Old Jan 23, 2013, 08:54 AM
life long racing nut & modeler
granada don's Avatar
Granada Hills Ca.
Joined Nov 2009
Hi Eddie
Back in the day i built a Gemini MTS wing and put it on a sharp pointed round glass fuse with fin, looked like a missile so i called it ' Missiles ' in laten for missile.
Try to come up with your own name for your design as you just used Blane's ribs, think outside the box!! for something trick
G Don
granada don is online now Find More Posts by granada don
Old Jan 30, 2013, 01:44 PM
hog2soar's Avatar
Central California
Joined Jan 2010
I finished her. I like it.
Here's a couple pictures. You can see more pictures if you want in the Thermal thread under "Mirage customized personalized build.
Hog
hog2soar is offline Find More Posts by hog2soar
Old Jan 30, 2013, 02:03 PM
craigrrr's Avatar
San Diego area
Joined Jul 2006
Beautiful
Hog
Eddie:
You have created a very beautiful custom Mirage.
a few questions:
1. What is all up weight ?
2. Are you using full or half elevator
3. What is your motor and battery ?
4. What material did you cover it with ?
5. How does she fly ?
Craig
craigrrr is offline Find More Posts by craigrrr
Old Jan 30, 2013, 02:20 PM
Fly to live- Live to fly
ultimatetwo's Avatar
ROTA-CADIZ-SPAIN
For those of you who may not be following my build of a Custom Mirage in the Thermal section,here's a couple pictures.
I'm making it an electric and will probably use it for ALES.
I custom built and stretched the fuselage. Custom built the tail feathers,and made the wing a 5 panel wing with custom tips. The stock Mirage is a 3 Panel wing with square tips.
Therefore,shouuld this be called a Mirage,even though the box it came in says Mirage. It doesn't resemble a Mirage and probably won't fly like a Mirage.
So what should it be called?
Eddie
Awesoome work...
Fantasa ...; ( Phantasy in spanish .. ) ? My two cents about name.
Congratulations Eddie.
Manolo.
ultimatetwo is online now Find More Posts by ultimatetwo
Old Jan 31, 2013, 10:18 AM
hog2soar's Avatar
Central California
Joined Jan 2010
Originally Posted by craigrrr View Post
Eddie:
a few questions:
Craig
Hi Craig,
It's all up weight is 46 ounces. I posted 44 ounces on my build log,but that was a typo error.
It has a half elevator.
Motor is the same as you used. KDA 22-20L I hope it has enough power. I was hopping to keep it's auw a little lower. But considering I stretched the fuse and glassed it then stretched the wing and added custom tips to make it 120",I don't think it's too bad. The Battery is a 30C 3s, 2200 Lipo. I needed it for the nose weight and still had to add a little.
The covering is Ultracote black and transparent red.
I don't know how she flies yet. You should bring yours up here to Visalia and show me how it flies.
Eddie
Eddie
Old Jan 31, 2013, 12:41 PM
craigrrr's Avatar
San Diego area
Joined Jul 2006
Hi Craig,
Eddie
Eddie
Eddie:
Thank you for the information.
Considering your mods, 46 ounces sounds good; and with your stretched wing, the loading should be low.
I think the motor should suffice. Nice to have a beefy
30C LiPo, especially as the battery ages and looses capacity. I also use 2200mah 3s; usually 40 minutes is easy in poor/marginal lift. Visalia lift may require occasional visits to the chiropractor. I would love to fly in your neighborhood.
My next bird will use Ultracote; I was just worried about wing flutter and heard that Monokote might minimize flutter. But I really don't know.
I REALLY THINK YOUR NEW BIRD IS GORGEOUS.
Wishing you a long enjoyable Mirage life
Craig
Old Jan 31, 2013, 01:35 PM
ROTA-CADIZ-SPAIN
Hey Eddie, please, can you tell me the size of the prop and nose cone of your ship..? Im doing a Mirage e-conversion an plan to use a similar or the same motor that you...
Tx for granted and have a really good maiden flight.
Manolo.
Old Jan 31, 2013, 02:20 PM
hog2soar's Avatar
Central California
Joined Jan 2010
Manolo.
I have a KDA 22-20L Motor from Hobby King. It's the same Motor that Craig,above has in his Mirage. However his Mirage only weighs 41 ounces.
Hobby King has been out of stock with that Motor for a long time. It's been back ordered.
The prop is an Aeronaut Cam 10x6 folding prop.
Hope that helps.
Eddie
Old Jan 31, 2013, 02:28 PM
hog2soar's Avatar
Central California
Joined Jan 2010
Craig,
I have Ultracote on an Oly III and a custom Pod and boom Sig Riser. I haven't had any problem with wing flutter. Oh,I take that back. When I was triming my Sig riser I put it into a dive to see what it would do. It was a little steeper than 45 deg. I don't know how fast it was going,much faster than it should and it was really waveing to me to stop. I pulled her out of the dive and she survived.
Ultracote is really easy to use in my opinion. Just make sure your iron temps are correct.
Eddie
Old Jan 31, 2013, 02:38 PM
ROTA-CADIZ-SPAIN
Hope that helps.
Eddie
Tx Eddie for the tip. Yeap, Im checking HK daily for that motor and ...
If they continue without it, my idea is to use a E Max GT 2218-09 or GT 2820-7 that are avaliable on my local hobby shop. Im now involved in the wing build but maybe on two weeks or so I will need the motor to plan to fuse nose area...
Checking to your maiden and flight report, mate.
Manolo.
Old Jan 31, 2013, 02:40 PM
ROTA-CADIZ-SPAIN
Hope that helps.
Eddie
If they continue without it, my idea is to use a E Max GT 2218-09 or GT 2820-7 that are avaliable on my local hobby shop. Im now involved in the wing build but maybe on two weeks or so I will need the motor to plan to fuse nose area... How about the diameter of the spinner ?..
Manolo.
Old Jan 31, 2013, 03:24 PM
craigrrr's Avatar
San Diego area
Joined Jul 2006
Manolo.
Manolo:
I use the KDA22-20L with a Graupner CAM 10-6 folder; it draws 21.1 amps, 249 watts with a 3s LiPo.
I am using a 30mm diameter spinner on the 3mm motor shaft (HobbyKing, $6)
With a 10-8 folder it draws 32.4 amps, 365 watts. This is above the recommended max amps, but might be ok with our short run times.
I also would like to buy a few more of these wonderful $14 motors for spares. I am on my second motor; the first one lasted over 400 soaring hours. They are reliable, long lasting motors; hope they will return to Hobby King.
Craig
Old Feb 02, 2013, 05:05 PM
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
Hog
That looks awesome.
Trisquire is offline Find More Posts by Trisquire
Question Can anyone identify this Glider...Name & Maker rhampton Sailplane Talk 8 Jun 09, 2013 10:26 AM
Discussion Just finished my new TBS Discovery, I really love this thing jasper7821 Multirotor Talk 6 Jan 14, 2013 08:49 PM
Help! Need a name for a new website idea! Garret H Life, The Universe, and Politics 17 Feb 06, 2010 07:45 PM
Discussion i really really really need some help with this red_ace12 Submarines 2 Jun 29, 2007 06:50 PM
you really need to see the pics of this new design!! birdie_in_texas Electric Ducted Fan Jet Talk 0 Oct 16, 2004 01:00 AM
