Old Mar 16, 2014, 01:51 AM
Paul_BB is offline
Find More Posts by Paul_BB
Paul_BB's Avatar
France, IdF, Lagny-sur-Marne
Joined Feb 2007
Question
Which engine equivalent to the Cox .049TD?
Hi,
I am considering building Fred Reese's 1/2A P-51D next winter from a plan found on Outerzone. I built and crashed this plane when I was a teenager (kit from House of Balsa), but at that time I owned a Cox TD .049. Today I can't find one new so I was wondering which engine could replace the Cox. (Brodak?)
Thanks for your inputs.
-Paul
Paul_BB is offline Find More Posts by Paul_BB
Old Mar 16, 2014, 02:38 AM
Amp Abuser is online now
Find More Posts by Amp Abuser
Amp Abuser's Avatar
Joined Dec 2007
There are tons of TD's for sale new and used on Ebay a clean used one will do you just fine.
http://www.ebay.com/itm/VINTAGE-COX-...5#ht_827wt_960
http://www.ebay.com/itm/COX-TEE-DEE-...#ht_177wt_1198
http://www.ebay.com/itm/COX-TEE-DEE-...0#ht_67wt_1198
http://www.ebay.com/itm/Nice-Cox-Tee...ht_2607wt_1198
above are links to 4 up for bid found in less than a min.
Amp Abuser is online now Find More Posts by Amp Abuser
Old Mar 16, 2014, 03:22 AM
Paul_BB is offline
Paul_BB's Avatar
Joined Feb 2007
No I want a NIB engine. This plane needs a very good engine. Have a look at the excerpt from F. Reese's building article below.
Old Mar 16, 2014, 03:58 AM
Amp Abuser's Avatar
Joined Dec 2007
Bare in mind this original plane was flown with larger servo's rx and batteries the weight of the original flying craft will not be as near as light with modern servo's rx and battery.
1/2A P-51D Mustang by Fred Reese 1976 36in span. Any 1/2A in good condition such as the 049 or 051 on 25% nitro will fly it better than Freds 1976 version. A modern carbon/plastic speed prop will out perform all props sold for the TD in 1976. The RX gear will be at least 2oz lighter. A modern 2S 350mah lipo pack will be lighter than 1 cell of the 4 cell nicad pack / or AA dry cell used back then.
Old Mar 16, 2014, 04:03 AM
Amp Abuser's Avatar
Joined Dec 2007
The original plans stated 24 to 28oz weight all up. A modern version can be made under 19oz.
You can use a single micro servo per aleron and one for flaps for a 5ch plane.
Old Mar 16, 2014, 09:09 AM
teeceeveecee is offline
Find More Posts by teeceeveecee
Old Submariner
United States, WI, Milton
Joined Dec 2007
Really Good Engine Needed- Then.....
NORVEL-
Why use some of the engines that need constant "tinkering" Use the .061 RC version and have a great combination...
Tom
teeceeveecee is offline Find More Posts by teeceeveecee
Old Mar 16, 2014, 10:14 AM
Amp Abuser's Avatar
Joined Dec 2007
Yes Norvel just have to tend with the added weight /power of that engine and muffler.
http://www.nvengines.com/index.php?p...mart&Itemid=65
Norvel: NV Big Mig 061 R/C
Price: $74.99
Specifications
Displacement - 0.061 cu.in. 0.99 cc
Compression ratio - 9.5 - 11
Average performance - 4,000 - 18,500 RPM
Weight - 2.01 oz / 57 grams
Old Mar 16, 2014, 11:46 AM
Paul_BB is offline
Paul_BB's Avatar
Joined Feb 2007
Originally Posted by teeceeveecee View Post
NORVEL-
Thanks for the tip, Tom.
Price: $74.99
Specifications
18,500 RPM? with a 6x3 black prop and with the muffler? Wow. And the throttling range is nice. Is this engine reliable?
