Old Dec 29, 2012, 04:33 PM
Joined Oct 2011
Help!
Trying to find a gearbox to fit this motor
I have a Black Mantis BM3650 900kv inrunner motor that I would like to find a gearbox for. I would prefer to not go into why, but if anyone has any advice on specific gearboxes to use, I would very much appreciate it!
It has a 36 mm canister and a 3.17 mm x 15 mm shaft.
More info here:
http://www.giantshark.co.uk/black-ma...-p-403926.html
Thanks!
nekoji is offline Find More Posts by nekoji
Old Dec 29, 2012, 10:05 PM
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
That's just too vague and open ended a question.
What sort of gear ratio are you looking for, and how much power are you expecting to put through it? You also need to specify the mount pattern on the front of the motor casing, ie 4 x 25mm PCD, or 4 x19, or 2x16 + 2x19. You also need to address any other constraints such as whether there is a boss on the front of the motor that might affect gearbox mounting, whether offset is feasible or inline/planetary is required. Is there a gearbox output shaft constraint?
Why the secrecy? - you're basically asking folks to provide you info on gearboxes when the solutions offered may be entirely inappropriate, thus wasting their time.
scirocco is offline Find More Posts by scirocco
Old Dec 29, 2012, 10:20 PM
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Any gearbox designed for a 'Speed 600' or '540' motor should fit, eg:-
Great Planes ElectriFly GD-600 Elec Gear Drive 2.5:1
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Dec 30, 2012, 08:08 AM
Challenger 413's Avatar
Dickinson, Tx.
Joined Sep 2004
I agree with Scirocco...Gearbox choice depends on what power output you want and what size prop you intend to fly with.
Challenger413
Challenger 413 is online now Find More Posts by Challenger 413
Old Dec 30, 2012, 11:44 AM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Two other pages to look at:
http://www3.towerhobbies.com/cgi-bin...3p?&C=GHI&P=ML
http://www3.towerhobbies.com/cgi-bin...&I=LXMLK0&P=ML
Note 48pitch RC car pinions can be used with the above.
jrb is offline Find More Posts by jrb
Discussion I am trying to find out how old this Tee Dee is? Capt. Quirk Engines 14 Jun 09, 2014 03:17 AM
Help! Need Help on finding an Electric motor to fit my plane. GulfCoastFlyer Electric Plane Talk 5 Nov 15, 2012 10:45 PM
Wanted trying to find a couple motors dlewton Aircraft - Electric - Power Systems (FS/W) 1 Oct 20, 2012 02:06 PM
Help! Where to find this motor? I wan one more, cant find where. Anybody knews? Master7 Scale Sailboats 1 Jul 30, 2012 10:22 PM
Discussion please help me find a battery to fit this motor bretd123 3D Foamies 9 Apr 16, 2010 02:02 PM
