Old Apr 12, 2015, 08:58 AM
RadioLink is online now
Find More Posts by RadioLink
Joined Oct 2013
Cool
Radiolink AT9 9 channels response parallel for 3ms
Excited flying by Radiolink AT9--XL Model RC (4 min 23 sec)
AT9 2.4GHz 9CH remote control system
Feature
1.Fast response, 3ms only, which is much less than the average 20ms even 9 channels it acts synchronously.
2.Support English & Chinese menu, including helicopter 8 swash plate modes, fixed wing 2 airfoils 3 rears, gliders 4 airfoils and 2 rears. Freely operating any styled aircraft.
3.Programmable mix control. Basic menu, advanced menu, graph view for verities of throttle and servo curve.
4.DSSS&FHSS spread spectrum mode supplies better performance in anti-interference, freefrom1.2G and 5.8G image interference and 433MHz datatransmissioninterference.
5.Adopt two-transmission technology of RadioLink AT10 10CH radio control, support signal strength, receiver voltage monitored, and extending battery voltage, temperature, motor RPM, GPS etc.
6.4096 section precision, 0.25us per section, servo anti-shake rudder.
7.2.8 inches 16 colors LCD resolution 240*320 distinct and magnificent.
8.Actual measurement: ground 900 meters, air 1500 meters.
9.Vibration alarm.
10.Support USB online upgrade.
11.Four VR switches, three three-way switches, four two-way switches, a reset trainer switch. Support multiple aerial control mode and PTZ control.
12.R9D support and compatible with FUTABA S-BUS. No matter for 3 axis control system or aircraft controlling S-BUS, AT9 is perfectly used. No need for too many cables and too much weight.
13.“AIRCRAFE” model type, navigation menu.
14.Mini receiver: 41*23*14mm.
Specification
1.Size: 183*100*193mm
2.Weight: 0.88kg
3.Frequency: 2.4GHz ISM band (2400MHz to 2485MHz)
4.Modulation mode: QPSK
5.Channel bandwidth: 5.0 MHz
6.Spread spectrum: DSSS
7.Adjacent channel rejection: >58dbm
8.Transmitter power: <100mW (20dbm )
9.Operating current: <105mA
10.Operating voltage: 7.4~15V
11.Control distance: more than 900 meters ground, 1500 meters air
12.Channel: 10 channels, 5-10 channels are customizable
13.Compatible model: include all 120 degree and 90 degree swashplate helicopter, all fix wings and glider, five flying models
14.Simulator model: under the simulator model the transmitter action turn off, change to power saving model
15.Screen: 3.5 inches 16 colorful screen, 320*480 pixels
RadioLink is online now Find More Posts by RadioLink
Discussion Radiolink AT9 anybody owns it? Reviews? manatta Radios 109 Today 01:03 AM
Discussion Radiolink AT9 (AT10) jensrichter Radios 20 Aug 28, 2015 04:06 AM
New Product AT9 2.4GHz remote control system--RADIOLINK RadioLink Multirotor Talk 28 Aug 28, 2015 01:16 AM
Cool AT9 2.4GHz remote control system--RADIOLINK RadioLink Electric Heli Talk 1 Sep 28, 2014 09:40 AM
New Product AT9 2.4GHz remote control system--RADIOLINK RadioLink Electric Plane Talk 0 Sep 22, 2014 10:57 PM
