Old Jul 27, 2014, 01:23 PM
Allways the hard way!
georgy's Avatar
South Africa, GP, Germiston
Joined Jan 2012
Question
Low wing oldtimer?
I'm new to oldtimers & started off buildind a Tomboy...
I been looking thru the plans thread but cant seem to find low or mid wing types.
(mostly cos the names of the models dont describe the type)
Can some one please post a few names of low/mid wingers?
Thanx
George
georgy is online now Find More Posts by georgy
Old Jul 27, 2014, 02:02 PM
Northumberland, England
Joined Jan 2007
The Mercury Galahad is one design that immediately springs to mind.
However if you visit http://outerzone.co.uk/index.asp , click "browse", select a category then select "thumbnails" you'll be able to see illustrations of each design.
patmcc is online now Find More Posts by patmcc
Old Jul 27, 2014, 06:08 PM
Since 1952
Harry D's Avatar
Canada, AB, Edmonton
Low wing oldtimers aren't all that common but there are a few. The prettiest one I've ever come across is the Schiffermuller (1946). Search here on RCG or on the web and you'll get lots of information.
Outerzone has the original plan: http://outerzone.co.uk/plan_details.asp?ID=5683
Durad did a nice build log here on RCG recently: http://www.rcgroups.com/forums/showthread.php?t=2182687
Good luck in your quest. Let us know what else you find, and what you choose to build.
Harry D is offline Find More Posts by Harry D
Old Jul 27, 2014, 06:15 PM
United States, MA, Waltham
Joined Dec 2001
When you say "old timer", does that mean only designs that originally had a motor? If not, I think Stahl's Hurricane (not the scale job) is interesting.
http://www.theplanpage.com/esp/hirridur.htm
These days it would be easy enough to put a motor in it. Especially if you put the motor in the center and used a rubber loop to drive the prop!
If you go over to Outerzone, look up Shereshaw's XP-2 and XP-3. The first one, I think, is a low wing twin boom pusher. Second is somewhere between mid and shoulder wing but similar otherwise. I know I've seen others. If you like flying wings, you might find some of those which are low wing. A high thrust line helps them.
lincoln is offline Find More Posts by lincoln
Old Jul 27, 2014, 06:20 PM
Old Timer
California Condor's Avatar
CARMICHAEL, CALIFORNIA USA
Joined Apr 2001
The Sykes Low Wing is one. Photo in the May 1939 Model Airplane News.
California Condor is offline Find More Posts by California Condor
Old Jul 27, 2014, 06:33 PM
Joined Dec 2001
Another thing to try is the advanced search on Outerzone. Pick IC and FF for the tags, and write "low wing" for the description field. You'll get a dozen or so.
Here's another one, the Panther:
http://www.outerzone.co.uk/plan_details.asp?ID=5074
BMJR has a kit for a slightly shrunk version meant as an RC park flyer.
Old Jul 27, 2014, 06:52 PM
Blenheim, NZ
Joined Dec 2007
Thanx
George
Lancer and Cumulus are my two mid wingers. There are plenty of others if your go through outer zone. Both fly great. I think the Dragon Fly is a low winger and there should be a brilliant South African thread on this group about it, Warren Smith build???
Moth Minow and Moth Major are really interesting low wingers out of cental Europe some place. Never seen one built but look at the plans ofter. Particularly the minor
Allan
AllanK1 is offline Find More Posts by AllanK1
Old Jul 27, 2014, 10:54 PM
I'd rather be flying.....
United States, IA, Story City
Joined Oct 2013
the j.l. sadler " pacemaker" is a wonderful looking model....
Best Regards,
Jeff
JeffMac is offline Find More Posts by JeffMac
Old Jul 28, 2014, 01:05 AM
georgy's Avatar
Joined Jan 2012
Thank you for the responce gents!
I will look thru them..
1st gotto finish the Tomboy.
Regards
George
Old Jul 28, 2014, 12:20 PM
SAslinky's Avatar
Umkomaas, South Africa
Joined Mar 2010
Here is the link to my Dragonfly old timer build log.
http://www.rcgroups.com/forums/showthread.php?t=1438924
Lionel.
SAslinky is offline Find More Posts by SAslinky
Old Jul 28, 2014, 12:44 PM
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
The ultimate Swedish lo-wing oldtimer is the "Viking" (around 1956) , designed by Eric Berglund.
Mr Berglund won the European Championship (s/ch class) in Darmstadt, Germany 1958, with his Viking & his own designed rc-gear...
To be read about in Aeromodeller, dec 1958.
Gluehand is offline Find More Posts by Gluehand
Old Jul 28, 2014, 05:29 PM
RyanNX211's Avatar
Upper Arlington, Ohio
Joined Dec 2007
Here's Bucky's Galahad. Not an OT by US rules, yet.
The most common low wingers you'll see in the States are the Peerless Panther and the Saddler Pacemaker. Sure wish someone could draw up a plane for the prototype of the latter; it had a bigger fin and a cabin.
RyanNX211 is offline Find More Posts by RyanNX211
Old Jul 28, 2014, 06:13 PM
Blenheim, NZ
Joined Dec 2007
Allan
Sorry Lionel, I should have remembered your name.
The models I spoke of above were actually the Beta Minor and Beta Major.
I should check my facts before burstingb into print!
Allan
Old Jul 29, 2014, 02:11 AM
perttime's Avatar
Tampere, Finland
Joined Nov 2004
I really like the look of Schiffermuller, Lancer and Cumulus.
perttime is offline Find More Posts by perttime
Old Jul 29, 2014, 02:48 AM
georgy's Avatar
Joined Jan 2012
Lionel.
Hi Lionel,
Are you the same "Slinky" on AVCOM?
That Dragonfly is a work of art!!
George
Sold New Flyzone Switch 45" High Wing Trainer/Low Wing Aerobat Tx-R geekmonkey Aircraft - Electric - Airplanes (FS/W) 0 Jan 13, 2014 01:24 PM
Discussion Motor angles - High wing vs Low Wing billisfree Electric Plane Talk 10 Jan 03, 2014 09:13 AM
Question Dumb question, Charging low wing planes. (1 piece wing) Falconpunch1 Fuel Plane Talk 21 Jan 01, 2014 11:24 PM
For Sale Predator II low wing hlg GaryO Aircraft - Sailplanes (FS/W) 7 Sep 30, 2013 01:07 PM
Sold Goldberg Tiger 2 (35) NIB Low wing Trainer (Kit) puplover Aircraft - Fuel - Airplanes (FS/W) 0 Sep 24, 2013 11:19 AM
