Old Nov 28, 2005, 11:46 AM
dogga22 is offline
Find More Posts by dogga22
dogga22's Avatar
Abington Ma
Joined Feb 2005
3dbatics extra 330 2nd flight
Hi Guys
here is a quick vid of my 2nd flight w/my extra 330 (love this plane )
rimfire 22/1000 motor
bl-8
hs-55
electron-6
640 mah batt
10x3.8 prop
http://media.putfile.com/extra330
hope the link works
dogga
dogga22 is offline Find More Posts by dogga22
Old Nov 28, 2005, 03:20 PM
Boss248 is offline
Find More Posts by Boss248
ProBro # 501
Boss248's Avatar
Austin Tx
Joined Jul 2005
Nice flying there dogga..the 330 is a real favorite of mine...it does everything I want to do and almost makes me look like I know what I am doing,,, Did the rimfire have pretty good pull..?
Boss
Boss248 is offline Find More Posts by Boss248
Old Nov 28, 2005, 03:59 PM
dogga22 is offline
dogga22's Avatar
Abington Ma
Joined Feb 2005
tx boss
the rimfire has some good pull w/ a full charge// hard for me to compare
i only have rimfires in all of my planes//ultrafly furious//gp turmoil//hl yak-55
it has the best power on the yak.i guess its lighter???
the extra is now my fav plane hovers better than anything i have///but i think
a little more power would be good
dogga
Old Nov 28, 2005, 05:26 PM
JoeRC is offline
Find More Posts by JoeRC
Mouth of the Midwest
Joined Mar 2003
Dogga, what's your All Up Weight? And, are you using a 2 or 3 cell?
JoeRC
JoeRC is offline Find More Posts by JoeRC
Old Nov 28, 2005, 05:43 PM
dogga22 is offline
dogga22's Avatar
Abington Ma
Joined Feb 2005
not sure on the weight joe i do not have a scale yet ( not even sure what kind to get) it would be nice to have an idea what all my planes weigh
i use a 3 cell 640 mah batt from great planes. i think the next batt i will get a higher mah///with the 640 i get around 6 to 10 min or so
dogga
Old Nov 28, 2005, 05:51 PM
Boss248 is offline
ProBro # 501
Boss248's Avatar
Austin Tx
Joined Jul 2005
Dogga..I think I pay about $30.00 for a ounce/gram digital scale at office depot..it will weight up to 4lbs. in .1oz and 1/10gram incriments something like that.. anyway it works great and is almost a must have.
I thought you were liking the 330 from the stuff you were doing in the vid. I am going to do a 3mm. version of it sometime this winter just for grins.
Boss
Old Nov 28, 2005, 06:53 PM
dogga22 is offline
dogga22's Avatar
Abington Ma
Joined Feb 2005
tx for the info boss i will ck out office depot for that scale
ya the 330 is a fun plane//stable//it is my first plan built plane i think it came out ok.a little on heavy side (once i get a scale i will know for sure) used hot glue for all the joints and used left over flatouts hardware on it//push rods//z-bends//servo arms all that good stuff
tx
dogga
Old Nov 29, 2005, 07:38 AM
r/cdawg is offline
Find More Posts by r/cdawg
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
dogga22,
Nice video, great flying, and ELO. Sweet.
dawg
r/cdawg is offline Find More Posts by r/cdawg
Old Nov 29, 2005, 08:06 AM
dogga22 is offline
dogga22's Avatar
Abington Ma
Joined Feb 2005
thanks man,
i still have alot to learn//only been flying for about 6 months but i did put alot of time on real flight g3 that helped getting a feel for it. who needs a trainor
just get a foamy .
dogga
Old Nov 30, 2005, 04:20 PM
Ben-Rod is offline
Find More Posts by Ben-Rod
HOW HIGH DOES IT GO???
Ben-Rod's Avatar
Jacksonville, Florida
Joined Nov 2004
Nice job on your plane, looks like your having fun with it. One of my all time favorites. Sure it will be one of yours too.
Ben
Ben-Rod is offline Find More Posts by Ben-Rod
Old Dec 01, 2005, 09:23 AM
dogga22 is offline
dogga22's Avatar
Abington Ma
Joined Feb 2005
540 conversion
tx ben
do you know if there are any plans for the edge 540 conversion??
i know i had seen some posts about it but i wasnt sure if there were any plans. i have some extra foam i would like to use now that it is getting to cold to fly .
dogga
Old Dec 01, 2005, 11:37 AM
Ben-Rod is offline
Ben-Rod's Avatar
Joined Nov 2004
Originally Posted by dogga22
tx ben
dogga
No there arent any plans for it but its very easy to do.
1- Lay out the wing and use a stright edge and draw a stright line across the wing.
2- Trace the servo hole and tab slot for the fuse, also trace the center part of the trailing edge.
3- Measure the wing tips of the 330. From the leading edge of the 540 make a mark so the wing tips on the edge and the 330 have the same measurement.
4- Connect the lines between the wing tips to the center part of the trailing edge.
5- The ailreons are the same at the tips as the 330, but get a little wider as you get closer to the center of the trailing edge.
6- The fuse is the same except the canopy gets moved back a little and reshaped to resemble the edge
7- Take 1/2 inch off the vertical stab and add to the counter balance part of the rudder surface.
8- Shape the rudder to resemble the edge, and your done everything else was left the same as the 330.
These suttle changes really work out to make another great flying foamy. Hope I didn't make it too confusing as it really is very simple. Good luck and try it you'll like it for sure...
Ben
Old Dec 01, 2005, 12:06 PM
dogga22 is offline
dogga22's Avatar
Abington Ma
Joined Feb 2005
thanks for the info ben. i should be able to do that no prob. i should be starting that project in a week or so i will let u know how goes
thanks one more time
dogga
Discussion DUDE Extreme Flight 2830/1095 EXTRA 330 MINI FLITON maxboy 3D Flying 3 Jun 08, 2006 04:41 PM
Electro-flight Extra 330 Built thread ecologito Foamies (Kits) 10 Jan 29, 2005 06:10 PM
2nd flight performance? jrb Electric Plane Talk 2 Aug 08, 2001 12:45 AM
2nd Flight and 1st landing Whizzler Beginner Training Area (Aircraft-Electric) 3 Jul 12, 2001 02:10 PM
Extra 300S First Flight Jedd Foamies (Kits) 11 Jun 06, 2001 08:42 PM
