Old Nov 29, 2009, 12:17 PM
Mk 9 Lunatic
Atra's Avatar
Perth Western Australia
Joined Sep 2008
Painting EDF fuses
I'm looking at painting my HL Rafale something other then grey. Anyone had any successes or failures with certain brands of paints that were supposed to be foam friendly?
Atra is offline Find More Posts by Atra
Old Nov 29, 2009, 12:21 PM
United States, CO, Colorado Springs
Joined Jul 2004
put a couple of coats of polycrylic to cover the foam and paint it with any paint you want. if you dont then you will have to use water base paint and an airbrush.
smoothb10 is offline Find More Posts by smoothb10
Old Nov 29, 2009, 04:16 PM
"Jesters" KC-135 Demo Team
kc135boomer's Avatar
United States, MI, Ypsilanti
Joined Sep 2005
I use Krylon. Just use very light coats and the paint will not eat the foam.
kc135boomer is offline Find More Posts by kc135boomer
Old Nov 29, 2009, 09:39 PM
HB Addict's Avatar
Fort Collins, Colorado
Joined Mar 2007
I have used both the water based spray Krylon and waterbase brushed polycrylic prior to using any spray paint. I prefer a base coat of waterbase brushed polycrylic at it makes the surface more resistant to scratches etc. I also didn't like the way the water based spray Krylon flowed out but like boomer said multiple thin coats works. Best of luck.
HB Addict is offline Find More Posts by HB Addict
Old Nov 29, 2009, 09:47 PM
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
I polycrylic my planes, lightly sand them smooth, repeat and then airbrush them with Apple barn water based paints (thinned with Windex) from Wally World. Then apply a light coat of clear matte finish (or gloss if you like) to seal the paint and add a little extra protection for belly flopping.
ATIS is offline Find More Posts by ATIS
Latest blog entry: maxford Nieuport 1/5th Scale
Old Nov 29, 2009, 10:24 PM
I make bad look so good.
SteveC68's Avatar
League City, Texas
Joined Sep 2006
I airbrush them with Deltacrome acrylic paints from Micheals or Hobby-Lobby ($0.70 each) craft stores thinned with denatured alcohol.
SteveC68 is offline Find More Posts by SteveC68
Old Nov 29, 2009, 11:04 PM
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
All the above techniques work.
I find the MINWAX Polycrylic brushed or sprayed from a can makes a good sealer. Then lightly degloss prior to painting with any paint you want. Two coats is a good idea to make sure you don't bleed through.
I have also filled in the foam surface using solution of Durhams water putty and lightweight spackle thinned so you can brush it on with a foam brush. Two coats sanded between coats then you can seal with Minwax WB Poly or use Krylon H20 primer to seal the surface. Below is Sapac F22 Military Jet I used the technique on. My base color was Duplicolor acrylic enamel (car paint) and the top coat was Duplicolor clear. The fluorescent orange stripes are from a Krylon spray can.
Prof100 is offline Find More Posts by Prof100
Old Nov 30, 2009, 09:15 AM
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
Testors spray cans at your LHS work great on foam. No issues.
I find the flat paints to come out nicer... but that could be related to my lack of painting skills!!
Smokescreen38 is offline Find More Posts by Smokescreen38
Old Nov 30, 2009, 09:29 AM
Keep calm and don't blink
KiwiKid's Avatar
Hamilton, New Zealand
Joined Jun 2005
Some background info on how I painted my TA-4K is in a blog entry here:
http://www.rcgroups.com/forums/showthread.php?t=966521
KiwiKid is online now Find More Posts by KiwiKid
Latest blog entry: SLS for the Calypso Cobra
Old Nov 30, 2009, 10:02 AM
kriss poppe's Avatar
Joined Aug 2009
You can also airbrush Tamiya paints.I use the Tamiya gray primer out of the can,the airbrush what ever color I need.
kriss poppe is offline Find More Posts by kriss poppe
Old Dec 09, 2009, 10:29 AM
chessmaster's Avatar
Colorado
Joined Oct 2008
Not to thread jack,but I was wondering. When you paint a foam plane how much weight does it add to the plane. Is it noticable in the perforance of the plane.
thanks
chessmaster is offline Find More Posts by chessmaster
Discussion Fuses and Overload Protection Lamedico Coaxial Helicopters 19 Sep 26, 2009 07:12 PM
For Sale HLG, 2M, and Open class fuses and cores Jim Frahm Aircraft - Sailplanes (FS/W) 7 Sep 24, 2009 12:31 AM