Old Mar 16, 2014, 01:48 PM
Amp Abuser's Avatar
Joined Dec 2007
Here is what Rusty had to say:
RknRusty (Thursday, 14 March 2013)
Rating:
The Big Mig .061 has replaced the Cox Tee Dee .049/.051 on some of my CL planes. Though the Tee Dee is a great dependable performer, the Big Mig .061 will blow its doors off. And even with the added power the NV gets Much better fuel economy. With an ounce of fuel a Big Mig will still be in the air long after the Tee Dee has landed. Even with a muffler you can prop it for as much power as you'll ever need for a 1/2A plane. They continue to get faster the more you fly them. My oldest Big Mig turns 28,800 RPM with a 5" prop. The recommended 6" prop doesn't do this engine justice.
It's happiest really unwinding with a smaller prop.
rknRusty
Old Mar 17, 2014, 02:49 AM
Paul_BB is offline
Paul_BB's Avatar
Joined Feb 2007
Thanks Amp Abuser.
On a side note - I remember long ago I tried to throttle my TD .049. I fitted my TD with a Tarno carb but I also had to add a muffler to get a reliable idle. But then it lost all its power and looked more like a worn out Babe Bee.
-Paul
Old Mar 17, 2014, 11:48 AM
madsci_guy is offline
Find More Posts by madsci_guy
Figure Nine Champ
madsci_guy's Avatar
North Texas
Joined Nov 2002
Fred recommended a 6x3 gray prop, for a Tee Dee on a HOB Mustang, I would use a 5 1/2 x 4. black prop. The Tee Dees really did a lot better with the smaller props.
Used Tee Dees are perfectly fine if you:
1. Replace the old compression glow head. Use a high compression (two fin) head like below. Make sure to replace the copper washer.
2. Make sure the plastic that holds the venturi is not cracked.
3. Make sure the con rod is not loose. A piston resetting tool will fix that problem. If a Tee Dee has a lot of time on it, it is a common problem, but easily fixed.
madsci_guy is offline Find More Posts by madsci_guy
Old Mar 17, 2014, 12:45 PM
Paul_BB is offline
Paul_BB's Avatar
Joined Feb 2007
Thanks for all the info madsci_guy.
But if I can get 18,500 from the NV Big Mig .061 R/C and also good idling... I think I'm already hooked.
Old Mar 17, 2014, 01:07 PM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
With little props, even a fairly high idle is ok, most planes will drop from the sky likely even at 6,000 rpm.
aspeed is offline Find More Posts by aspeed
Old Mar 17, 2014, 02:57 PM
Amp Abuser's Avatar
Joined Dec 2007
If I built that mustang this would be my set up a 5x5 glass /plastic prop carb with muffler on a TD.051 to keep things light on the airframe. About 20k on 30% nitro in the air unloaded ish my guess. Engine as shown is 74g./ 2.64oz. and to the right a TD RC .051 78g. 2.8oz with only a head mod.
Old Mar 18, 2014, 12:27 PM
pspring is offline
Find More Posts by pspring
United States, MN, Andover
Joined Sep 2012
I've got a HOB P51 on the board also. Is there a lot of difference between the Norvel ABC .049 and BigMig .061? What prop would you recommend for the NV 049? 5.5?
I was going to put an 049 Medallion in the P51 but found a new 049 NV at a garage sale. Based on what you guys are saying the Medallion would only be good for slow flyby's. lol Thanks for all the input and experience!
pspring is offline Find More Posts by pspring
For Sale RimFire 1.60 equiv to about a 30cc gas engine SkylineFlyer Aircraft - Electric - Power Systems (FS/W) 0 Nov 24, 2013 09:10 PM
Discussion Which is better for rc cox engine? rcrich 1/2A Planes 6 Mar 09, 2011 06:18 PM
Discussion Which Cox engine is this? Will Rock Engines 5 Jan 13, 2009 02:47 PM
For Sale NIB G-Mark .061 R/C engine/ NIB VA RC engine/NIB Cox engines airplane-1 Aircraft - Fuel - Engines and Accessories (FS/W) 5 Sep 22, 2006 04:49 PM
WTB HS81's or equiv and a hitec 555 or equiv...for a zagi reznikvova Aircraft - Electric - Airplanes (FS/W) 2 Dec 12, 2002 06:56 PM
