Old May 06, 2012, 03:46 AM
Mikethk's Avatar
Joined Aug 2010
New setup performance......
Hi.
I upgraded my setup from:
Motor: 745W, 1240Kv http://www.modelskibet.dk/product.asp?product=6531
ESC: 120A http://www.hobbyking.com/hobbyking/s..._Boat_ESC.html
To:
Motor: 2400W, 1300Kv http://www.offshoreelectrics.com/pro...o-4092&cat=148
ESC: 180A http://www.hobbyking.com/hobbyking/s..._Boat_ESC.html
Same batteries are used. 25C, 22v2
But the performance seemed to drop down?
Why is that?
Its like when i have the propeller above water, then it goes nice fast, but as soon as i put it into the water, i cant archive the same top RPM.
Im thinking, maybe there is no enough power for the bigger motor/ESC.
But what could the problem be?
Mikethk is offline Find More Posts by Mikethk
Old May 06, 2012, 04:39 AM
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Double post, sorry.
pompebled is offline Find More Posts by pompebled
Old May 06, 2012, 04:49 AM
Sneek, Netherlands.
Joined May 2004
Hi Mike,
Your Lipo's can't provide the power for the new motor.
Did you use the same prop, or did you prop down for testruns?
25 x 5,8 = 145A
The motor average output is 2400W : 22,2V= 108A
The bursts can be easily twice as much = 200A+
You'll need 40C lipo's or more (preferably parallel packs) for this set-up.
Regards, Jan.
Old May 06, 2012, 05:13 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I'll do a "what he said" on Jan's post and add that you need to be sure to check your esc timing on that motor. The 4092 1300kv is a D wind and should have the timing set just above 0 degrees. (3.75 degrees works well)
The default factory timing on the Turnigy 180 is around 15 degrees and if left unchanged will cook something.
bill34207 is online now Find More Posts by bill34207
Old May 06, 2012, 07:40 AM
Sneek, Netherlands.
Joined May 2004
Thanks Bill, I knew I was forgetting something cruicial...
Most likely because I don't own one of those ESC's.
Regards, Jan.
Old May 06, 2012, 10:31 AM
Mikethk's Avatar
Joined Aug 2010
Originally Posted by pompebled View Post
Hi Mike,
25 x 5,8 = 145A
Regards, Jan.
I used the same prop as with the first setup.
25 x 5,8 = 145A What are those calculation? 25? 5,8?
The feeling i get is that when the motor is above water, it can go as fast as it needs. But when underneath it cant go fast anymore.... So to say, it aint the prop size i believe.
Could i try to parralel my 2 packs running 11v1 with then 50C. If i can get the power as i get with 22v2 25C then it would be a pretty good test for showing that its the discharge of the battery that is wrong? I dont wanna buy new batteries if it aint the solution
Old May 06, 2012, 10:33 AM
Mikethk's Avatar
Joined Aug 2010
Jan's post?
esc timing? How to check this? How do i set it? Sry. im still nab.
D wind?
Why will the Turnigy 180 cook somethign due to 15 degress? I dont get it. I wanna test this before working towards new batteries.
Best regards Mikethk
Old May 06, 2012, 10:42 AM
wagondriver42's Avatar
United States, NY, Rochester
Joined Jul 2011
electric motors are timed just like a combustion motor so to speak. The timing for your "d" wind motor is low. So you need a programming card to change the timing of your ESC to 3.5 degrees. Also 25C batts can not typically provide the required amp draw for FE boats.
wagondriver42 is offline Find More Posts by wagondriver42
Old May 06, 2012, 11:10 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Originally Posted by Mikethk View Post
Jan's post?
D wind?
I was referring to the need for more battery as Jan said. Minimum of 40c for that motor with a 2p (6s x2 in parallel) being preferred to give it full power.
As wagondriver said different motors require a different timing on the esc to operate properly. D wind motors are typically more torquey than a Y wind but generate more heat and absorb more amps doing it. As a result you have to run lower timing to keep from overheating them.
Easiest way to set the timing on the Turnigy is with a programming card. http://www.hobbyking.com/hobbyking/s...idProduct=7187
Refer to the sheet that came with your esc for what the settings mean or to program it via your radio.
Old May 06, 2012, 07:21 PM
Thermite + ice = Big boom.
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
Jan, where did you get the 5.8ah? He never stated the capacity of his batteries
boaterguy is offline Find More Posts by boaterguy
Old May 06, 2012, 07:40 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Coming back to referring to the sheet that came with the esc. Did you set the throttle end points? That's another thing you have to do with a Turnigy that I forgot to mention earlier.
Old May 07, 2012, 02:49 AM
Sneek, Netherlands.
Joined May 2004
Check Mike's thread about his large and heavy hull.
Regards, Jan.
Old May 07, 2012, 05:48 AM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
Alright, didn't realize there was another thread.
The calculation Jan did (5.8*25) was to calculate how many amps your batteries can put out.
The 5.8 is the capacity of your batteries, in this case your batteries are 5800mah (milliamp hour), but you have to change that to amp hours (/1000).
The 25 is the C rating of your batteries, there is usually a burst and constant, you want to use the constant. Beware with cheaper manufacturers these numbers may be a little bit exaggerated.
Old Jun 12, 2012, 03:22 AM
Mikethk's Avatar
Joined Aug 2010
Hello everybody... Thx. The timing actually worked....
I changed it to 3,75 and now it goes alot faster.
Old Jun 12, 2012, 01:56 PM
Sneek, Netherlands.
Joined May 2004
Hi Mike,
Good to hear you got it working!
Some pictures, or video would be nice...
Regards, Jan.
Discussion Best fuel tank system (proof) The search for the best performing tank setups schusterjo Fuel Plane Talk 414 Aug 29, 2012 12:19 PM
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
Question Anyone Know What Kind of Setup Would Give This Type of Performance? AEMontoya High Performance 10 Mar 25, 2012 02:29 AM
Question What kind of performance from this D99 Setup? AEMontoya High Performance 2 Sep 21, 2011 02:30 PM
How Would This Setup Perform On The Gws Formosa? QUESTIONS AAND COMMENTS APPRECIATED! Zachary Parkflyers 12 Aug 31, 2004 06:41 AM
