Old Jul 01, 2013, 02:43 AM
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
A bit tail heavy?
Up&Away is offline Find More Posts by Up&Away
Old Jul 01, 2013, 03:06 AM
Loose Sox Special Spec
LooseSox's Avatar
Australia, SA, Modbury North
Joined Feb 2012
Was a bit nose heavy for maiden flight. Didnt really have a chance to enter a spin, it all went bad on climb out, I was only about 30 feet off the deck.
LooseSox is offline Find More Posts by LooseSox
Old Jul 03, 2013, 12:00 AM
LooseSox's Avatar
Joined Feb 2012
Well I've noticed a little crack in a few places on the wing
TOTAL REBUILD TIME
Just because I can, I'm seriously thinking of covering the wing with carbon fiber (stock covering already removed for repair work) and painting the fuse bright pink. Should definitely make a statement at the field! All my current fleet is grey or camo so looking for something a bit left field.
Old Jul 07, 2013, 03:48 AM
LooseSox's Avatar
Joined Feb 2012
Well here are some progress shots of the resurrection!
Here's the fuse all back together with all the cracks/gaps filled in
I wasn't happy with some of the finish on the fuse originally so I gave it two heavy coats of spray putty then blocked it back all the way just to fill in some of the low spots.
It's now sitting in the shed with the first coat of primer on it. More pics to follow later
Sold Omega II 1.8M elec wing and more (sold pending funds) jnjloo Aircraft - Sailplanes (FS/W) 17 Apr 09, 2008 09:02 PM
Wanted WANTED: Omega 1.8M Wing Joiner Rod ropuri Aircraft - Sailplanes (FS/W) 4 Mar 04, 2008 05:58 PM
Sold Omega/Fly Q/Dreamline 1.8m Poly Wing Set screamin' eagle Aircraft - Sailplanes (FS/W) 2 Sep 03, 2006 11:27 AM
Found Omega/Fly Q/Dreamline 1.8m Aileron Wing Set screamin' eagle Aircraft - Electric - Airplanes (FS/W) 1 Jun 29, 2006 01:43 AM
Omega 1.8M Wing Servos RSturtevant Electric Sailplanes 1 Feb 06, 2003 07:27 PM
