Old Nov 13, 2012, 07:42 AM
guytimes is offline
Find More Posts by guytimes
United States, KY, Louisville
Joined Apr 2009
How to: Specktrum Radio DX7 replace switches
I dropped my radio and broke two, two position switches. I could not find a "how to" so here goes:
1. Go to radio shack and buy replacement switch, 275-635
Description:
EDIT: Make sure the battery is removed before taking apart your radio! (as 66 points out below)
2. Open the back of the radio, with the 4 screws, and the secret, two more hidden behind the rubber grips as shown in picture.
Description:
Description:
3. De-solder and solder in new switch
Description:
4. Turn the radio on, and check to see the position of the switch is correct.
Description:
You're done!
Caution, SERVICING (not just opening) your radio voids your warranty. And freechip brings up a good point, to make sure nothing else it wrong with your radio. In my case, I've been flying with it for a month and no issues, so I think I'm good.)
guytimes is offline Find More Posts by guytimes
Old Nov 13, 2012, 09:26 AM
Daedalus66 is online now
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Originally Posted by guytimes View Post
Caution, opening your radio voids your warranty.
Thanks for the useful instructions, but this last point is not correct. What the warranty actually says is the following, with relevant bit in red:
What is Not Covered
This warranty is not transferable and does not cover (i) cosmetic damage, (ii) damage due to acts of God, accident, misuse, abuse, negligence, commercial use, or due to improper use, installation, operation or maintenance, (iii) modification of or to any part of the Product, (iv) attempted service by anyone other than a Horizon Hobby authorized service center, or (v) Products not purchased from an authorized Horizon dealer.
You can open the back. Just don't mess around modifying or servicing things. In fact, my experience has been that as long as the modifications haven't caused the problem you are seeking to have fixed under warranty, the HH service people don't object.
Note that the manual says: "Always power off the transmitter, disconnect
and remove the battery before opening the transmitter case."
Daedalus66 is online now Find More Posts by Daedalus66
Old Nov 13, 2012, 10:04 AM
freechip is offline
Find More Posts by freechip
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
Very cool but also understand that many would rather have the radio serviced by the right people as they would also perform a full system check to ensure nothing else is wrong with the radio.
freechip is offline Find More Posts by freechip
Old Nov 13, 2012, 05:48 PM
guytimes is offline
Joined Apr 2009
Thanks for the great comments, guys. I edited my post to note your good points.
Old Nov 13, 2012, 05:52 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Opening the radio is not servicing it. Most radios (not 7s) require you to open the case to adjust spring tension, so this is certainly not a general rule.
Old Nov 13, 2012, 05:55 PM
guytimes is offline
Joined Apr 2009
I see. So changing out switches is not servicing it either?
Old Nov 13, 2012, 05:58 PM
freechip is offline
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
The idea is that opening the radio does not automatically void the warranty, in some case the user is required to do so for example when changing MODE.
What you did is service the radio and/or made repair work yourself, this could void the warranty but like mention previously HH is pretty good when it comes to these things.
Question Specktrum modules for Futaba radios are they BNF capable? Scooter619 Radios 25 Jul 28, 2013 11:24 PM
Discussion Adjusting Friction Straps on Specktrum DX7 Altbob Power Systems 12 Feb 22, 2013 03:51 AM
Sold Specktrum DX7S corsair167 Aircraft - General - Radio Equipment (FS/W) 2 Jul 10, 2012 06:38 AM
Discussion DX7 flap switch replacement? Barak1001 Coaxial Helicopters 3 Mar 29, 2009 10:23 AM
Sold Specktrum DX7 radio and Case MUDBOGGER2 Aircraft - General - Radio Equipment (FS/W) 6 Oct 13, 2008 05:18 PM
