Old Jul 14, 2011, 05:44 PM
miniprinter96 is offline
Find More Posts by miniprinter96
Psalms 23:4
Goshen, IN, USA
Joined Nov 2010
Idea
X-tail plane
i've seen v-tail planes, and that gave me an idea for an x-tail. with the proper mixing you could control yaw, pitch, and roll from the same surfaces. would there be any practicality in this, or would it just weigh the plane down with too much equipment, and decrease it's performance?
miniprinter96 is offline Find More Posts by miniprinter96
Old Jul 14, 2011, 06:51 PM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Mini, we don't recall seeing any X tail planes around here ... The only way to know is to try it out ... sounds like a Cool idea !!!
gpw is offline Find More Posts by gpw
Old Jul 14, 2011, 07:46 PM
Psalms 23:4
Goshen, IN, USA
Joined Nov 2010
would you have any idea how to setup the mixing for a plane like that? i would probably need a lot of v-tail mixers, since i couldn't get enough on my radio...
Old Jul 14, 2011, 08:49 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Seems you would need V tail mixing of some sort ... Why not try making the top of the X work as a V tail , the bottom fixed... ? ... as a start ... Just an idea ...
Old Jul 14, 2011, 09:26 PM
Psalms 23:4
Goshen, IN, USA
Joined Nov 2010
the point of having the x is to get better control. with the x, the surfaces should cancel each other out, allowing for cleaner control. i don't know if you're getting what i'm saying, but the point is, with ailerons for example, the top and bottom would counteract each other, allowing for purely roll, without any pitch. the same would apply to rudder and elevator. just my theory.
Old Jul 14, 2011, 09:34 PM
Rusty Nail is online now
Find More Posts by Rusty Nail
Rusty
Rusty Nail's Avatar
Auckland, New Zealand
Joined Feb 2006
All DLGs are X tail - but you want one without any surfaces parallel to the wing.
The inverted Y is also sometimes used.
Rusty Nail is online now Find More Posts by Rusty Nail
Old Jul 14, 2011, 09:43 PM
Psalms 23:4
Goshen, IN, USA
Joined Nov 2010
what i'm thinking about doing is mixing the v-tail and the inverted y, only it would be more like an inverted v and a regular v-tail. again, this is all in theory, but i would like to test it out. do you know how many v-tail mixers it would take to set it up like this?
Old Jul 15, 2011, 05:28 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Thinking just the one ...
Old Jul 15, 2011, 10:10 AM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
I don't think you'll be able to control Roll, because all the surfaces would be much closer to the centre line than the wing tips. Some jets use the tail for roll, but they have short wings and wide tails, and go so fast they don't need efficient controls.
Otherwise, just set it up like a V tail.
I think the reason it's not common is that the lower part will be damaged easily when it lands.
RobinBennett is offline Find More Posts by RobinBennett
Old Jul 15, 2011, 10:28 AM
Psalms 23:4
Goshen, IN, USA
Joined Nov 2010
the point isn't to have an x shaped tail. i want to have all four surfaces moving. with an extra large tail, and large control surfaces, i think it would be possible. if i would dial down rudder and elevator, but leave the ailerons on full throws, i think i could be able to control roll with it too. i want to be able to control pitch, roll, and yaw using all four surfaces for each one.
Old Jul 15, 2011, 11:29 AM
Quick61 is offline
Find More Posts by Quick61
Just call me crash for short
Quick61's Avatar
United States, OH, The Plains
Joined Jan 2011
What you might be thinking about is something like this? I have seen several built like this, some worked better than others. Careful about how big you make the tail. Too big can be as bad as too small. If I am remembering correctly, the shorter the tail booms were on this type of tail, the less effective they were.
Quick61 is offline Find More Posts by Quick61
Old Jul 15, 2011, 01:46 PM
Psalms 23:4
Goshen, IN, USA
Joined Nov 2010
that's exactly what i was thinking!! how effective is this design?
Old Jul 15, 2011, 02:30 PM
Sussex, UK
Joined Jun 2004
Do a little maths - compare the total area of your control surfaces with the area of normal ailerons (probably about the same, maybe the X-tail will be twice as big). Then multiply each area by the average distance from the centre-line. At a guess, ailerons will have about 4 times as much power as your tail.
If you use large surfaces, with big control throws, it might be controllable but it'll cause more drag than normal ailerons for less effect.
What would work would be an X-shaped model, like the Pogo
hobby-lobby.com Pogo (1 min 4 sec)
Old Jul 15, 2011, 03:00 PM
Strizzo is offline
Find More Posts by Strizzo
United States, TX, Houston
Joined Jun 2011
seems like you could get it done with a Y harness and a pair of v-tail mixers, similarly you might be able to do it with a pair o Y harnesses and v-tail mixing on your radio, if you set it up like a regular V-tail and just hook the upper and lower tails to the same linkage (both control horns would have to be on the same relative side of control surfaces) you might be able to get it done without extra crap, but wouldn't be able to control roll
tricky part comes when you want to be able to roll with the tail surfaces as well as use the v-tail functions, interested to see what comes of it.
Strizzo is offline Find More Posts by Strizzo
Old Jul 15, 2011, 03:05 PM
Psalms 23:4
Goshen, IN, USA
Joined Nov 2010
i want to have a 3 axis plane, without having any other surfaces. so i need to be able to do all three functions from the tail.
Discussion V tail vs. X tail NedBurdick Thermal 116 Jul 19, 2015 11:57 AM
For Sale 2 x Gaui 200 V2 tail assembly with CNC tail pitch OCFly Aircraft - Electric - Helis (FS/W) 2 Sep 01, 2011 08:13 PM
Wanted Mini Funtana-X Tail Set Yc2011 Aircraft - Electric - Airplanes (FS/W) 1 Jun 25, 2011 10:41 PM
Discussion Explorer 4.0 X tail Vs Explorer 4.0 V tail spread tow Hoot Multi Task F3X 0 May 06, 2011 08:07 PM
For Sale New Plane Quiver V-Tail and X-Tail Socks seto Aircraft - Sailplanes (FS/W) 8 Mar 19, 2008 10:42 AM
