Old Apr 10, 2013, 02:33 PM
Joined Feb 2013
Monokote or Ultrakote?
Hello everyone, Im sure this has been asked before but i am unable to find the thread.
My question is whether you prefer monokote or ultracote and why.
Thanks everyone
Alex
airbatik is offline Find More Posts by airbatik
Old Apr 10, 2013, 03:05 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
I've always preferred UltraCoat because it would go around corners easier...but I've heard MoneyKote has had a change in materials, making it easier to work with than the old stuff.
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: Is it possible to lose weight?
Old Apr 10, 2013, 03:11 PM
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
I've used ultracote in the past and liked the adhesive characteristics before heat is applied, as it helps with propositioning of the pieces. But have switched to monokote for no other reason other thank cheaper cost and LHS availability. The two material have different activating temperature, so once you figure out the optimal setting, they are both easy to work with, with similar results.
Steph280 is offline Find More Posts by Steph280
Latest blog entry: Multicopters
Old Apr 10, 2013, 08:31 PM
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
Ultra is thinner so seams are much harder to detect assuming they are pointing down and its just as strong. Much easier around compound curves and much easier to get a wrinkle free finish... IMO having used both.
As stated... some years ago Mono changed the formula or something.. but it used to be just as easy to apply as Ultra.
Thermalin is offline Find More Posts by Thermalin
Old Apr 11, 2013, 03:33 PM
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
If you plan on keeping your plane around longer than a year or so, use Ultracote. I have had (as well as others at our field) issues wiht Monocote shattering after a year or so.
rcav8r2 is offline Find More Posts by rcav8r2
Old Apr 11, 2013, 04:26 PM
United States, MI, Vassar
Joined Jan 2006
I use to use monokote till they changed it. The new stuff doesn't shrink well unless pulled real tight when installing. That is hard to do on open structures. It also wrinkes easy by temperature changes. Try the chinakote at HK. There are places that sell it for about 1.23 a meter also. I won't pay there prices for monokote, black baron, or ultrcote films after using the chinakote. 5 meters for 8 bucks at HK. Good stuff.
Beardiedrg is offline Find More Posts by Beardiedrg
Old Apr 11, 2013, 05:46 PM
Dragons, Windmills. All Same.
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
I use to prefer Monocote for open structures and Oracover/Ultracote for sheeted foam cores surfaces decades past
Now a days, Utracote for almost all.
Jared
jcstalls is offline Find More Posts by jcstalls
Old Apr 11, 2013, 06:28 PM
Leander, Texas
Joined Sep 2003
Ultracoat. I dont use money coat anymore.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Apr 11, 2013, 06:51 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
As I said earlier, some people have stated the NEWEST Monokote is a big improvement over the materials that we have had to endure these past couple of years...almost is making me TRY the newest stock!
Old Apr 11, 2013, 07:13 PM
Where's the lift?
dgliderguy's Avatar
United States, WA, Snohomish
Joined Mar 2001
Ultrakote may be easier to apply, but it goes chalky with repeated wipe-downs, where Monokote retains its glossy finish a lot longer.
Monokote also comes in a wide variety of colors, where Ultrakote is more limited in color selection.
I have seen transparent red Monokote shatter like glass with a sharp impact. Some say other Monokote colors will do this, too. Ultrakote keeps its resiliency longer.
Monokote has more of a tendency to bubble up in the hot sun. Ultrakote will fade from UV exposure after a season or two. Ultrakote goes on at a lower temperature, so you can cover foam with it if you like. Pick your poison.
I'm going to be trying Hobby King chinakote soon, and I hear all good things about it (beyond just the amazingly affordable price!).
dgliderguy is offline Find More Posts by dgliderguy
Old Apr 13, 2013, 04:28 PM
cbarnes0061's Avatar
United States, VA, Petersburg
Joined Mar 2012
Agreed on the cheap chinakote from HK works great. You twice as much for half the price of monokote.
cbarnes0061 is offline Find More Posts by cbarnes0061
Found monokote or ultrakote rcrick10 Aircraft - General - Miscellaneous (FS/W) 2 Jan 13, 2012 07:39 PM
Sold Monokote, Ultrakote and Hi-Tec Servo Plasmajoe Aircraft - General - Miscellaneous (FS/W) 1 May 08, 2011 05:41 PM
Discussion Ultrakote/ Monokote cutting and preping? hidaven Electric Plane Talk 5 Mar 10, 2011 01:54 PM
Discussion How To Seal MonoKote & UltraKote??? JCinTEXAS Painting and Finishing Tips 1 Mar 27, 2008 12:29 AM
Discussion Reparacion (UltraKote, Monokote) joche Mexico 10 Feb 29, 2008 02:24 PM
