Old Sep 21, 2014, 10:58 PM
United States, WA, Manchester
Joined Jan 2011
Build Log
Sidewinder Build
I've had this kit for a while now. I finally found a ASD drive plus have some time to get started. It is a logging Sidewinder from Gary King in BC. This is my second kit I've built of Gary's. The hull's are really stout and can really take a hard bump, The hull, Deck, and superstructure will require quite a bit of trimming and sanding for a good fit.
Zebear is offline Find More Posts by Zebear
Old Sep 21, 2014, 11:15 PM
Joined Jan 2011
Propulsion system
Here is the propulsion system I am using. Its a 40mm prop ASD from Cornwall Model Boats, A 3536/8 1000KV brushless motor, 50A speed control, HS-5645 digital servo with a 60 tooth gear to turn the schottel drive. The 6V SLA batteries I wanted to use will not fit so I have some of the 1.2 amp hour versions on order.
Old Sep 21, 2014, 11:22 PM
Joined Jan 2011
Propulsion system installed
Here are pictures of the system installed
Old Sep 22, 2014, 01:58 AM
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
You may find you need a high torque metal gear servo to overcome the
rotation and friction of the drive gears. I had a hard time keeping my
tug strait for the first few years, and finally figured out that at full speed, the
servo couldn't hold the drive "true".
Lower speeds were not an issue, just full power.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Yesterday, 04:29 AM
Joined Jan 2011
Thanks for the tip Aimee. It is a high torque metal gear digital servo.
I found out that the HS-5XXX series digital servos can program the endpoints for 180 degree travel and they will move that far on the programmer, However. when connected to the radio system I will only get 90 Degrees of travel. The 5XXX series only has a High Resolution mode so you get very fine movement for the 90 degrees but no low resolution to get 180 degrees travel.
The 7XXX series has both High and Low resolution. I picked up HS-7985 which is another high torque metal gear servo with both High and Low resolution. I can now get 180 travel on the servo which gives me 360 travel on the ASD.
Old Yesterday, 08:43 PM
Keep a Steady Strain....
capntroy's Avatar
Orange County, CA
Joined Nov 2007
Cool project Zebear, Gary King always makes a fine kit!
Looking forward to the build log and sea trials...
capntroy is online now Find More Posts by capntroy
Old Yesterday, 10:26 PM
boat butcher
the goon's Avatar
Whittier CA.
Joined Oct 2009
Mark
the goon is offline Find More Posts by the goon
Discussion Sidewinder sct vs sidewinder 3 zen3 Off-road Cars 8 May 07, 2014 11:30 AM
Help! Sidewinder 3 help Fotografer1 Electric Power Cars 2 Nov 04, 2013 01:16 AM
Build Log New Super Sidewinder Build Spyder2782 Slope 17 May 19, 2010 12:08 AM
Build Log My Sidewinder II build G2BBrushless Hand Launch 43 Sep 18, 2007 08:14 PM
