This thread is privately moderated by my c210, who may elect to delete unwanted replies.
Old Mar 19, 2013, 02:56 AM
scrub monkey is offline
Find More Posts by scrub monkey
use the 4s luke, use the 4s...
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
i found that the screws just dont go down far enough to hold the wire that i was using for the push rods. also with the plastic ends for the keepers it alows me to change them easily if i have to change the throws mechanically. i have only used the dubro ones but if i can find knock off that are similair and are half decent (not to mention cheaper) then id definately use them.
scrub monkey is offline Find More Posts by scrub monkey
Old Jan 24, 2015, 06:15 PM
Prboz is offline
Find More Posts by Prboz
Joined Feb 2005
I always head off to my local copy place and have my plans scanned into a PDF I if I ever wreck them I just get a new copy printed. Saves for headaches later. Even have the second set printed and use them not the originals. My 2c worth
Prboz is offline Find More Posts by Prboz
Old May 18, 2015, 10:34 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
I have switched to parchment paper as a plans protector some time ago. I have used ultracote backing paper as well as the monokote backing but run out of it.
Rubber bands and pins make execelent clamps for LE wing skins while it's still on the board.
Painters tape also makes for a good clamp of off pieces.
Harbor Freight sells all sorts of plastic hobby sized clamps CHEAP.
Thermalin is offline Find More Posts by Thermalin
Old Jun 02, 2015, 03:51 AM
Panaplazacar
A moderator felt this post violated the following rule: Redacted Content.
DAW Extra - Building Tips? Sal C Foamies (Kits) 27 Sep 26, 2001 09:08 PM
Simple 400 Building Tips? 99esq High Performance 4 Sep 10, 2001 07:07 PM
Kavan Parnetavia building tips cruzomatic Foamies (Kits) 28 Sep 09, 2001 09:36 PM
Wattage F-22 Building Tips / Pictures rcfanatic Foamies (Kits) 9 Sep 08, 2001 02:25 PM
IFO Mark3: Any last minute building tips ? volt flyer Parkflyers 13 Jun 21, 2001 03:33 PM
