Old May 29, 2015, 12:07 PM
Colonel Blink is offline
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Build Log
Corsair Glider for SOS Build Off 2015
Here it is – my bowler being lobbed into the SOS Build Off ring; admittedly it was a long throw from the bench where the KK Bandit is still being produced but it is as they say, a peg in the ground.
I have chosen John Holt’s Corsair from the June 1953 Aeromodeller for reasons that I have mentioned before in the SOS ‘kick off’ thread – but the main ones are its simplicity and apparent robustness. According to the AM article, the original(s) were well placed in several competitions and so one is hoping for a sure flyer. The model is a fairly solidly built, relatively low aspect ratio design, as can be seen in the article header photo, where (presumably) Mr Holt holds it aloft whilst doing a passable impression of Frank Spencer of Some Mothers Do ‘Ave ‘Em.
Having downloaded the plan and article from the splendid Outerzone, I did realise that I actually have a full sized copy of the plan anyway. However, the Outerzone pdf enabled me to import the plan into DraftSight and trace it, making sure that the wing halves were identical, that the rib lengths matched the wing plan etc etc – ie correcting the little things that can either be the joy of or the irritation of building from Vintage plans, depending upon your outlook. I admit to falling into the latter camp….
Some changes will be made – it will be electric and R/C and I am also considering some other slight changes, and I intend to discuss these in the coming posts. But CAD design work is ongoing!!
Colonel Blink is offline Find More Posts by Colonel Blink
Old May 29, 2015, 01:55 PM
Sundancer is offline
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Looking forward to following another of your entertaining build logs Colonel.
Sundancer is offline Find More Posts by Sundancer
Old May 30, 2015, 06:24 AM
rabidrue1 is offline
Find More Posts by rabidrue1
Blueplaidcanard flyer
sdy. ny
Joined May 2007
This ought to be a good one.
rabidrue1 is offline Find More Posts by rabidrue1
Old May 30, 2015, 02:10 PM
foamdave is offline
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
I agree. It will be a good one.
Dave-
foamdave is offline Find More Posts by foamdave
Old Jun 02, 2015, 01:48 AM
Joined Nov 2008
Let's hope so!!!
Now some points for discussion:
a) The aerofoil as drawn is a significantly undercambered one, which should be good for slow flight (which I like), but I understand that an Eppler 305 has a better glide performance. It also has the added advantages of being easier to build for a duffer like me - on the original, it looks to me like the lower spars could only be added after the wing has been lifted from the board. I feel this is likely to allow inaccuracies to creep in. But as can be seen from the pic below, the chord line of the E305 has a greater AoA with respect to the surface on which it sits - this will mean that the fus top will need a slight redesign in order to keep at least the incidences of the original. What are people's views - E205 or undercambered original?
b) Whilst we're on the subject, the original has the wing (chord line) set at 4° to the longitudinal datum, and the (lifting) tailplane at 1.8° (LE high - is that +ve or -ve for the tailplane?) giving a total of 2.2° difference - does that sound OK for it's intended use as a motor glider?
c) The other thing I have been mentally wresting with is the rudder and elevator design, and the proportions thereof. I rather fancy a single elevator for simplicity, but not sure if the elevator I have drawn is big enough. I realise that being primarily a glider, the control surface proportions need to be larger than on a power model due to the lack of propwash, but I'm not sure by how much. I'm sure George will suggest an AMT, but I would like to keep it as simple as possible.
d) The proportions of the model give approximately a 2:1 longitudinal ratio, nose to CG to tail. I think this means that I can mount 5g servos in the back end to counteract a fairly heavy motor and battery in the nose. I am wondering whether mounting the elevator servo in the tailplane could then mean that I could have a radio-operated D/T activated by one of the flick switches on the DX6i, which could be fun.....
I now invite comments from the floor (please get up, you're not that drunk....!)
Last edited by Colonel Blink; Jun 05, 2015 at 08:01 AM. Reason: Corrected E305 to E205!
Old Jun 02, 2015, 03:21 AM
DaveB69 is offline
Find More Posts by DaveB69
United Kingdom, Scotland, Dalkeith
Joined May 2015
For the original aerofoil, could you prop the lower spars up on strips of wood/whatever to the correct height, or just glue the ribs to the bottom spars freehand and then pin the whole lot down to finish it.
Dave.
DaveB69 is offline Find More Posts by DaveB69
Old Jun 02, 2015, 04:11 AM
owlsabie is online now
Find More Posts by owlsabie
owlsabie's Avatar
South Africa
Joined Feb 2009
Interesting question Colonel, I feel your pain with the undercambered wing! For my one I'm going with an Eppler 205 its supposed to be a good aerofoil, and I don't think you can wrong there. As you say, it will be much easier to build accurately!
owlsabie is online now Find More Posts by owlsabie
Old Jun 02, 2015, 05:27 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Originally Posted by Colonel Blink View Post
Let's hope so!!!
a) The aerofoil as drawn is a significantly undercambered one, which should be good for slow flight (which I like), but I understand that an Eppler 305 has a better glide performance. It also has the added advantages of being easier to build for a duffer like me - on the original, it looks to me like the lower spars could only be added after the wing has been lifted from the board. I feel this is likely to allow inaccuracies to creep in. But as can be seen from the pic below, the chord line of the E305 has a greater AoA with respect to the surface on which it sits - this will mean that the fus top will need a slight redesign in order to keep at least the incidences of the original. What are people's views - E305 or undercambered original?
