Old Sep 17, 2012, 06:10 PM
zhavener is offline
Find More Posts by zhavener
United States, GA, Athens
Joined Feb 2012
Ugrading Hyperion 720i Duo to Bluetooth
I am trying to upgrade my 0720i Net Duo 3 to Bluetooth in an attempt to resolve an Issue with running the EOS suite off of my Power Supply that for 24vdc use has a floating ground.
I have the Bluetooth Module and have read over the description http://www.wheelchairdriver.com/hype...conversion.htm
However I can not tell in the linked pictures where the Tx and Rx wires are soldered.
It appears that they are connected to R358 and R49 but I can not tell for sure and I have no idea which is Rx and which is Tx
Here is a Pic of what I am looking at. The Points of confusion are just under the FAN connector
zhavener is offline Find More Posts by zhavener
Old Sep 18, 2012, 09:19 PM
zhavener is offline
Joined Feb 2012
Stuck the multi meter on the subject case and last pin of the temp sensor and only got a reading of 2.2vdc is this enough to power the bt module? I'm guessing it's not
Discussion Hyperion 720i super duo 3 problems Eddy Batteries and Chargers 39 Jun 19, 2013 11:03 AM
For Sale Hyperion 720i DUO DC charger JimRussell Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 24, 2012 09:00 PM
Wanted Wanted Hyperion 720i Duo lafuerza Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 20, 2012 12:26 AM
Wanted Looking for new or slightly used - Charger Hyperion EOS 720i super duo 3 ganapati08 FPV Equipment (FS/W) 0 May 27, 2012 01:23 PM
Sold Hyperion Super Duo 3 720i flymustangs Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 05, 2012 06:21 PM
