Old Apr 23, 2011, 07:29 PM
helifreak592 is offline
Find More Posts by helifreak592
United States, FL, Hollywood
Joined Nov 2010
Up Grade
bought one of these-http://www.nitroplanes.com/93a275-800p51-yellow-rtf-24g.html , what to up grade the motor and the prop , thinking about the motor -http://www.hobbypartz.com/75m40-optima400-2215-1200kv.html#scProductReviews , but i don't know what size of prop top used
helifreak592 is offline Find More Posts by helifreak592
Old Apr 23, 2011, 07:34 PM
Xpress.. is offline
Find More Posts by Xpress..
Hitec RCD CSR
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
I think that motor would work. I'd run a 9x6E (NOT the SF version) prop with a 3S lipo. That should hot rod that mustang. Don't forget to toss out the included electronics (which is why it's best to buy just the airframe ), which very likely are junk, which is what you get with $89
Xpress.. is offline Find More Posts by Xpress..
Old Apr 23, 2011, 09:49 PM
Joined Nov 2010
ok thanks , so what type of esc, servo and battery to buy , or can you send the link of the individual for me
Old Apr 23, 2011, 10:34 PM
Xpress.. is offline
Hitec RCD CSR
Xpress..'s Avatar
Joined Oct 2007
1800mah 25C 3s lipo, a 25 amp BL ESC with BEC, and any 9g servo. You can get all of that from HobbyKing. HXT900 servos, a Plush 25 amp ESC, and any one of the 3s 1800mah 25C lipos. Also don't forget the lipo charger (if you don't have one).
Old Apr 23, 2011, 10:45 PM
Joined Nov 2010
but it will work for this plane---http://www.nitroplanes.com/93a275-800p51-yellow-rtf-24g.html
Old Apr 24, 2011, 12:09 AM
Xpress.. is offline
Hitec RCD CSR
Xpress..'s Avatar
Joined Oct 2007
Yes... I wasn't aware we were talking about another airplane
Old Apr 25, 2011, 08:43 AM
Joined Nov 2010
this is the plane that i have , so i am wondering your recommendation will work
Old Apr 25, 2011, 10:56 AM
Xpress.. is offline
Hitec RCD CSR
Xpress..'s Avatar
Joined Oct 2007
I have answered all of your questions...
Question Futaba Trans. Battery Up-grade WildWings Radios 7 Mar 21, 2011 11:09 AM
multiplex..... software up grade sventek Electric Plane Talk 7 Jun 11, 2006 09:03 PM
Fantastic GeeBee up-grade sparks Parkflyers 3 Jun 14, 2003 09:39 PM
Great Planes Up grade to G-2 AMTJIM Aircraft - Electric - Airplanes (FS/W) 0 Jan 24, 2002 07:54 PM
What is the best up grade from a graupner sp280? KOMET 44 Power Systems 13 Jan 20, 2002 11:35 AM
