Old Oct 02, 2012, 03:01 PM
Joined Feb 2012
Help!
CRIUS PRO with ArduCopterNG V2.7R1a by JLN on Y6: just 4 motor outputs working
Hi-
got SW installed (with PPM sum on Throttle), seems to work.
On mission Planner outputs for all channels Ch1 - Ch6 give reasonable values BUT only 4 motor outputs work physically.
Checked with Scope- 2,3,5,6 give PPM signals (also ESCs work here...),
others all non- functional.
Tried to change APM_Config.h CONFIG_CHANNELS CHANNEL_CONFIG_CUSTOM no difference.
Is my board (other outputs) dead? Is there a test routine I can flash to the processor to have "some" signal on all pins so I can check with the Scope?
All help would be really appreciated.
THANKS
Roman
P.s.: my huge & expensive Y6 frame needs a brain- PLEASE
RQuad is offline Find More Posts by RQuad
Old Oct 03, 2012, 07:32 AM
Joined Feb 2012
just checked: it is not the hardware..
DigitalPin7 and 8 are capable of generating a PWM output on my board...
Old Oct 03, 2012, 03:02 PM
Joined Feb 2012
ISSUE SOLVED
it indeed had to do with the motor mapping- the new FW 2.7 R4 hekped (it sayed: motor mapping changed ;-)
Discussion Crius LCD (Serial LCD v1.03) doesn't work with MultiWii 2.1? xoxota Multirotor Electronics 1 Nov 14, 2012 06:19 AM
Question One ESC output on my HFpro board stopped working Adidas4275 Hoverfly Technologies 9 May 07, 2012 10:27 PM
Discussion Yaw issue with 4.0 upgrade on x8 and Y6 tahoelight Hoverfly Technologies 11 May 04, 2012 02:37 AM
Help! Help with 4 CH 2.4GHz BlitzRCWorks F5-E Swiss V2 Pro SemperFiSC Electric Ducted Fan Jet Talk 4 Mar 17, 2012 01:52 AM
Discussion will Solo pro V2 RTF TX work on Solo PRO 328 andione1983 Micro Helis 0 Feb 05, 2012 09:12 PM
