Old Mar 16, 2009, 08:21 AM
Indiana
Joined Feb 2009
Evolution Engines Trainer Power System 46
While in flight, or sometimes take off the engine quits, any suggestion on how to correct this problem? Thanks.
takeoff1 is offline Find More Posts by takeoff1
Old Mar 16, 2009, 09:10 AM
Airplane Gearhead
Central N.Y.
Joined Jan 2005
Well... we need a few more details first...
It could be too lean...(probably) or too rich...or you might have an air leak...etc. etc.
What are the symptoms...what does it sound like just before it quits?
proptop is offline Find More Posts by proptop
Old Mar 16, 2009, 12:11 PM
Joined Jan 2004
If the high speed needle is too lean it can cause dead sticks
Or if the low speed needle is too rich fuel can build up in the crank case and cause a dead stick.
Have You read this
How to set/tune your engine http://www.rcgroups.com/forums/showthread.php?t=205602
MrGreenSpeed is offline Find More Posts by MrGreenSpeed
Old Mar 17, 2009, 08:45 AM
Indiana
Joined Feb 2009
No I haven't read that. I'll look into it. Thanks.
Old Mar 17, 2009, 09:00 AM
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
The Evolution 46 engine has a limiter on the high speed needle, you only can adjust it about 1/2 turn.
http://www.evolutionengines.com/Prod...nualUpdate.pdf
Before you do anything, you should check the glow plug, if the coil is distorted or looks odd in any way, change it - before you go tweaking needles.
Hemikiller is offline Find More Posts by Hemikiller
Sold Evolution trainer power system pyrobus Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 14, 2008 04:51 AM
Sold Evolution Trainer Power System (.46) Nate129 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 06, 2005 06:56 PM
Another UCD 46 power system ? Ron Sport Planes 0 Oct 07, 2004 12:08 PM
Question Suggestions for an affordable power system for a 5 to 6 pound trainer ? Neo-eflyer Power Systems 1 Jun 21, 2004 05:03 AM
micro hydrocarbon engines...future power system? e-sailpilot86 Power Systems 9 Oct 08, 2001 11:36 AM
