Old Aug 22, 2014, 01:25 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Water consumption with Battery Minder
Havenít been using my deep cycles much; and keep them connected to my Battery Minder ( http://www.northerntool.com/shop/too...2201_200332201 & http://www.batteryminders.com/batter...er-desulfator/ ) in desulfate mode.
Just checked the water level since last fall Ė at/or below the top of the plates.
I didnít think the Minder would cause that much water comsumption; do others see the same?
Here some thread that might be of interest:
http://www.rcgroups.com/forums/showthread.php?t=1468597
http://www.rcgroups.com/forums/showthread.php?t=1460119
http://www.rcgroups.com/forums/showthread.php?t=621277
TIA,
Jim
jrb is offline Find More Posts by jrb
Old Aug 23, 2014, 03:59 AM
desertstalker is offline
Find More Posts by desertstalker
Australia, VIC, Melbourne
Joined Feb 2010
AFAIK desulfation is accomplished by overcharging. Overcharging also causes the cells to split water to H2 and O2, thus why your cells are consuming water.
The charger should have a maintenance (float?) mode, this will keep them fully charged, without excessive water losses.
desertstalker is offline Find More Posts by desertstalker
Old Aug 23, 2014, 11:09 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Any wet cell battery will need electrolyte levels topped off duriing/after charging even with a smart trickle charger. Fluid loss at low charge rates is less than with higher charge rates.
E-Challenged is offline Find More Posts by E-Challenged
Closed thread too fast Battery Minders people look here BVH Non R/C Items (FS/W) 12 Aug 20, 2013 06:24 PM
Discussion Drive battery consumption monitoring with telemetry Blue Bird Radios 9 Aug 21, 2010 11:07 AM
Discussion NiCd battery minder for Tx and Rx robhinze Batteries and Chargers 2 Aug 03, 2010 11:38 AM
Discussion Water Consumption ??? Pibber Dock Talk 2 Jan 31, 2009 12:04 PM
Discussion Battery Minder Plus E-Challenged Batteries and Chargers 5 Apr 02, 2008 12:17 PM
