Old Apr 06, 2009, 08:16 PM
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Question
5mm shaft prop saver - where can I get one?
I would like to get a prop saver adapter for a 5mm shaft. I can't find any. Does anyone know of a source?
About to give up...
Rob
Bombay is offline Find More Posts by Bombay
Old Apr 06, 2009, 08:51 PM
Crossville, TN
Joined Dec 2004
Rob, www.headsuprc.com has them for less than 4.00. Go to adapters pg.2 on their website. 2.00 shipping no matter what you buy. FWIW. art
Art Schmitz is offline Find More Posts by Art Schmitz
Old Apr 06, 2009, 09:05 PM
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Hi Art. Thanks for the reply. What am I missing? This is one of my main sources of rc stuff, but I don't see a prop saver for a 5mm shaft. The largest Jeff carries is a 3.17mm
http://www.headsuprc.com/servlet/the...ers/Categories
Old Apr 06, 2009, 09:10 PM
Closed Account
Joined Aug 2007
After a quick search, I didn't find any on Google either. Usually motors with 5mm shafts are 1+ horsepower, so a prop saver wouldn't be safe to use for that application.
All I found was this thread:
http://www.rcgroups.com/forums/showthread.php?t=826230
Good luck, Dave
eagle777 is offline Find More Posts by eagle777
Old Apr 06, 2009, 09:26 PM
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Yep, I am in the same predicament. The motor is just your standard parkflyer motor, but with the 3-point adapter needed to mount the prop at the "correct" end for my application, the shaft ends up being 5mm.
It sounds like the wing-nut idea might work, but I wish I could find a regular one.
Rob
Old Apr 06, 2009, 09:32 PM
Crossville, TN
Joined Dec 2004
3.75 .....on page 2 under PROP ADAPTERS. Just re-checked... art
Old Apr 06, 2009, 09:47 PM
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Yep, but that is not a prop saver adapter. It is your standard collet.
http://www.headsuprc.com/servlet/the...for-5mm/Detail
I am looking for one of these...that fits a 5mm shaft.
http://www.headsuprc.com/servlet/the...r-3.0mm/Detail
Old Apr 06, 2009, 10:16 PM
Crossville, TN
Joined Dec 2004
Rob, Sorry for the bum steer..gotta learn to read better. art
Old Apr 06, 2009, 10:34 PM
WARNING: May contain spam
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
5mm shaft should be on a motor that can put out nearly 700 watts, which, if I'm right, would rip any type of rubber band/rubber o-ring to shreds upon powerup, sending your prop through airspace, possibly casuing harm to you, or others.
Haven't found a prop saver that big yet.
Xpress.. is offline Find More Posts by Xpress..
Old Apr 06, 2009, 10:39 PM
Closed Account
Joined Aug 2007
I think Bombay just wants one for his 150-200 watt motor with a 5mm radial mount adapter.
Old Apr 07, 2009, 04:29 AM
Bombs away! Err...landing
Ira NZ's Avatar
Upper Hutt, New Zealand
Joined Apr 2006
Interesting, my motor with a 5mm shaft is only 250 watts.
Ira NZ is offline Find More Posts by Ira NZ
Old Apr 07, 2009, 08:19 AM
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Try max 150 watts. Right, it is a 3-point or radial mount adapter. It is for a 2830-09 motor...850kv. The manufacturer of the motor (so I am told) does not recommend reversing the shaft on this particular motor. Anyway, I went ahead and ordered a few extra radial adapters as a sub for the prop saver, but I would like to find a source for the savers in 5mm.
Old Apr 07, 2009, 08:53 AM
USA, WV, Moundsville
Joined Oct 2006
just get this one and bore it to 5mm or take it to a machine shop and ask them to do it.. most will drill it out for nothing...
http://www.bphobbies.com/view.asp?id...02&pid=V916781
turbored21 is offline Find More Posts by turbored21
Old Apr 07, 2009, 11:21 AM
Xpress..'s Avatar
Joined Oct 2007
Ahh, much smaller than the 5mm shaft made it out to be.
Switchback:where can I get one? MTwallet Parkflyers 27 Nov 01, 2002 09:59 PM
Graupner EDF, where can i get one? Paranoia Electric Ducted Fan Jet Talk 3 Sep 06, 2002 05:23 PM
GWS Zero - How Much does it cost & where can I get one? mrebman Parkflyers 4 Apr 27, 2002 10:03 PM
alienator: where can i get one? hammertime Foamies (Kits) 2 Oct 31, 2001 11:35 AM
Sky Scooter Throws Prop Adapter - Where can I get another one? mrebman Foamies (Kits) 3 Jul 16, 2001 12:19 AM
