Old Oct 01, 2011, 06:28 PM
Ralph A. D'Amelio is offline
Find More Posts by Ralph A. D'Amelio
Ralph A. D'Amelio's Avatar
United States, MA, Chelmsford
Joined Jul 2000
A-10
I'm currently building this A-10 from Uncle Willies and am interested if anyhone has built this per plan. I'm doing mine as an electric but interested in any flight info gas or electric. Also any articles that may be associated with this plan. BTW the plans are great.
http://unclewilliesplans.com/about31.html
Ralph
Ralph A. D'Amelio is offline Find More Posts by Ralph A. D'Amelio
Old Oct 01, 2011, 06:33 PM
Joined Jul 2000
Some pics of wing
Old Oct 02, 2011, 05:55 AM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Hey DAF!!!!!!
Long time no hear! Great to see you at it again.
Wish I could help you but have no experience with that plan. I did just pick up plans for a 92" ws A-10 so I guess great minds run in the same channel, huh?
J
J Morgan is offline Find More Posts by J Morgan
Old Oct 02, 2011, 10:51 AM
Joined Jul 2000
Hey J
I been lurking in the background and watch your planes at the 2 events and CN flying as well. Ya been taken it easy still flying some small foamy stuff...just got the urge to smell balss dust again!! Geez what a nice smell.
92" ws is that the wowplanes ...it looks awesome. Thanks for remembering me.
DAF
PS I still haven't lost my touch...building heavy...the wing wieghs 21 oz.
Old Oct 02, 2011, 03:11 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
No, it's an old slimer ducted fan plan. Decent outlines but will need a lot of work for a more scale appearance. Man, at 92" it is huge!
Building heavy? My last two were over 12 lbs AUW. What size is the willie's plan?
J
Old Oct 02, 2011, 03:34 PM
Joined Jul 2000
J,
Nice size at 56"ws The plans are fantastic just take them to Kinko etc to print out or scale up.
DAF
Old Oct 02, 2011, 06:34 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
I'm wanting to go somewhat larger DAF. After looking at them, the 92" ws might be a little too big. But I haven't settled on building it just yet either. Please post your progress.
J
Old Oct 02, 2011, 06:48 PM
Joined Jul 2000
J
I meant to ask you are going EDF or pusher prop(s)?
Getting enought power isn't a problem with todays BL motors and lipos. One problem with a pusher is the limit on the size of the prop and not being able to rotate on TO...but thats what 3 bladed props are for.
Of course we could put 2 BL motors in the engine pods again limit on prop size...and 2 motors combined will give you more power than 2 motors..I bet 15-30% more.
This what makes the scratching fun....not always knowing how it will all come out....love living on the edge.
DAF
Old Oct 02, 2011, 07:54 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
I was figuring either pushers or even tractors in the nacelles. Still a little limited on prop size but with today's motors, shouldn't be a problem. No way I'm going EDF, that porker would be 50 lbs!
J
Old Oct 08, 2011, 07:36 PM
Joined Jul 2000
some more progress..
the side view that bothers me although its per plan.
I think it needs to be flatter along bottom and start its upward curvature just before tip of nose. I think I'll slice some off the bottom and add a peice and reshape...gotta love foam
Old Oct 09, 2011, 08:48 AM
mrshea is offline
Find More Posts by mrshea
michigan jet guy
mrshea's Avatar
USA, MI, Caledonia
Joined Jul 2007
looks good ralph. I bet that nose will look just fine once you stick the cannon in it. Phil
mrshea is offline Find More Posts by mrshea
Old Oct 09, 2011, 09:15 AM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Coming right along DAF!
J
Old Oct 10, 2011, 02:37 PM
Joined Jul 2000
Thanks mrshea....
J, as a point of reference for your big A10 at this point all balsa except for pink foam & balsa fuse top. regular servo for elevator..13ga wire(+-) from motor to nose (twisted)...wt 2lbs11oz ( 43oz)....really not too bad. wing alone wts 21oz....making fuse alone 22oz.
I got some 6/3mm depron and am tempted to make another wing with 6mm bottom skin, 6 mm ribs and 3mm top skin with spruce 3/16 sq spars.....1.5 oz FG + PU.........I thinking of a goal of 10oz ...of course if it did come out this lite then 6mm depron with 1/16ply reinforcred fuse with 2oz fgpu.
Than can use a smaller motor & bat and hand launch the sucker.
J, what do you think?
Ralph
Old Oct 11, 2011, 12:09 AM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
I think that is worth considering. At that size the weight will be important. I think I would redo the wing if you think you can really cut the weight in half.
J
Old Oct 11, 2011, 09:05 AM
Joined Jul 2000
J,
I looked at one of you threads ....the B26 I think and saw how you are doing
the fuse...thats awesome! The A10 fuse is quite basic and could be easily be done that way. I'm going to look for a local supply for PVA and wax.
I'm going to do the center panel of the A10 using depron (this is the heavy part of the wing) and see what the wt comes out to...which will give me a good basis for the overall wing wt in depron.
Ralph
Cool Scratch built 1:10 DC-10-30 airliner Ben_E Fuel Jet Talk 3 Oct 10, 2011 02:47 PM
For Sale 10 nib standard gauge y harnesses shipped 10.00 miller6196 Aircraft - General - Radio Equipment (FS/W) 1 Sep 22, 2011 06:29 PM
For Sale Airtronics XL 6ch AM TX $10; RX $10 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Apr 11, 2011 11:10 PM
For Sale FS/FT Brand NEW Airtronics SD-10G 10-Channel 2.4GHz TX w/10-Channel Receiver! gaaunapoi Aircraft - General - Radio Equipment (FS/W) 2 Mar 31, 2011 10:33 PM
For Sale Futaba Attack 4 FM TX $10, RX $10, 40.73MHz John Kim Aircraft - General - Radio Equipment (FS/W) 0 Mar 27, 2011 01:07 PM
