Old Oct 19, 2003, 05:36 PM
GailInNM is offline
Find More Posts by GailInNM
Near Albuquerque, NM USA
Joined Apr 2003
HodgePodge
I just have a preliminary simple decoding scheme in place so far. It is far from finished, but is a standard interrupt based procedure. On leading edge of pulse from receiver interrupt checks timer that is running. If it has been more than 5 ms since the last pulse then assumption is made that it is a new frame and channel count starts at 0. If between .9 and 2.1 ms then it is considered a valid signal and the value is placed in ram for further processing and channel count value incremented. Then the timer is reset and return from interrupt. This is only for testing so far as I want to add some glitch testing and then clean it up.
I program in assembly language. I will be happy to share code when I get a little further along. Working on other things right now so it will probably be about 2 weeks before I get back to it. Most of the code should be OK on the f300.
Gail
GailInNM is offline Find More Posts by GailInNM
Old Oct 19, 2003, 06:33 PM
clipclop is offline
Find More Posts by clipclop
QLD, Australia
Joined Sep 2003
Thank you Patrick,
I am new to this IR and micro models so all advice is greatly appreciated. I have been flying indoors for about 4yrs but just with gws equip , nothing super light
I have to learn how to build light too another hurdle , but life is a learning curve i suppose
Thank you to Dave ,
For the addy's and the transistor replacement No's , love these forums and all the helpfull people shareing this great hobbie
Stewart
clipclop is offline Find More Posts by clipclop
Old Oct 19, 2003, 09:42 PM
dcamp0 is offline
Find More Posts by dcamp0
Peculiar, MO
Joined Aug 2003
Dave,
Do you have any idea when the Inside Story article will be done? There a lot of info on this forum, but some of it is hard to follow, for me anyway.
Don
dcamp0 is offline Find More Posts by dcamp0
Old Oct 19, 2003, 11:13 PM
david_dewit is offline
Find More Posts by david_dewit
Australia
Joined Sep 2001
Hello Don,
Best I make no promises at the moment, have a fair bit on my plate already, but I will get it done asap.
I think what may also be a good idea is an index at the begining of useful threads.
I will look at editing an index and more links to start of this thread, that should help.
Dave
david_dewit is offline Find More Posts by david_dewit
Old Oct 19, 2003, 11:36 PM
billystiltner is offline
Find More Posts by billystiltner
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
Good idea Dave about the index.
I was thinking of starting a seperate thread for the JDM programmer till it is sorted out I'm thinking it could add
un-needed posts to the threads trying to get a PIC programmer
working which only has a tiny bit to do with the DIYIR and DIY LRFers.
Billy(still stuck with verify failed at 00h)
billystiltner is offline Find More Posts by billystiltner
Old Oct 20, 2003, 02:30 AM
Australia
Joined Sep 2001
Billy,
May not be same problem I had, but same symtoms.
My hardware settings are:
JDM programmer
Com 2 (programmer must be in selected port)
I/O delay 4
Windows API
When I first downloaded icprog hardware settings were not as above and I had to change them. This should not be the case.
These should set automaticaly I believe.
I'll put some more time into article and get it finished.
Dave
Old Oct 21, 2003, 08:31 AM
Australia
Joined Sep 2001
Weight 0.4 gram on 0.1 resolution scales.
Old Oct 21, 2003, 08:52 AM
clipclop is offline
QLD, Australia
Joined Sep 2003
Neat job David , i hope mine can look as good
Stewart
Old Oct 21, 2003, 08:21 PM
Australia
Joined Sep 2001
0.9 gram as pictured and with lightened sensor.
Dave
Old Oct 21, 2003, 09:14 PM
clipclop is offline
QLD, Australia
Joined Sep 2003
David, were are you getting thin pcb or are you cutting it down???
the thinest i can get is 1.6mm way to heavy
Stewart
Old Oct 21, 2003, 09:42 PM
Australia
Joined Sep 2001
Stewart,
I'm cutting down 1.6mm pcb at the moment. Reasonably easy to do with pcb this small.
To save some time I split thickness about half way.
Then I go ply by ply.
I put point of knife in corner of board and seperate ply along short side two or three mm. Then put blade lengthwise under ply and with some pressure you should be able to slice ply off neatly.
Then a light sanding. PCB in picture is under 0.4mm or 0.015".
Dave
Any chance of getting a copy of SC article
Old Oct 21, 2003, 10:08 PM
Australia
Joined Sep 2001
Picture or two of how I do it.
Old Oct 21, 2003, 10:09 PM
Australia
Joined Sep 2001
Old Oct 22, 2003, 01:44 AM
clipclop is offline
QLD, Australia
Joined Sep 2003
Thank you David,
think i can manage that , its kinda what i thought i may have to do , with luck my smt components will be here tomorroe or day after, have my fingers crossed-will wait till i have them to check against board layout, i think i ordered the right size bits
my back has been too bad this week to concentrate on programing some pics -need a clear head .
my TX is ready oh what hex file will i need for a JR with throttle on the right stick ???
i also built a 3 servo rx to test -can use in my existing indoor model not a super light weight lol -------150grams
Stewart
Old Oct 22, 2003, 01:57 AM
clipclop is offline
QLD, Australia
Joined Sep 2003
This is my model
own design flys real good just gws equip -i must draw up a plan one day .
Scale it down for the ir equip .
Stewart
questions on diy ir rx jonathan8388 Scratchbuilt Indoor and Micro Models 29 Jan 11, 2005 10:44 AM
Question Diy IR Z-tron Tx micromad Scratchbuilt Indoor and Micro Models 0 Dec 10, 2004 11:50 AM
DIY IR Rx PCB's david_dewit Scratchbuilt Indoor and Micro Models 11 Nov 04, 2004 05:12 PM
Where is the DIY IR and LRFers thread? Timbo337 Scratchbuilt Indoor and Micro Models 2 Dec 30, 2003 04:29 PM
DIY IR 555 timer help. j8m8l Scratchbuilt Indoor and Micro Models 4 Dec 03, 2003 10:02 PM
