Old Dec 08, 2011, 08:31 PM
QiW is offline
QiW
Find More Posts by QiW
QiW
south east asia
Joined Mar 2009
sorry but i read earlier about lawmate receivers not doing good with spw or cl.
i could not find info on that and solving the lawmate vrx issue... or is it still an issue ?
i have recently acquired a lawmate vrx since i heard about how good it can be vs generic chinese vrx.
thanks
QiW is offline Find More Posts by QiW
Old Dec 08, 2011, 11:23 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
thanks
That was an isolated special problem. There is no problem with LMRX and these antenna.
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Dec 10, 2011, 09:02 AM
QiW is offline
QiW
QiW
south east asia
Joined Mar 2009
thanks...
Old Dec 28, 2011, 02:41 PM
Chairwolf is offline
Find More Posts by Chairwolf
I think it'll work this time!!
Chairwolf's Avatar
399 feet above Roanoke, VA
Joined Jan 2007
My first SPW Antenna
Well, here it is, my first attempt at an SPW antenna for my RX. It's 910 mhz. Works so far on the bench, so I went ahead and gooped it up with hot glue.
This antenna was made from a Rubber Ducky antenna from HK. I had to do this because the connectors on the HK VRX are not SMA connectors; so I disassembled the dipole part of the RD and used the coax that was inside. I kept the joint on the connector and hot glued the top end. Then I mounted the clover-leaf end inside a GLAD container.
I'm going to try a ground test today and see how it does with my cloverleaf VTX antenna.
Stand by!
Bob
Chairwolf is offline Find More Posts by Chairwolf
Old Dec 28, 2011, 02:48 PM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Stand by!
Bob
Bob,
Nice work! The drag of that GLAD container will be enormous though....
Markus
markus123456 is offline Find More Posts by markus123456
Old Dec 28, 2011, 02:56 PM
Chairwolf's Avatar
Joined Jan 2007
I don't think my receiver will even notice!
Old Dec 30, 2011, 12:41 AM
volto is offline
Find More Posts by volto
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
It will if the wind picks up
volto is offline Find More Posts by volto
Old Dec 30, 2011, 06:50 AM
RaptorAP is offline
Find More Posts by RaptorAP
W4UAV
Gainesville, FL
Joined Nov 2005
Very nice, Bob! Nice work!
RaptorAP is offline Find More Posts by RaptorAP
Old Dec 30, 2011, 08:07 AM
Lauri1000 is offline
Find More Posts by Lauri1000
Joined Feb 2011
Made antennas
Yesterday I made my first 5.8 Ghz circular polarized antennas. Cloverleaf turned out nicely but Skew-Planar Wheel was a bit messy. I put too much epoxy on Skew-Planar Wheel. Now I need to test these antennas to see how they perform. Used RG58 coaxial cable.
Lauri1000 is offline Find More Posts by Lauri1000
Old Dec 30, 2011, 08:21 AM
Registered FPVer :)
Joined Aug 2006
Originally Posted by Lauri1000 View Post
Yesterday I made my first circular polarized antennas. Cloverleaf turned out nicely but Skew-Planar Wheel was a bit messy. I put too much epoxy on Skew-Planar Wheel. Now I need to test these antennas to see how they perform.
Looking at the fourth picture from the right makes me wonder what may remains in those what it looks 2.4Ghz whip antennas? Usually such antennas are so called pot antennas where there is a metal tube forming one part of a dipole and the center wire the second pole. Now, since your antennas are what seems to be at the far end of the original antenna, I truly wonder if you took the tube out?
Markus
Old Dec 30, 2011, 08:23 AM
Registered FPVer :)
Joined Aug 2006
Ok, I recon that this is eventually just RG58 cable?
Old Dec 30, 2011, 08:32 AM
Joined Feb 2011
It's just RG58 cable, nothing more
Old Dec 30, 2011, 09:06 AM
Chairwolf's Avatar
Joined Jan 2007
Hopefully not! Here's a shot of my brand-new BMGS. (That's Belly-Mounted Ground Station ) I wear the GS with a strap around my neck, right above my belly. My RC Transmitter is strapped below it TO the GS. I can fly with my hands in the "normal" position, and hold my RC TX up above the GS if I need to look at my RC Transmitter (or use it to block the sun).
Flight tested this system yesterday, and it works like a champ!
The SPW and Clover Leaf antennas are performing EXTREMELY WELL, at least in the eyes of this FPV Noob!
Thanks Alex, and everyone else for your help and support!
Bob
aka
Chairwolf
Old Dec 30, 2011, 09:07 AM
Chairwolf's Avatar
Joined Jan 2007
Thanks! I feel like I'm bringing a cake to the field every time I put that thing in the car! ha ha
Old Dec 30, 2011, 09:14 AM
Chairwolf's Avatar
Joined Jan 2007
The shape looks good! Nice work. (I can really say that, because mine are the result of about 4 feet of wire going into the trash can first!!! )
Bob
edit - I just noticed that you mentioned using epoxy. I was thinking - I broke my SPW on the bench right after I bench tested it, and had to re-solder the top (signal) connector. If you use hot glue, and the antenna breaks later, you can melt the hot glue off and fix the antenna. It would be difficult to do (maybe even impossible) with epoxy. So you may want to give hot glue a try for your next one!
No criticism, just food for thought if it might be of some help.
Great work!
Bob
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
Mini-HowTo DIY Ground Plane omni directional RX antenna IBCrazy FPV Talk 60 Nov 19, 2012 06:11 AM
Discussion 900 mhz circular polarized antenna? g00bd0g FPV Talk 9 Aug 21, 2012 09:54 AM
Discussion 18dbi Circular Polarized Patch ? Coyote64 FPV Talk 3 Nov 10, 2010 04:59 PM
Question Circular polarized antenna question Sov4life FPV Talk 8 Mar 05, 2010 05:00 PM
