Old Mar 25, 2012, 06:19 PM
nsg is offline
nsg
Find More Posts by nsg
nsg
Yardley, PA
Joined Sep 2006
Phoenix 10 and MP Jet 22/4
Dear all -
By way of something completely different..
What would be a good setup for a Phoenix 10 turning an MP Jet 22/4-90D? It's a 1300 kV motor, 90 (sic!) turns, 17g. The prop is GWS HD 8040, 2s for about 3A.
I did some trial and error - ended up with PWM of 24, custom timing 1, high power on startup, high response to throttle. The motor hesitates a bit if I go from zero to full throttle - I think it's having trouble turning the prop. No problems without the prop; no problems if I advance the throttle gradually, or the prop is turning already.
The plane is an Alfa Albatros. I chose PH-10 because of low weight and high efficiency (mostly the latter), and also to leave myself some headroom if I go to a bigger motor.
Thanks!
nsg is offline Find More Posts by nsg
Old Mar 26, 2012, 11:04 PM
Klogg96 is offline
Find More Posts by Klogg96
USA, CA, Long Beach
Joined Jun 2004
I had a similar setup ... 22/7-45 D with an 8x6 prop with a Phoenix 10. I never measured it, but my calcs indicate about 10 amps static.
I couldnt ever get the thing to start right. I didnt much care though because it only starts once (it windmills when you pull throttle out). I have since transitioned to a MicroDan motor. I asked for a custom wind many years ago aiming for the 1400Kv of the origional. It turns out, the micro dan motor doesnt start very well either.
I would have to admit that it has been so long now that I dont even know what version of the firmware it was. I would say the latest firmware 3 years ago ...
Klogg96 is offline Find More Posts by Klogg96
Sold MP JET Folding Spinner 40mm 8/3 5mm collet jrej Aircraft - Sailplanes (FS/W) 4 Mar 19, 2012 03:57 PM
Discussion Mounting Speed 300 in MP-Jet Gearbox rszanti Power Systems 4 Mar 14, 2012 09:49 PM
Discussion Firmware Phoenix, Phoenix HV, and Phoenix Ice Series 4.00 Beta 02/22/12 imagine 50 Castle Creations 25 Mar 04, 2012 12:24 PM
Sold Mp-Jet 22-7/60D--Eflite 10 amp esc(Price Drop) 800mZero Aircraft - Electric - Power Systems (FS/W) 2 Jun 13, 2007 07:12 AM
MP JET AC 22/7-60D MJ20204 Outrunner prop / thrust data? IA-Flyer Power Systems 0 Feb 28, 2005 03:47 PM
