Old Sep 27, 2012, 06:14 PM
RyanNX211 is offline
Find More Posts by RyanNX211
RyanNX211's Avatar
Upper Arlington, Ohio
Joined Dec 2007
Odd-Ball programming scenarios
I thought that the DX8 had the easiest programming features until I spent two minutes with an A9. After losing most of my planes due to lockouts/brownouts/whatever I'll be spending a lot more time with an A9.
Since basic programming is so easy, I thought I'd start a thread where we could challenge each other.
Here's my submission:
The subject is basically a three channel motor glider flown in Mode 2. It has double rudders activated by the aileron stick and actuated by two servos in the stab.
I think I've figured out how to get more deflection from the inboard rudder by limiting throws but I'd like to be able to do something a little different. With the left slider, I'd like to be able to turn them both outward as airbrakes and still maintain some directional control. Slider forward, rudders parallel; slider back,rudders split.
I don't mind digital trims that much, except on the elevator. For that, I like something a little more tactile; something I don't need to hear over engine noises and talking. Can I put the elevator trim on the right slider?
RyanNX211 is offline Find More Posts by RyanNX211
Old Sep 27, 2012, 08:34 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Since basic programming is so easy, I thought I'd start a thread where we could challenge each other. :
Similar set up:
. Aurora 9 - Airbrakes -Twin Rudder set up. posts 4503 & 4504 e.g. Stryker 27Q & Funjet mode 1&2 setup & Zip files
Trim:
. Aurora 9 - Trim Mixes In-flight - Cross Trim, In Flight Mix Changes, Re-Assign or Mix Trims.
. Aurora 9 - Programming Chart
When your model set up complete, add to:
Aurora 9 - Model Set Up & Templates Program (Model) Templates.
(Download existing Set Ups and transfer to your Aurora. Upload & share your own set ups/solutions.)
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry
- FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
$65 - New JR max radio set w/ni-cads 2-507 servos, 1 L501 servo and 1 used odd ball braxx Aircraft - Electric - Airplanes (FS/W) 0 Feb 06, 2004 10:33 AM
$65 - New JR max radio set w/ni-cads 2-507 servos, 1 L501 servo and 1 used odd ball braxx Aircraft - Fuel - Airplanes (FS/W) 0 Feb 06, 2004 10:31 AM
$75 - New JR max radio set w/ni-cad ( 2-507 servos, 1 L501 servo and 1 used odd ball) braxx Aircraft - Electric - Airplanes (FS/W) 0 Feb 02, 2004 10:59 AM
$75 - New JR max radio set w/ni-cad ( 2-507 servos, 1 L501 servo and 1 used odd ball) braxx Aircraft - Fuel - Airplanes (FS/W) 0 Feb 02, 2004 10:57 AM
New JR max radio set w/ni-cad (TX, RX, 2-507 servo, 1 L501 servo and 1 used odd ball) braxx Aircraft - Electric - Airplanes (FS/W) 1 Jan 21, 2004 09:19 PM
