Old Aug 10, 2014, 09:25 PM
Houston. .we have a problem.
FOX ONE!'s Avatar
United Kingdom, England
Joined Aug 2008
In that case, apologize for my misunderstanding.
I'm only passing on the info I was told.
Here's a question, if it was a simple disconnection of the antenna, how is it that when connecting a wifi antenna, there was only a usable range of 10 metres, if the gain of the antenna had nothing to do with the variables involved? If the antenna was actually not connected at all (due to the lack of central conductor connection), surely there would not have been a usable range of anything like 10 metres?
In addition, my home wifi normally only has a range of around 10 metres, with its standard low-gain antenna (according to the instruction manual) yet if I screw in an "ultra high gain 12db antenna" (that's how they're marketed, by the way, if you google "ultra high gain antanna", they're all there, although I personally suspect the "ultra" reference is a marketing ploy as commonly only low & high gain antennas are referred to according to my own understanding ), suddenly I get about 150 metres range, with no other hardware changes other than different antennas with different gain values?
FOX ONE! is online now Find More Posts by FOX ONE!
Old Aug 10, 2014, 09:43 PM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
See my comments in the text.
Hope this makes sense.
The issue is not the antenna but the connector. The connector used by the Quanum has the internal "live" pin on the aerial side and an internal "live" socket on the Quanum transmitter side. Most (all?) WiFi antennas are opposite and have have the pin on the modem and socket on the aerial. The rest of the connecter including the screw connection is identical. So if you screw a modem WiFi aerial on the Quanum transmitter it fits perfectly but there is in fact no connection between the Quanum and the aerial since there are two sockets inside the connector - and they never touch. The usable range of 10 metres would have been exactly the same if no aerial at all was screwed on since it is just the RF radiation from the Quanum PC board traces.
In addition, my home wifi normally only has a range of 10 metres, with its standard low-gain antenna (according to the instruction manual) yet if I screw in an "ultra high gain 12db antenna" (that's how they're marketed, by the way), suddenly I get about 150 metres range, with no other hardware changes other than different antennas with different gain values?
That's because the high gain antenna is directional. What it does is change the radiation pattern from ball (omnidirectional) to a disk (highly directional -with more power in the flat disk and much less away from it). The TOTAL power of your WiFi router is unchanged since the antenna is unpowered and therefore passive with no amplification. It just changes the shape of the radiation pattern so more signal appears.
This is fine for WiFi since you can move the aerials around to maximise the signal strength of the path and in most cases the aerial is vertical so it broadcasts a flat horizontal disk which is what most ground based WiFi needs. Most bits of the network are all at roughly the same height so concentrating the signal into a flat disk makes sense.
That doesn't work with a plane flying around in 3 dimensions. The FPV guys who use passive higher gain transmitter antennas have to be very careful to orient them to get good signal strength because of this.
jj604 is online now Find More Posts by jj604
Old Aug 10, 2014, 09:51 PM
FOX ONE!'s Avatar
Joined Aug 2008
OK, got it, Thanks.
Cool Picked this up at the post office last night. The Quanum 2.4ghz lipo telemetry unit cryhavoc38 Batteries and Chargers 282 Dec 11, 2012 08:26 PM
Discussion Quanum battery voltage telemetry - and 'voltage under load' question ... JJJNYC Batteries and Chargers 40 Dec 15, 2010 08:45 PM
Question Quanum 2.4ghz Telemetry DjBac Batteries and Chargers 21 Nov 29, 2010 02:43 PM
Alert $70 BUCKS! Quanum 2.4Ghz voltage telemetry (1km Range) jet-ster Foamy EDFs 42 May 27, 2010 11:54 PM
Discussion quanum 2.4 ghz telemetry sellman Electric Plane Talk 3 Mar 29, 2010 11:00 AM
