Old Apr 19, 2013, 07:24 AM
Wing Driver - You buy, we fly
Guam
Joined Nov 2012
Hobby King Phazer Wicked setup?
Hi Don,
Thinking of picking up a HK Phazer. Do your Wicked setup's fit / work with these?
Also I'm stationed on Guam USA, standard zip 96921. NOT APO/FPO, will you ship to me via USPS Priority Mail ?
Capt. Thomas
Capt. Thomas is offline Find More Posts by Capt. Thomas
Old Apr 19, 2013, 09:28 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
It uses a 64mm setup so assuming a 4S 2200 lipo will fit then either Setup B or Setup C will be a good choice. http://www.rcgroups.com/forums/showp...21&postcount=2
I never got one of these kits as they messed up my order. I can ship to Guam no problem.
The Don is online now Find More Posts by The Don
Old Apr 20, 2013, 03:08 AM
Guam
Joined Nov 2012
Ok thanks Don, I assume the Stinger & the Phazer are interchangable 64's? Reason I ask is if I get a Phaser it will take months to get here from HK. I just bought a Stinger from a statside supplier and it will be here in a week or so USPS Priority mail. I want to build a little speed demon, so the question is.....
1. I see your Wicked Plus 4400/HET6404 comment of 1000w. Is this fast / faster than the D 800w set up enough to justify a lager ESC and the extra cooling I will do to it? What is the amp draw on this 1000w combo?
2.If I just wanted to throw a 3s pack in to tool around while other batteries are charging, could I and what would the watt & amp draw be with it on 4400/HET at 3s?
I want to get this on order ASAP as well as balanced EDO type 1 fan so I can play with the Phaser when it arrives.
Thanks!
Capt. Thomas
Old Apr 20, 2013, 11:49 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
They should be interchangeable. The only difference usually is the inlet lip on the EDF some setups do not have one but most do have the lip and the higher wattage setup have the lip.
The 4400 @1000 watts will be faster than the 800 watt setup. Mathematically it should be about 8% faster than the 800 watt setup. The 1000 watts will be about 65 amps so will require an 80 amp ESC. These 4S setups on 3S will have about half the watts, so the 800 watt setup on 3S will be about 400 watts.
Wanted Stinger 64 - HK Phazer - Dons Wicked Setup's & Hobby Wing ESC's Capt. Thomas Aircraft - Electric - Jets (FS/W) 1 Apr 13, 2013 01:55 PM
Discussion Alfa MiG-15 + Don's Wicked setup = FAST! smaze17 Electric Ducted Fan Jet Talk 3 Mar 19, 2013 05:15 PM
Sold Hobby king 900mhz fpv setup Depron Dave FPV Equipment (FS/W) 2 Mar 15, 2013 07:36 PM
For Sale Hobby king 900mhz fpv setup Depron Dave Aircraft - Electric - Multirotor (FS/W) 2 Mar 14, 2013 09:03 AM
Discussion Hobby City/ Hobby King FPV setup- thoughts? Smokescreen38 FPV Talk 6 Oct 23, 2009 04:27 AM
