Old Jan 21, 2013, 02:50 PM
Auckland - New Zealand
Joined Dec 2010
Kontronic Fun600-25
Hi i have a Kontronic Fun600-25 motor,I'm trying to find out the specs on it and there is nothing on their website.
I need to know the max voltage i can run in it
Adrian
Adrian_M is offline Find More Posts by Adrian_M
Reply With Quote  (Disabled)
Old Jan 21, 2013, 05:52 PM
Hastings, Hawkes Bay, New Zealand (Aotearoa)
Joined Feb 2000
The Fun 600 series where rated for 50,000 rpm so working backwards from that gives at least 5s (~20v) possible.
Heather
Heather is offline Find More Posts by Heather
Old Jan 21, 2013, 11:29 PM
Joined Dec 2010
Heather
Old Jan 22, 2013, 03:47 AM
Grow old disgracefully!
dickw's Avatar
Luton, UK
Joined May 2006
Heather
I have run them at 70,000+ rpm so you could go a bit higher if you needed to.
Dick
dickw is offline Find More Posts by dickw
Old Jan 22, 2013, 04:01 AM
Joined Dec 2010
Dick
Hi Dick, I was told that I could run 6s no problem with small prop
Cheers
Adrian
Old Jan 22, 2013, 04:14 AM
Crashing into the sky!
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
The rotor on em seems to be one peice with the shaft, its really cool machining/manufacturing. I still dunno how they are made Id think 50k rpm is VERY safe.
jackosmeister is online now Find More Posts by jackosmeister
Old Jan 23, 2013, 02:46 PM
Joined Dec 2010
It took nearly two weeks but finally got a reply from Kontronic
• 2530 U/min/V
• 6-24 Zellen / cells
• 20-60A Dauerstrom / cont. current
• 90A 20 sec.
so i guess 6s shouldn't be no problem
all of you guys where pretty much right
now we come to the next question, how do i remove the Gearbox I'm using this motor in direct drive
Old Jan 23, 2013, 03:09 PM
Auckland NZ
Joined Aug 2007
6-24 is nimh talk
Gearbox is threaded onto front plate of motor, conventional thread (lefty loosey). Theyre often held on with loctite (heat helps lots)
A small oilfilter strap wrench works well, or you can thread screws into the front the gearbox (all the way in till they bottom out) and use them with a screwdriver jammed against them to get some leverage. Bench vice with softjaws makes it much easier.
Pinion is held on with loctite, heat and a small puller.
Try not to bust the box, KPG25/27s are cool things. Becareful not too loose bearings/planets and the retaining washer when it comes off
Old Jan 23, 2013, 05:26 PM
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Cheers
Adrian
Once the pinion is finally removed you will be left with a very short stub shaft--so before you tear it apart be sure you can actually put a prop adapter on it....
Steve
sneu is offline Find More Posts by sneu
Old Jan 23, 2013, 07:13 PM
Joined Dec 2010
Originally Posted by jackosmeister View Post
6-24 is nimh talk
Jako thanks for the info about the gearbox
I figured out that it was Nimh 24x1.2=28.8 that's why i said 6s should be fine
Old Jan 23, 2013, 07:16 PM
Joined Dec 2010
Steve
I was thinking about that Steve,I figured the only way i would know would be to pull it apart
What motors can you offer me with a similar KV?
Old Jan 23, 2013, 09:52 PM
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
The shaft will be only about 11mm long from memory so if that isn't long enoughfor your direct drive application it might pay to leave it together !
Peter M is offline Find More Posts by Peter M
Old Jan 23, 2013, 10:08 PM
Joined Dec 2010
That's too short then
If anyone is intrested in buying it pm me I'll let it go cheap
Cheers
Old Jan 24, 2013, 10:40 AM
sneu's Avatar
Joined Dec 1999
A 1409/1.5Y is close with a Kv of 2400. The standard version has a 5mm shaft which would be good for what you are likely to use it for.
Steve
Old Jan 25, 2013, 01:57 AM
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
Yup, the shaft will be very short. Also it's a waste of a good motor not using the gearbox.
I have run a FUN600-18 with 6.7:1 gearbox with 10S 1800mah Lipo and up to 18'' F5B props. Mine worked fine untill my biggest prop cooked this motor at well over 6KW. Remember that this motor is only about the size of a Neu 1509 and so it is better to stay below 5KW and/or do not run the motor to long each flight as the heat builds up. About 30 seconds total run time max at 5KW.
RPM wise, these motors can take more then a Neu. I've had mine up to 120.000 RPM at one point (a 3800KV Kira).
For this 2500 KV motor, you would need atleast 6S to get it up to speed. Best combo would probably be 8S 1800-2500mah with a CC ICE 100 Lite or 200 Lite. The prop size depends on the gearbox ratio. With 6.7:1 you could use RFM 16x17 slim for about 4KW but probably this gearbox is 5.2:1 so then RFM 14.5x14 already gives 4.5KW. Going cheap, you could use one of my 60 euro ESC's and 6S 2700-3300mah with an RFM 16x17 slim for about 3.5KW.
Let me know if you need any more help with setup.
Joe
jjmouris is offline Find More Posts by jjmouris
For Sale Kontronik FUN600-25 with gearbox Adrian_M Aircraft - Electric - Power Systems (FS/W) 0 Jan 09, 2013 10:43 PM
For Sale Kontronics FUN600-17 brushless motor pulsar110 Aircraft - Electric - Power Systems (FS/W) 1 Mar 13, 2008 12:10 AM
For Sale kontronics fun600-18 cars4fun2001 Aircraft - Electric - Power Systems (FS/W) 1 Nov 15, 2006 02:55 PM
Kontronic Fun600-25 Saga fmidgett Power Systems 12 Aug 04, 2005 04:55 PM
Question Kontronic Fun600-25 Saga fmidgett 3D Flying 1 Aug 02, 2005 05:41 PM
