This thread is privately moderated by Spadplanter, who may elect to delete unwanted replies.
Old Apr 20, 2015, 11:09 PM
webdragon is offline
Find More Posts by webdragon
glider pilot in training
webdragon's Avatar
United States, AR, Searcy
Joined Aug 2006
yet another one for the fleet
webdragon is offline Find More Posts by webdragon
Old Apr 30, 2015, 02:04 AM
Extreme Sports is offline
Find More Posts by Extreme Sports
Extreme Sports's Avatar
South Africa, GP, Johannesburg
Joined May 2012
Originally Posted by robw_london View Post
Looks great, how are the U?C fixed and how is the wing fixed (detail of reinforcing?) thanks
Sorry, I did not see this.
Suggest that I post some details in the 'Beyond yardsticks and gutterpipes' thread so as not to mess with the purpose of this one.
Extreme Sports is offline Find More Posts by Extreme Sports
Old May 09, 2015, 05:09 AM
Stretch1 is offline
Find More Posts by Stretch1
Happiness is a warm ESC.
Stretch1's Avatar
Ballarat Vic. Australia
Joined Jun 2008
New Nitro Delta
Nitro Delta SPAD "Sledge Hammer" aka VFT (Very Fast Triangle)
OS 46 AX II
10X6 APC prop.
3 X Hextronik HX5010 twin bearing digital servos (Elevons + Rudder)
1 X Turnigy 50090M metal gear 9g servo (Throttle)
Spektrum AR6255 Rx
5Cell Eneloop 6V Rx pack
Stretch1 is offline Find More Posts by Stretch1
Old Jun 11, 2015, 02:52 AM
Joined May 2012
Updating a classic
I suspect that many current SPADDERS fondly remember the 1/2A Airtronics Q-Tee that was a very popular first plane in the late '70's and '80's. I decided to give mine an update by building it from correx and converting it to electric. I had to lengthen the nose to get the balance right, and the wing is just a spar-less 'curved plate' made from a single piece of 2mm correx.
Span: 910mm (36")
AUW: 330g
CWL: 5.1
Power: Blue Wonder (1700KV) with an 8x4 prop on a 2S 800mAh Lipo
For comparison, my original balsa version with 1980's gear and a TD .051 weighed in at over 600g. Needless to say, this feels like a very different plane!
QTee in correx 2 (2 min 24 sec)
Old Jun 11, 2015, 11:48 PM
rockyabq is offline
Find More Posts by rockyabq
Envies his own avatar
rockyabq's Avatar
Albuquerque, NM
Joined Apr 2008
Very nice little flier!
rockyabq is offline Find More Posts by rockyabq
Old Jul 18, 2015, 06:23 PM
wildhairman is offline
Find More Posts by wildhairman
United States, TX, Austin
Joined Jun 2010
I'm so delighted to have found this thread. I've been flying SPADs for a couple of years now. A couple of us decided to try them as a way of enticing a fellow flier to build a plane that could deal with his profuse crashing. Started flying combat together with Demons, switched to Dominators, and have built a Debonair for yet another flying buddy who has really slow fingers. Best part about SPADs though is the rapidity with which one can build project planes. This latest one is inspired by the Balsa Nova 40, and I have a 120 size that I'm now flying. My SPAD-A-Nova is related to the Debonair in that it shares the 40" fuse tube, tail feather dimensions and around 800 squares of wing area (wingspan 57"). Maiden flight was Memorial Day weekend 2015, with the Evo 10cc gasser shown. That proved way too weak for the 9lb flying weight, so I swapped in a .91 Surpass with a 14 x 8 prop and that livened it up a bunch. Comes off the ground in about ten feet. With the aid of flaperons coupled to the elevator it does outside loops and snaps just fine with the traditional flat-bottom SPAD airfoil, though this one has been stretched two inches in front and back at the root. The flat pattern layout was wonky looking, but it worked out just fine. The plane doesn't come close to the favorable wing loadings of its balsa namesake, but it'll still hold a knife-edge as long as you want, and lands slower than it has a right to given the weight. Like it's balsa brother the ground handling is rock solid. Turtle deck is 2mm coro, all else is 4mm. Trim markings are all Duck tape and the wheels are off of a baby stroller. I call them my RC tundra tires.
wildhairman is offline Find More Posts by wildhairman
Old Aug 12, 2015, 06:15 PM
SilentArt is offline
Find More Posts by SilentArt
Joined Aug 2015
need to understand what I need to assemble gutter pipe in right way as fuselage...
SilentArt is offline Find More Posts by SilentArt
Old Aug 13, 2015, 11:13 PM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Very nice Wildhair!
SilentArt, if you go to www.spadtothebone.net, all the free plans listed there tell you pretty much step by step how to cut out a gutter pipe fuselage depending on which plane you want to build. Basically, all you need is stick of PVC downspout and then you just cut it out with a hacksaw, dremel tool, or my favorite, a multi-tool.
http://www.harborfreight.com/oscilla...ool-62279.html
http://www.spadtothebone.net/SPAD/De...ge3/page3.html
JohnsPop is offline Find More Posts by JohnsPop
Old Aug 26, 2015, 09:07 AM
Joined May 2012
Avro Vulcan Twin
This one is not a genuine SPAD...it took me about 3 months to build. But it is made from correx. The wings are correx and the fuselage is correx wrapped with 3mm Depron - this makes compound corves possible with a neat finish.
Span: 1.4m
AUW: 1575g
WCL: ~3.1
Power: 2 x Emax 2812 1550KV motors with 8x6 props off a single 2200mAh Lipo.
It's got a lot of presence in the air (and on the ground!)
Old Aug 26, 2015, 12:12 PM
Joined Jun 2010
Well done, Extreme Sports, that's a fabulous looking model! Regardless that it isn't strictly PVC and coro, it does make use of alternate materials and construction techniques. That, I think, is part of the spirit of SPADs.
Old Aug 26, 2015, 05:28 PM
pzanni is online now
Find More Posts by pzanni
Australia, ACT, Canberra
Joined Feb 2013
Let's see the S.P.A.Ds
Amazing work ES! 3 months… how many build hours I wonder???
A two person launch? Look forward to the flight video.
pzanni is online now Find More Posts by pzanni
Gallery Let's see your boats flailing Scale Boats 257 Mar 08, 2012 01:38 PM
Idea Let's see your sloper pics! Ben74 Slope 161 Aug 04, 2005 05:44 PM
Let's see your pilots! DennisG Electric Plane Talk 39 Jun 09, 2003 06:05 AM
Let's see your Pumkins! Troy Life, The Universe, and Politics 27 Nov 07, 2002 11:00 PM
Hey Doug! Let's see a T-6 Texan!!! CheeseWing Parkflyers 9 Oct 13, 2002 01:51 PM