Right Colonel, let's get to it! Your Eppler section would be a perfectly viable choice in place of the original; as you say it would be easier to build (and cover), although as suggested packing up the bottom spar would be an easy solution to the building part. The model will fly fine with either section - just differently. A bit quicker with the Eppler and better penetration of a breeze, slower and more "floaty" with the original, your choice really. As Owl says I would personally prefer E205 (or E193 with the SLIGHT undercamber deleted) or RSG29 as a substitute.
The incidence settings sound perfectly reasonable, at least as a starting point, for either section.
Your suggested rudder looks perfect. With regard to the elevator, I wouldn't dream of pressurising you into an AMT, indeed the layout of the tail end would make it (unlike my Lulu) quite tricky, if going with an AMT on this one I would be looking to do a rocking cradle with a "as per" tailplane strapped on top. Your elevator proportions look OK, but I would make it a double sided elevator of the same proportions, simply a matter of a wire in tube joiner.
The nose is long enough so that with the motor up front and the ability to shift the lipo for balance there should be no problem with 5 gram - or even 7 or 9 gram - servos at the back. Don't forget you only need to run four wires, 2 signal plus common +ve and -ve.
A radio operated D/T might be fun, but it'll need to be reversible though, not just a one shot option.
All just personal views, just go with what feels right, enjoy the build and I'm sure all will be well.
Old Jun 02, 2015, 06:17 AM
Joined Nov 2008
Dave / Al / George:
Thanks for the input!!!
I will be using the Eppler - partly because that's what has already been drawded up , but also because I would like some wind penetrating ability. Also, I believe that to build with the original aerofoil, it would not just be a case of packing up the main spar and lower secondary spars - if you look closely, they are positioned 'normal' to the undersurfacce - ie the mainspar leans forward and the secondary leans back - which apart from being awkward to pack correctly, would make it very difficult to slide the ribs on. Hence my comment about building ribs, LE, TE & upper spars, and adding the lowers after lifting from the board.
Re the D/T - I'll admit that I was indeed thinking of a one shot wonder just for the fun of showing off in still air & low altitude, rather than using it as its original intention - after all one could presumably drive it out of a thermal with the RC. But a reversible option would add weight and complication. so perhaps its better to just leave it!!!
Old Jun 02, 2015, 06:25 AM
sdy. ny
Joined May 2007
A radio operated D/T is doable,when I get a bit of time I'll draw up the linkage and post a photo of a workable set up I've used.To use the D/T you may need to move the rudder servo from the tail to under the wing.The elevator servo is right where it needs to be for the D/T setup.
Old Jun 02, 2015, 07:43 PM
JeffMac is offline
Find More Posts by JeffMac
I'd rather be flying.....
JeffMac's Avatar
United States, IA, Story City
Joined Oct 2013
Colonel I'm looking forward to your Corsair build !
Your choice of the E305 or 205 ? is sound, of course.
Best Regards,
Jeff
JeffMac is offline Find More Posts by JeffMac
Old Jun 03, 2015, 01:33 AM
Paul_BB is offline
Find More Posts by Paul_BB
Paul_BB's Avatar
France, IdF, Lagny-sur-Marne
Joined Feb 2007
I would choose a modern Coupe d'Hiver airfoil: less penetrating but will hang your model in the air for a longer time. As you said, the E205 makes building a wing faster and easier. And is more penetrating. But there is no arguing about matters of taste.
Paul_BB is offline Find More Posts by Paul_BB
Old Jun 03, 2015, 02:13 AM
Sky Jiver is offline
Find More Posts by Sky Jiver
Sky Jiver's Avatar
United Kingdom, England, Gt Man
Joined Jul 2012
Hi Colonel,
Nothing to add to the discussion E205 or E193 for me, would both be good choices.
KBO in you inimitable style.
Sky Jiver is offline Find More Posts by Sky Jiver
Old Jun 05, 2015, 07:01 AM
sdy. ny
Joined May 2007
I'll still post the D/T set up just in case.
Old Jun 05, 2015, 07:54 AM
Joined Nov 2008
Please do, Scottie - one never knows when these nuggets of information will come in handy!
Discussion Windrush II - SOS Build Off April 2015 to September 2015 cpmcgraw Vintage & Old-Timer Designs 108 Yesterday 06:34 AM
Build Log KK Soarer Baby (2m) for 2015 SOS Build Off RFJ Vintage & Old-Timer Designs 60 Aug 28, 2015 08:06 AM
Build Log Skyleada Amphibian for SOS Build Off April 2015 to September 2015 brokenspar Vintage & Old-Timer Designs 38 Jul 04, 2015 03:05 PM
Build Log Skyleada Scale Gliders - SOS Build Off April 2015 to September 2015 -Balsa- Vintage & Old-Timer Designs 11 Jul 03, 2015 08:17 AM
Build Log Walt Musciano's Nimbus Nudger for SOS Build Off April 2015 to September 2015 brokenspar Vintage & Old-Timer Designs 31 May 07, 2015 06:14 AM
