictures of how the inlet is shaped, most likely a piece of slanted tubing sticking out of the hull, but if the outlet is above the waterline, the flow will stop when the boat moves too slow.
Come on, it's a speedboat, floor it!
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Question Boat ESC in plane? air cooling through fuel line like water cooling? flythreedee 3D Flying 7 Apr 01, 2010 01:40 PM
Cool The unique water-cooling brushless outrunner motor with water circling in the center AEO_Tang Racing Boats - Electric 27 Oct 15, 2009 07:40 AM
Discussion URGENT: Water Cooling - How Much Water Must Pass Via The Head? richclausen Racing Boats - Internal Combustion 1 Dec 16, 2008 11:41 PM
For Sale Athlon XP computer system components - with water cooling! PICTURES ADDED!! habitforming Non R/C Items (FS/W) 3 Feb 06, 2008 11:58 AM
Question water cooling system for motor chriszuma Racing Boats - Electric 12 Jan 04, 2008 03:46 PM
